Lexmark T630 Laser Printer
Problem for Lexmark T630 Laser Printer
When i try to print anything, i get a message 241 paper jam,
By mindy5569 on Nov 11, 2008
It says 241 paper jam,check tray 1
Best Solution
posted on Nov 25, 2008
Very Helpful)
Cops
Rank: Wiz
Rating: 80%, 93 votes
this is most likely to be worn pick up rollers. these are the two rubber wheels that you can see underneath the printer when you remove the tray. you should be able to source these from a local suplier and are very easy to fit. just make sure your gentle with the clip that holds them in place as if they break then you will need to buy a whole new pick up assembaly which is significantly more expensive.
hope this helps
Pete
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Lexmark T630 Laser Printer
Questions and Unsolved Problems for Lexmark T630 Laser Printer
Do you recommend Lexmark T630 Laser Printer?
Answer
Answer
i want to now about Chip Messages of lexmark x340 is the chip full functional? i heard about... (More)
Answer
paper will not feed without jam
Answer
i have lexmark t630 printer, it works fine but every few hours it comes "error" on the... (More)
Answer
I have a couple of these printers with Fax machines on them. They will periodically hang with a... (More)
Answer
problem is with the printer.... 1) when you select print job and you enter the number of copies or... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
