Question about Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher
Handle Replacement How do you replace the "latch" handle on the latch assembly?? I have both of the parts but there is no way of installing the handle on the latch assembly. Thank You
  • lindalou760 Dec 12, 2008
    The latch was previously replaced while the unit was under a repair contract. Now it's no longer covered and the latch is broken again. Is this something I should be able to fix? (I'm not very technical...)
    I'm very leery of paying to have it fixed again if it's just going to break again. There's nothing else wrong with the dishwasher... Do you know if Maytag has fixed this problem with the new latches?
You can see a video of this very repair being done on your dishwasher here: http://thatsawesome.tv/?p=44
Posted on Nov 11, 2008
  • 3 Answers
Catriver is correct as far as he goes, but the real problem is getting the plastic handle onto the switch assembly. There must be a 'trick' to this but it eluded me and a trained repair technician so we used pliers and brute force. It should be noted that the plastic handle has been modified since the original. There are now metal reinforcements in the hinge pivot, which was the bit that broke off on the original without the metal strengthening. Suggestions for the correct assembly of the handle and switch will still be welcome.
Posted on Apr 01, 2007
    President:
  • 878 Answers
You are going to have to remove the inside panel and get it from the inside. There should be 11 tork screws on the inner panel. Before lifting it away, disconnect the wires from the vent and dispensor wax motor. The latch assy will can now be removed from the inside. If you take your time and observe, it should be a piece of cake...Catriver..post back.
Posted on Nov 12, 2006
  • Ron Marek
    Ron Marek Apr 01, 2007
    Ales, It's been a while since I replaced one, however it appears that the handle would insert through the front and secured to the latch assy. by the mounting screws that hold the latch down. I don't have one in front of me but I'll take a look at the shop on Monday. If I run across one I'll give you more detailed instructions. In the meantime maybe one of the other good techs on this site may have the trick to this. Catriver
  • Ronald C Brazeau
    Ronald C Brazeau Jan 27, 2013
    Ron after replacing handle now no power to front panel, I did check and there is voltage to panel but nothing lights up and it did before i replaced handle what am i missing?
How do I remove the LCD Housing from the Handle Assembly
The lcd and housing should have been removed from the previous handle...if you have thrown them away then you will have to order the new parts.
May 16, 2017 | Fisher & Paykel DD24DCTB6 Double Tall...
Top coupler on gas pump handle ONLY (Majestic 360 SS) is broken. Do we have to replace whole hose and handle assembly?
They now make a replacement tab so you don't have to replace the entire handle grip. The bad part is, most of the time it's the handle grip that has the broken place in the plastic, not the latch tab. That too can be bought seperately though, so you don't have to buy the hose. Call your local vac shop for assistance.
Oct 21, 2014 | Filter Queen Majestic Canister Vacuum
How do you replace a door latch on a Dometic RM2652 fridge?
Remove the two screws holding the latch/handle assembly on. With the door open, roll the handle outward toward the edge of the door. Then install the new handle assembly.
Aug 31, 2013 | Dometic RM2652 Refrigerator
Amana ADB1200AWQ model dishwasher, built -in, bought replacement part for broken door lock handle. Any idea as to steps to replace it?
Just replace my door latch handle for the 4th time in 6 years. its very easy,,, you have the same as i do. latch and handle assembly i got from amana parts on the internet, # for part is W10130697. it is the same i think as a whirlpool part. call 877-827-5003 to order about 48 bucks. very easy to fix. Open dishwasher door and take out the tork screws ,you will see the latch with the 2 micro swithes on both sides, black on the right and white wires on the left. pull off the plugs , put the new door latch assembly in place and put the two plug bacl on micro switches, put back in all the tork scews and your set to go.... good luck... it is real easy.
Nov 22, 2011 | Amana 24 in. ADB1200AW Built-In Dishwasher
How do I replace the tailgate latch on 2005 avalanche
Welcome to FixYa.com
Latch Replacement - Endgate
Removal Procedure
1. Lowerthe endgate.
2. Loosen the handle bolts.
3. Raise the endgate.
4. Remove the handle bezel by prying gently on the upper retainer tabs.
ImageJ
5. Disengage the linkage rods (1).
Image 1
6. Lower and support the endgate.
1. Remove the cables from the side panel cable retainer bolts.
lmag7
8. Remove the bolt holding the latch assembly.
l_1m a gj
9. Disengage the linkage rod from the latch assembly.
10. Remove the latch assembly from the endgate.
Installation Procedure
L Image
1. Engage the linkage rod to the latch assembly.
2. Install the latch assembly to the vehicle.
Image I
Notice: Refer to Fastener Notice in Service Precautions.
3. Install the latch assembly bolts.
Tighten the bolts to 25 N.m [18 Ib if).
Image I
4. Connect the cables on each side of the endgate to the side panel cable retainer bolts.
Image 1
5. Engage the linkage rods (1J.
6. Raise the endgate.
7. Install the endgate handle bezel. Pressing into place until fully seated.
8. Tighten the handle bolts.
Tiqhten the bolts to 25 N.m 118 lb ftl.
