Question about Zanussi FJS1225W Front Load Washer
My zanussi's door wont lock, it normally clicks once to lock but now it clicks three times and does not lock or start washing. I have replaced the locking mechanism but still have the same problem.
  • 183 Answers
Front PCB faulty, if you remove pcb you may be able to resolder blown track on pcb totherwise it will require replacement.common problem with this model. Regards Advisor
Posted on Aug 30, 2007
Zanussi iz16s door does not lock once programme has started i have chage the door lock sytem it clicks and light comes on but the door will still open any ideas ?
give it a swift kick, that should do it... or tip in on its side... and if that doesnt work just burn it and cut your losses!!!
Oct 29, 2011 | Zanussi IZ161S Front Load Washer
Washing machine wont start get E40 come up
This is normally due to the door lock failing.
If you remove the clamp holding the door seal on the front.
Then peel the seal back and remove the 2 screws holding the door lock on.
You can change the lock from there and hopefully this will sort the problem out.
However if still doing the same after changing the lock then the control board will be faulty. But 9 times out of 10 for this fault its the door lock thats the problem
Apr 18, 2010 | Zanussi FJD1666W Front Load Washer
Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi nexus washing machine
almost certainly the door interlock faulty. fairly cheap part and easy to replace.
remove plastic clamp holding door boot to cabinet and peel back in the area of the door interlock. door lock is held in by 2 screws from outside which undo and withdraw lock. disconect electrical plug and small diameter tube at bottom. fitting new one is just the reverse
Oct 18, 2008 | Zanussi FJS1225W Front Load Washer
My zanussi Aquacycle 1100 wont start. A clicking noise starts after I try and start a wash. I heard it could be a door interlock that requires replacing. Is this easy to replace?
door interlock is easy to replace.
undo the plastic clamp that holds door gasket to cabinet. peel back in area of door lock. door lock is held by 2 screws on outside. undo these ans lock comes off. there may also be a small diameter hose as well to door lock which take off as well.
reassembly is just the reverse
Jun 30, 2008 | Washing Machines
Zanussi washer drier 1480W door lock
Zanussi's always keep clicking before starting.I don't know what E60 is about,but I take it the machine is working?
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Machne wont start
Hi. Dangerus to by-pass on off switch. Re check wires to make sure they are not burnt out, check wires to door lock for burn out, could be lock needs replacing.
Slim jim
Nov 08, 2007 | Zanussi FJS1225W Front Load Washer
DOOR WONT OPEN
I'm afraid I don't have a solution, just the same problem. Exactly this has just happened to me and I don't know what to do. Calling out an engineer will be too expensive and in the mean time, I can't do any washing. Have you had any success yet?
Jun 30, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
209 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
