Question about Kenmore 80809 Microwave Oven
My Kenmore over the range microwave (721.80019401) has no power.
It just went blank. No clock, light or power. I checked the oulet and it is fine.
  • Anonymous Jan 29, 2009
    Kenmore elite (navigator) microwave just stopped working. No power, no lights, nothing...dead.
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore Microwave model 721 62624200
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore 665.61629100 Microwave Problem
The 665 prefix on your model number is Whirlpool, but I haven't found the code "d" listed yet.
Can you set the cooking time?
If so, what happens when you press Start?
I'll post back if I find the codes or if you have other info and I can help further.
Posted on Oct 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
MicrowaveSvc
  • 9098 Answers
SOURCE: kenmore microwave #721-89941-1490
There is an internal fuse, plus one or two thermostats or thermal cutouts.
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
Posted on Jun 29, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: KENMORE MICROWAVE (HOUSEHOLD) LOCKED
It sounds like you press STOP two or three times to lock it. Maybe that (or another key) will unlock it.
The lock / unlock procedure will be covered in your owner's manual.
Or you can try a hard reset - unplug it from the wall for one minute, then plug it back in and try again.
If you don't have your manual, you can get one here. (Enter your model number without any spaces)
Posted on Jul 01, 2008
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
Kenmore microwave nights light don't work.
That's a problem on the circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | Kenmore 62622 Microwave Oven
Kenmore 401.80082700 Over the range microwave just stopped working. WILL DO NOTHING! Is anyone home out there?
I would go ahead and replace the microwave oven the cost to repair will be higher than what you are thinking of getting.
Mar 23, 2012 | Kenmore Microwave Ovens
No power to microwave (but electric oven works fine)
hi yes slow blow 500 milliamp take off rear cover you will see it hope this helps merlinv12
Aug 19, 2009 | Microwave Ovens
11 yr old range/oven ; oven stopped working (clock is out and everything) : stove top is fine. Major expense ro fix ? Am I better off getting new one ?
your clock controls the oven functions. replace clock. probally a little cheaper than a new range but depends on service call fees and labor
Jun 22, 2009 | Kenmore 63792 Microwave Oven
GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 80809 Microwave Oven Logo
795 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