Thank you for Using FixYa.com
Kind Regards, Lee
Your FixYa Expert and Master Technician
Jan 31, 2011 | 2005 Chevrolet Avalanche
Have a maytag dishwasher MDB6600 AWQ -latch/handle broke - bought replacement but not sure how to install - can you help
Just did this myself .Need the right star screw driver to remove 11 screws holding the door inner liner
then you can access the handle latch assembly. You pull off the 2 wire connectors to the switchs that are part of the assembly. Slip connectors onto new assembly.Position the handle part thru the door and re attach inner liner. 2 of the inner liner top screws also hold the assembly in place.Unfortunely , this didn't solve my problem of the dishwasher not turning on.
Jan 06, 2011 | Maytag 24 in. MDB6600A Jetclean II...
Drivers side door won't open from inside and its not the handle-already replaced that. also outside handle is floppy and sometimes the lock doesn't want to unlock with key
The latch assembly needs replacement as well as the springs on the outside handle. You can try to lube the latch with alot of WD-40 and see if it helps. If it doesn't then the latch will need replacement
Mar 31, 2010 | 1996 Ford Explorer
How to replace the exterior door handle,both sides,on a 1992 Chevy S10 pick up. Is there an on line illustrated manual I can download or copy? I will need step by step instructions. Illustrated step by...
remove seat belt bolts and pull it out. the rest is just held in with tabs.
..or if you want Forget taking the door apart - just remove the two bolts holding the latch assembly to the door - Pull the latch assembly out far enough to see the pin that goes through the broken handle - drive the pin out far enough to remove the handle - insert new handle that you just removed from the replacement latch assembly - drive pin back in - Throw the rest of the replacement kit away since all that was broken was a tab on the handle you just replaced.
hope this helps a lot. :)
Feb 13, 2010 | 1992 Chevrolet S-10
Rear door on driver side won't open,have taken the panel off the inside of car,seems like the lock won,t travelas far as it does on the other door.is there any way to open this door,thanks[1997 lincoln...
Rear
Removal
  1. Using a small screwdriver, remove the screw cover from the armrest of rear door trim panel (27406).
  1. Remove the two retaining screws.
  1. Using Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry rear door trim panel from door inner panel.
  1. Disconnect electrical connectors.
Installation
  1. Position rear door trim panel on door inner panel, aligning two locators on rear door trim panel. Reverse Removal procedure.
------------------------------------------------------------------------------------ Rear
Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05 .
  1. Check all connections of remote control links and cables. Service as necessary.
  1. Remove remote control assembly.
  1. Remove door latch remote control assembly from latch assembly.
  1. Drill out rivet at bellcrank and link (264B14).
  1. Remove three screws attaching latch assembly to door.
  1. Drill out rivet that attaches actuator motor to door.
  1. Remove latch assembly with actuator motor and door latch control rod lever link assembly.
Installation
  1. Install new bushings and clip onto latch assembly.
  1. Install latch with links and power lock actuator into door cavity.
  1. Position latch assembly to door, aligning screw holes in latch and door. Install three screws. Tighten to 10-13 Nm (89-115 lb-in).
  1. Attach door latch actuator motor to door with a new rivet.
  1. Install bellcrank and link to door using a new rivet.
  1. Install inside door handle and remote control assembly to door.
  1. Open and close door to check latch assembly operation.
  1. Install watershield and door trim panel. Refer to Section 01-05 .
Item Part Number Description 1 221A00 Door Handle to Door Latch Actuating Cable 2 26446 Rear Door Control Rod Retainer 3 377901 Plug Button 4 26412 Rear Door Latch 5 W623451-S2 Push Nut 6 224A32 Counter Balance 7 22450 Door Outside Handle Tension Spring 8 W701210-S309 Screw 9 224A20 Outside Door Handle Anti Rattle Pivot (2 Req'd) 10 22404 Door Handle 11 224A24 Front Door Outside Handle Spacer (2 Req'd) 12 264A64 Rear Door Actuating Rod 13 22408 Outside Door Handle Anti-Rattle Bumper 14 22428 Outside Door Handle Large Pad 15 N621906-S2 Nut (2 Req'd) 16 N807329 Screw (3 Req'd) 17 26595 Rear Door Electric Latch Actuator (RH) 18 W701566-S47 Rivet 19 431C04-A Rear Door Latch Striker Assembly 20 — Door Lock Striker Plate (Part of Door Shell Assy) 21 W525172-S Rivet (2 Req'd) 22 264B14 Bellcrank and Link (RH) 23 264A50 Bushing 24 N802034-SG Rivet 25 26420 Rear Door Latch Control Rod Link 26 W525172-S Rivet (2 Req'd) 27 21818 RR Door Latch (Inside) 28 A26460 RR Door Latch Push Button Rod 29 21982 Door Latch Rear Striker Assembly 30 N808377-S101 Screw (2 Req'd) 31 250A04 Rear Door Catch 32 N801010-S100 Truss Head Bolt (2 Req'd) 33 N804234-S2 Screw 34 266A74 Rear Door Latch Actuator Retainer 35 24630 Rear Door 36 26552 Rear Door Latch Control Escutcheon A — Tighten to 21-29 Nm (16-21 Lb-Ft) B — Tighten to 10-13 Nm (89-115 Lb-In) C — Tighten to 7-8 Nm (62-70 Lb-In) D — Tighten to 26-34 Nm (20-25 Lb-Ft) E — Tighten to 3-4 Nm (27-35 Lb-In)
Mar 24, 2009 | 1997 Lincoln Continental
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher Logo
167 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
