Question about Sharp (BQCXGC50X1) Projector Lamp for PG-C45X, PG-C45S, XG-C50
XG-C50 Problem Hi All, I just replaced a Lamp in the Sharp Notevision XG-C50. When I plugged it back in and turned it on it worked fine. That first use I checked the lamp life and it said 84%. I thought it would have said 100% but figured there was some reason it was 84%. When I pressed power on the remote to shut it off, everything went fine. A few hours later I tried turning it back on with the remote. The green light on the bulb replacement light was blinking for about 5 minutes and then went to red. I unplugged the projector and a minute later I tried again and it came up just fine. I checked the lamp life and it was still at 84%. So the lamp doesn't need to get replaced. After turning the power off a few hours later I tried again and it would not turn on just had the red light pop up after 5 minutes. I unplugged it and plugged it back in last night and tested it this morning and it worked fine. Then turned it off, hour later tried to test it and it blinked green then went to red. I shouldn't have to unplug it every time to get it to work. Any ideas? Thanks, - Jim
  • 1 more comment
  • Jim Butler Nov 10, 2006
    I reset the the lamp life to show 100% but it still times out after 5 minutes. Wondering if anyone has any feedback?
  • Jim Butler Nov 14, 2006
    Would love to hear an idea if anyone has one...
  • Anonymous Nov 24, 2007
    same problem as jim with epson projector. lamp does not come on every time, have tried to reinstall and tighten lamp screws, still no luck.
  • 115 Answers
Hello
Replace the fly-eye lens of projector.
Viren
Posted on Jan 21, 2008
  • Virender  Dhiman
    Virender Dhiman Feb 06, 2008
    reset the lamp timer with the details provided in the new lamp box.
Sharp Notevision 6 XG-NV6XU
Perhaps clean the side filter as well as per page E-46 in the manual on following link: http://www.fixya.com/support/t161763-sharp_notevision_6_xg_nv6xu You can find links to email support & FAQ's on this link: http://www.sharpusa.com/products/TypeManuals/0,1083,29,00.html
Jul 28, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Sharp XG-C50X Notevision. Doesn't get past "warming up"
it seems that the powersupply is failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 21, 2009 | Sharp (BQCXGC50X1) Projector Lamp for...
Sharp Xg-50X projector won't turn on. Replacement light not on.
I pulled the projection bulb and did a continuity check on the filiment. It was open. I ordered a new bulb.
Thanks.
Feb 14, 2009 | Sharp Notevision XG-C50X Multimedia...
Looks like the wrong lamp was installed, or the cooling fan is not working. Careful - it may be permanently damaged, as the LCD inside can be hurt by high temperatures.
Sep 05, 2008 | Sharp Notevision XG-NV6XU Multimedia...
XG-C50
pls check the fans under the Optical Engine, under the prism
the fans easy to be failed
Have a nice day!
Jerry
Lampdeng Limited
Sep 04, 2008 | Sharp (BQCXGC50X1) Projector Lamp for...
Sharp notevision XG-MB70X
No special tools needed. these units (dlp projectors) are designed so the lamps and color wheels can be changed out by the user. Some can figure out how to do this easily without instructions but to be safe just do a quick search and find step by step instructions. You can also refer to your owner's manual.
Jul 17, 2008 | Sharp Notevision XG-NV6XU Multimedia...
Sharp XG-P10XU lamp problem
power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
Dec 07, 2007 | Sharp Notevision XG-P10XU Multimedia...
Having problems with my sharp notevision XG-C40XE
Your lamp is not lighting up most likely. Try removing the lamp assembly and clean the contacts. If that does not work then you will probably need to replace the lamp. Also try resetting the timers. Refer to you owner's manual for info on how.
Aug 23, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Sharp Notevision 6 XG-NV6xU
reset the lamp hours on your projector
Sharp (BQCXGC50X1) Projector Lamp for PG-C45X, PG-C45S, XG-C50 Logo
369 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
