Question about Panasonic Pro NE1757 Microwave Oven
Keypad problem I am having problems with my key pad. When we first recieved the unit it would go in incrinits of ten from 1-0 now 1,2, and3 don't work. When you push them it says A1,A2, andA3 what would the problem be and how can you fix it?
  • Panasonic Master
  • 9,098 Answers
You have a defective membrane keypad, but both that part and its replacement is shown as being no longer available. About your only hope is to contact local shops to see if they may have a salvage unit with a good keypad. They should be able to swap what's called the "escutcheon" or front panel frame. The keypad for models NE1057 and NE1257 was the same, too, in case they may have one of those. These were pretty neat microwaves, mostly used in commercial environments. Sad to see it go. Good luck.
Posted on Nov 11, 2006
Kenmore microwave 721 keypad buttons does not work.
The key pad or the system Bord is faulty. You have replace the keypad unit first.
If you wish to get any more detailsthen check the bellow added link.
www.electro-medical.blogspot.com
Jun 29, 2016 | Kenmore Microwave Ovens
Key pad flashing se . key pad locked pease tell me what to do iam a disabled lady need help please
"SE" error means you have a shorted membrane keypad.
You would need to have either the membrane keypad itself replaced, or the control panel frame assembly which comes with a new keypad, or the whole controller.
Part numbers and prices will of course depend on the model number.
Dec 27, 2012 | Samsung Microwave Ovens
Ge microwave oven key pad short circuited JVM 1540
see the next steps. God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 03, 2012 | GE JVM1850 1000 Watts Microwave Oven
Keypad don't light up
see this causes and fix it. God bless you
Lights come on, but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
Sep 25, 2012 | Maytag MMV4205 Microwave Oven
I have GE microwave oven model JVM1740DM1WW-1000W. the key pad 1 to 6 on express is not working. all other key pad works. how to troubleshoot this problem?
you can try removing the outer cover and being careful,check all ribbon cables to the keypad by removing if they are plugged in and not soldered to the keypad circuit board and re plugging them back in,if this doesnt solve the problem you will need to replace the keypad board
Aug 07, 2011 | GE Spacemaker JVM1740 Microwave Oven
I touch the touch pad and nothing happens
Hi!!
Try unplugging unit from the wall outlet for 5 min. If the key pad still do not respond, it may have become defective they are not fixable. Replacing the key pad it is often more expensive then buying a new unit.
Spills and directly spraying cleaner solutions into keypad will eventually cause it to fail.
The correct way to clean the front of your microwave is to apply a small amount of the cleaner solution to a cleaning cloth and then wipe the keypad clean
Show your appreciation with a 4 THUMBS Rating for answering your FREE question. Thank you for using FixYa
Oct 03, 2010 | Samsung MT1088SB 1000 Watts Convection /...
Keypad does not always work
HI. you will need to replace this malfunctioning key pad asap. this will require you to disassemble the unit, in order to reach the actual touch pad board. It is not an easy task, and i recommend a professional tech, if possible.
Aug 26, 2009 | Maytag MMC5000 Microwave Oven
Key Pad only works on some numbers. Others do not respond when pushed
Unplug the unit. Generally, remove the screws inside the door that hold on the faceplate. Inside, it will become rather obvious how to detach the keypad from the main circuit board. Note that some of the screws are longer than others. Carefully unplug the wire loom from the board. Note that these plugs have a small movable section. Flush to the board is lock...up is unlocked. Make sure when you push the loom in that the section is up...then push it down. By the way...before you buy a new part, unplug each connection related to the key panel and reinstall. It may just fix it.
Dec 19, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp Carousel Convection Oven. Model R-9H54.touch pad
It depends on what you mean by "a problem with the touch pad assembly".
If some or all keys do not respond, you would probably need a new keypad, but the key units for all Sharp R-9H-series models have been unavailable for a few years now.
These units did indeed last a long time.
Sorry I can't bring better news.
Dec 06, 2007 | Sharp R-370E 1000 Watts Microwave Oven
Panasonic Pro NE1757 Microwave Oven Logo
108 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
