Question about GE Kitchen Ranges
I'm trying to schedule a service call on my new Cafe convection stove, Model #C2S980SEM1SS, Serial #MR206170P, that we bought at Home Depot. (I cannot find the right website or phone number.) We received it 8/25/08 and just used the convection oven. The fan clanks when it starts and stops, then after awhile, it starts clanking continuously. Sounds like it's hitting something as it rotates. Also, we bought a microwave/sensor convection oven, Model# PEB1590SM1SS, Serial# M4900044K from Home Depot, which was delivered at the same time. The oven is built in under the counter as designed by the Home Depot with the assistance of Steve Nacca, their appliance person, store #6687. We used the convection part the other day, and noticed that the butter on the counter above was melting. We felt the counter and it was extremely hot to the touch. We have talked to Steve Nacca and he showed us in his GE Appliance book that it is shown to be built in with a trim kit surround which would not allow for any ventilation. (We haven't installed a trim kit yet, so there is a one to two finger gap surrounding it.) He said he had never heard of one getting hot. He talked with the GE rep yesterday and was told by the rep that he had never heard of the problem, either. Steve said the rep was going to call GE first thing this morning and call him at 10 AM when he came to work. We have heard nothing yet. We don't want to use the convection part for fear of damaging our new cabinets, and for fear of fire. We are also very concerned that should we not be able to use it, we cannot find another microwave that vents to the front and would fit in the space which is 16"Hx24"Wx24"D. All the ones I've seen require a larger cutout. Their is also the fact that we spent about $500 for this unit which we love, but may not be able to use. We hope these problems can be resolved ASAP. Thank you, Oscar Matherly (661) 822-0413
MicrowaveSvc
  • 9086 Answers
SOURCE: Sensor touch to microwave oven
Sounds like a bad keypad.
For parts see: https://www.mcappliance.com/orderparts.aspx
For support help:
http://www.mcappliance.com/contactus/contactus.asp
Posted on Nov 18, 2007
SOURCE: Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Posted on Nov 21, 2007
  • 833 Answers
SOURCE: gap between cabinet and top of microwave oven
eastlake...only if you think so. Most of these units use a submounting bracket set and then you hook your oven to it. This is a rather nasty installation...I've done several. If it's sturdy, you may just want to put in a filler piece.
Posted on Dec 13, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: KitchenAid Superba combination built-in oven
It sounds like a stuck relay or other controller problem.
I don't have the service data on this one, but there should be a schematic or tech sheet / mini-manual either on the back side, behind the controls, or somewhere else inside.
If you or someone you know can locate them and scan and e-mail or copy & fax them to me, I can probably give you further guidance.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 23, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: GE Microwave vent fan replacement
(I'm assuming you're talking about the hood / vent / exhaust fan instead of the internal magnetron cooling fan).
The part # SMV-260UA-C will not be enough to go on, as there at least 3 variations on that number shown at Samsung parts.
These microwaves are made by Samsung, but you'd need the GE part number to replace the whole thing. They don't sell the blades separately.
The part # for the "ventilation motor" is WB26X10042 and you can find it for $97.11 here, which is about fifty dollars less than direct from GE.
I may have available a replacement flan blade off a used unit. If you'll send me the dimensions, I'll check. I need the length of the fan blade, the diameter, and the inside diameter / shaft size, and whether the shaft is round or "D" shaped.
prototech@usa.net
Posted on Jul 28, 2008
Are gas stove elements expensive to repair?
No, they pull right out and can be found at home depot or Lowes
Dec 25, 2014 | Kitchen Ranges
Eaton viking imperial electric,stove oven door will not close completelty; circa 1996. are replacement hinges still availible?
To the owner of the Eaton Viking stove RS3028W-1, yes you CAN get replacement hinges!
I too, have this stove model (circa 1996) with exactly the same problem and I have spent the past 18 months looking for replacement oven hinges. I was very frustrated at the thought of having to throw out a stove that cooks and bakes wonderfully and has not needed any repairs till now and having to buy one of the new subpar ones that constantly need repairs. Plus you can't do canning on the new stoves and the few remaining coil models are extremely poorly made.
I have found 2 places that carry the hinges.
1. Reliable Parts, 1-800-663-6060. This company is located in Montrea (St. Leonard), Quebec.
2. Appliance Shark, 1-800-663-1176. This company is located in Barrie, Ontario.
The part number for the hinge is: 318-024-741
I hope this is helpful, and may you have many more years of happy cooking on this great stove.
Sep 17, 2014 | Eaton Computers & Internet
Is there a recall for ryobi 18v charger or batteries
I had similar problems with my 18V Ryobi batteries. Called Ryobi customer service, gave them the serial numbers and was told there was a 2 year warranty on them, in my case the warranty was in effect until July 2012. Took the batteries to Home Depot today and they replaced my batteries with two brand new ones. I can't complain about Ryobi customer service
Jan 07, 2011 | Ryobi 18volt 12" Cordless Drill Model P206
We have an old electric kitchen kenmore stove that was just given to us. Unfortunately it does not have a cord/plug in to go with it. Where can we get one? model #911 7368010 serial # 0c61844
Hi. This is a common item. Go to any appliance store or home depot or lowes.
You can also order one on line from searspartsdirect.com
Joe
4 thumbs up please. ty
Nov 04, 2010 | Kenmore Kitchen Ranges
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool electric stove
The ideal thing to do, would to be to replace the elements themselves. Most heating elements for stoves are universal and can be bought at lowes stores. I found your model number specific burner elements on a supply website for 42.00 each on the 8 inch and 35.95 each on the 6 inch elements. I am almost certain, you'll find these parts at lowes or home depot much cheaper. If this doesn't help, let me know, we will try another route.
Apr 15, 2008 | Ovens
Electric stove
Could you be more specific? You mean (I assume) you bought a stove and can't connect it to the wall?  That would be because they don't come with a cord.  You buy it separately... I work in a Home depot.. we carry them.
Mar 08, 2008 | Ovens
Kenmore Convection STove - All Oven elements non-fonctional
is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
Dec 10, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
