Question about Sony Playstation 3 (PS3) Console
PS3 will not power up or eject disc
Main switch in back will cause red light to come on, however pushing or holding front start panel icon only allows the system to engage for a few seconds then the green light changes back to flashing red.
  • fredit24 Nov 12, 2008
    Just bought an hour ago and tried to hook it up several times to a few different tv's, and I still get the same response... when you turn flip the power switch on in the back of the PS3 the red light stays on, but when you try to power it up the light goes from yellow to green for a few seconds then begins to flash red. It sounded like the fan was kicking in before it shut off though.We have the PS3 clear from any obstructions, its not hot(since we havn't even powered it up yet). It won't take a cd either. You pay this kind of money for it and it won't even work! WTF
Hard drive, Remove the small panel on the side that says hddemove the small blue screw, pull out by hinged c-clip and reinsert, it sometimes becomes loose, if this does not solve the problem, go to your local electronics store, fry's, best buy, etc and get just about any SATA 2.5" 5400 or 7200rpm laptop hard drive, Western Digital are the best. Take it home, remove the hard drive as desribed above only also remove the four small screws as well, swap the hard drives, reinstall. When you turn it back on it will ask you to format the hard drive, select yes, if it does not go to this screen on its own you can forcibly get it there by plugging in a controller and pressing the ps button so that it syncs and hold select and start for 5 seconds, a screen will appear to reformat the hard drive. This is your problem, good luck, it may sound hard, but I literally showed my five year old do it and she helps me all the time.
Posted on Dec 31, 2008
    Scholar:
  • 120 Answers
Sdkoukal, Sounds like it is overheating or a connection issue, your probebly going to have ot call sony and see what they say.  If this doesn't answer your problem please post again.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
My ps3 wheni go to turn it on n press the button the lite goesfrm green rite back to red n wont turn on
This fix works for some models, so if it does not work for you please tell me your model number
Look at the bottom. This is what it looks like:
SONY
PLAYSTATION 3
CECH-*** = Your model number
SONY COMPUTER ENTERTAINMENT INC.
MADE IN XXXXX
You can do this fan test.
Turn the main switch off, hold the eject button.
While holding the eject button, turn the main switch on, when the power light is green, release it, it will beep
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and blink a red light.
When this happens, turn the main switch off and on then turn it on normally.
Let me know how this goes!!
P.S. It will not harm your ps3, It's testing the cooling fan.
Nov 28, 2011 | Sony Playstation 3 (PS3) Console
Red light blinks and wont stay on when push power button
While holding the eject button, turn the main switch on, when the power light is green, release it and you should hear a beep.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and the red light will blink. When this happens, turn the main switch off and on then turn it on normally.
Tell me how this goes!!
May 05, 2011 | Sony Playstation 3 (PS3) Console
My PS3 80Gb shows the red standby light as normal. When I push the power button, I hear one beep, as the light go from red, to green, to off, and then finally back to red again. If I push the eject button...
Does the lights blink red? If so, You have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself as some would suggest.You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED*
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not backwards compatible, any non 60g or 80g then you can retrieve your disc.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
You will have to have the system repaired so that you can eject the disc the normal way. If the technician cannot repair your system, simply ask him to remove your disc.
Feb 03, 2011 | Sony PlayStation® 3 (80GB) Console
Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Nov 23, 2010 | Sony Playstation 3 (PS3) Console
The game cd cannot be ejected from the PS3. When the eject button is pressed the red light keeps blinking.
Try the following solution.
Turn the PS3 off with the main switch on the back.
Turn the PS3 back on into standby (red light on)
While holding the eject button press the power button on the front of the PS3. This should initialize a forced disc eject.
Hope this helps and thank you for using FixYa
Aug 19, 2010 | Sony Playstation 3 (PS3) Console
My game is stuck in my ps3
This is quite a common problem on the PS3. Try the following steps:
Step 1. Turn the PS3 right off with the switch on the back
Step 2. Turn the PS3 on so it is in standby mode (red light on)
Step 3. While holding the disc eject button press the power button on the front of the console.
This should force the disc to eject and all should be ok again.
If this does not work post a reply here and I will assist you some more.
Thank you for using FixYa
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
My ps3 has the yellow light. How do i retrieve the game stuck inside
Hi, i'm sorry you've got the YLOD issue :( to get the disc out you may try this:
- turn off the ps3 with the main switch, behind the console - press the EJECT touch-key on the front, HOLD on it while you turn on the console with the main switch... keep holding the eject key, if it'll work you'll get your disc out. If it won't work just try a couple of times more.
Other than that, the only thig to do is to get in touch with Sony technical support, but anyways don't worry you'll have your disc back.
Regards, Peter
Aug 10, 2010 | Sony Playstation 3 (PS3) Console
Disc will not eject
Disc stuck is not a big issue. Don't waste money to find someone to fix it yet! It may be a minor issue that you can be fixed by yourself.
Remember, you are not the only one to suffer this problem! Because I had help so many people to fix the same problem now. You are so lucky to be there. I share a guide for you - It make me like a pro to help my friends and many people. It is too expensive to send back to Sony repair if your machine is out of warranty!
I had solved the same problems after bought this guide. The author of the book is really kind and helpful to his customers. May be you can buy it and share what you have learned !
PS3 Repair Guide
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
My PS3 wont turn on it just flashes a yellow light then red light that beeps cant get disc out
I found a way to eject the disk:
  1. Power off the PS3 on the main switch on the back of the console
  2. Press and hold the Eject button
  3. Turn on the main power switch
  4. The PS3 LED will go green and the fan will spin at max speed
  5. Wait a few seconds and press the eject button a couple of times, the disk should now eject
  6. watch the PS3 die after 30s or so…
This procedure did not fix my PS3 but at least I got my disk back before sending it to Sony for repair.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
Ps3 won't turn on red light flashs on and off
i get same problem, this should work:
turn the main switch off at the back, then hold the eject button then turn on the switch while still holding the eject button. fan should go at max speed then it should die down after 20 secs.
didnt work for me but it should for you.
May 01, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
93 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
