GPSmap 176 not communicating with laptop via serial/USB adaptor
Hello Team,
GPS communicates via supplied 4 pin/ serial cable in old model laptop. New laptop only has USB ports. Bought a serial-to-USB adaptor cable however am unable to get communication. When I plug the USB in I get the sound signal that a device is connected.
If I try to upload/ download waypoints an error tells me there is no communication.
Hoping you can help.
  • Peter Rob Feb 09, 2009
    Thanks for the help Niraj,
    However I posted back in November 2008 and turned elsewhere and received a solution to my problem after not receiving any response from here.
  • 183 Answers
Sounds you do not have appropriate usb driver so find download and install usb driver from following website:
chose your compute product to make sure about USB driver.
Posted on Feb 09, 2009
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
Where do I find a 6 pin serial to usb adapter for the Garmin 421s? I can't find one anywhere on line. Does Garmin sell one? It's Saturday and Garmin's help center is closed. Their on line...
The 6 pin DIN plug found on the GPSMAP 421s data/power cable (Garmin part number 010-10918-00) is used for the sonar input.
Data transfer from the GPSMAP 421s is easily transferred by memory card.
Information about data transfer on the 421s is at about 50 seconds into this video.
Real time NMEA data can be transferred using Garmin part number 010-10918-00 wired to a DB-9 serial connector (Instructions are on the cable).
It then can be adapted to USB using a serial to USB adapter.
Sep 17, 2011 | Garmin 421S GPS Receiver
Need software to connect GP31 via serial to USB cable to W7 PC
Make sure you installed the driver for the serial to USB adaptor cable.
Jun 30, 2010 | Furuno GP31 GPS Receiver
I cant uploaud waypoints to gpsmap 76csx
Try reloading the software, then load the program, then attach the GPS.... Should start communicating at this point. Make sure the cable is seated correctly....
Feb 14, 2010 | Garmin GPSMAP 76CSx Handheld GPS GPS...
Hi fire1961,
Downloading data from my FURUNO GP-30 gave me no problems. But it took me long time to figure out why I coudn't upload waypoints and routes to the GP-30 via the serial port in my ThinkPad T30.
I tried nearly everything tested the cable, tested a lot of different software and even wrote a little c-program to communicate with the serial port. I also tried a serial-to-usb converter with no results. Then I stumbled over this RS232 Tutorial. According to this - serial ports are not just serial port but can be divided into three general categories:
The types of driver ICs used in serial ports can be divided into three general categories:
* Drivers which require plus (+) and minus (-) voltage power supplies such as the 1488 series of interface integrated circuits. (Most desktop and tower PCs use this type of driver.)
* Low power drivers which require one +5 volt power supply. This type of driver has an internal charge pump for voltage conversion. (Many industrial microprocessor controls use this type of driver.)
* Low voltage (3.3 v) and low power drivers which meet the EIA-562 Standard. (Used on notebooks and laptops.)
Then I installed the waypoint upload software to my ten years old Compaq Presario and suddenly I could upload routes and waypoints but only via the on board serial port. The serial-to-usb converter didn't still work.
So if people experience no result trying to upload data to these old GP-30's from their notebooks and laptops. Then I think it could be a matter of these Low voltage ports not are able to provide the FURUNO device with enough voltage. See the above RS232 Tutorial.
Best Regards
Lars Erting
Aug 03, 2008 | Furuno GP31 GPS Receiver
Hooking up my garmin 168
I bought a usb to serial cable from Radio Shack.
Mar 29, 2008 | Garmin GPSMAP 168 Sounder GPS Receiver
Trouble connecting to any computer
Make sure your using a USB cable, specifically a USB cable with a mini connector on the end. Specifically, a USB cable with the second one from the left in this picture:
If you are using the USB port, you should have no need for setting COM ports.
Another technique you can use (which I just figured out today) was to place the Garmin Unit in "USB Mass Storage Mode". This allows you to offload saved tracks, but I don't think you can download waypoints or other things that the WayPoint Manager allows.
You can access this option via the Garmin Unit
Goto: "Main Menu" -> "Setup" -> "Interface". Press Down to get to the button "USB Mass Storage". Plug in that USB Mini cord, and you have a thumb drive!
Good Luck!
Oct 14, 2007 | Garmin GPSMAP 60CS GPS Receiver
Belkin USB/adaptor
Google Franson GPS GATE this little software utility is what you need
Mar 31, 2007 | Belkin USB/Serial Portable Adapter...
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
