Question about Car Audio & Video
Audiobahn A1300HCT No questions, I just wanted to thankyou for the "LED removal" fix! I had the same problem and the amp has been sitting in the garage for the last year or two. It might as well have been trash up until last night when I read your post. Damn, I forgot how good that thing sounded! I was told by professionals that the amp was shot, who would have thought> pluck the lights!!! anyways, thanks for the help!!!
Not a problem! my audiobahn amp is still pounding also. those stupid leds will get you every time. What do the "experts" know.
Posted on Nov 20, 2008
No power
may be the coil filter choke is wornout...DC supply stage inside your amplifier...go to the nearest electronic tech to repair that..
May 26, 2010 | AudioBahn A1300HCT Car Audio Amplifier
Audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 23, 2008 | AudioBahn A8000T Car Audio Amplifier
Bridging 2 amps togerther
Not all amps can be bridged together. If the amplifier is capable of being bridged with another amp, the owner's manual will explain how to do it.
Aug 21, 2008 | AudioBahn A1300HCT Car Audio Amplifier
Audiobahn A2301Q amp, charred RCA wires
If the amp goes into protect with the wires unplugged from the board, the amp likely has more serious problems. It may have a shorted power transformer and almost certainly has shorted output transistors. If you think you may want to try to repair it yourself, read through the following page (particularly the information in the yellow box). Respond to this post if you have more questions.
Basic Repair Primer
Jun 08, 2008 | AudioBahn A2301Q Car Audio Amplifier
A1300hct
The amp is almost certainly repairable... If it's defective.
Have you tried disconnecting the speaker wires from the speaker terminals to see if the amp would power up normally?
Apr 17, 2008 | AudioBahn A1300HCT Car Audio Amplifier
Audiobahn A2502DP amp is alive but wont talk to me
Your "bumpin" may have killed the amps "bumpin" Was the amp secure when you were sliding? So wires are ok, and lights and finas running. You have power but no output..Check the settings on the amp, also the fuse. Something might be earthing itself to the amp as well.
Feb 14, 2008 | AudioBahn A2502DP Car Audio Amplifier
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
No sound out of subs
Check the ohm of your soeakers again. If it doesn't say 2 ohm thats the prob. Keep in mind that 2 ohm can be any where from 1.7 too 2.3 but any reading on you DVOM that gives you two decimal places is also wrong. i.e. 2.17. This would mean that you have a woofer shorted.
If thats not it and you have already fixd a ground then use your meter to check the ground; to do this set the DVOM to ohms and touch one lead to a true gound, by that I mean scratch the paint and primer off of a spot you can hide untill you see bright mirror like metal. Then disconnect the ground wire from the amp and touch the other lead to it. You should read anything from 0.3 to 0.1 any higher and your ground isn't that great.
If thats not it, The only thing left is to hook the amp up out side of the vehicle away and not connected to ANYTHING that has to do with the car. Get a battery and a diskman or a playstation, anything that can pass sound out of RCA's (Maybe even a diff radio if poss). Hook it up. If it works its in the car and let me know. I'll tell you some more to check, If not its the amp. Good Luck
Dec 03, 2007 | AudioBahn A1300HCT Car Audio Amplifier
Car Audio & Video Logo
96 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
