Question about Dryers
Whirlpool Dryer WED9200SQ0 Heating Element
How do I replace the heating element in the above mentioned dryer?
Thank you
Earl Lester
  • lesliepking Jan 23, 2009
    My 18 mo. old dryer suddenly overheated and quit working. The heating element, thermostat, and both fuses are blown. It is over $300 to fix the problems. Why did this happen? We had the vent cleaned, but it was not terribly dirty.
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
TheMobilian
  • 8220 Answers
SOURCE: how do you test dryer heating element on GEQ9800LW0
Ok maybe the heating element got old and brittle over time and finally gave up the ghost. But it may not be the element. It could be one of the safety Hi-limits have blown.READ MORE...
Posted on Apr 10, 2009
  • 659 Answers
SOURCE: whirlpool dryer not blowing hot air
The element is at the bottom of the unit. Usually they are located on the right bottom but when you take the housing off, you will be able to see it.
Posted on Apr 11, 2009
  • 351 Answers
SOURCE: Whirlpool Dryer not heating
There is many different things it could be! most of the time it is not the heating element. You have thermal fuses and safety switches. I bet you 10 to 1 if you locate the thermal fuse on the element cannon say 1 foot up from the incoming voltage from the wires to the heating element.
1. either disconnect power to the unit, take continuity on every fuse try the one i suggested first.
2. the same exact fuse im talking about disconnect power and connect both wires together, dont ground it out, plug power back in and then try it.
Note this is only advice and Whirlpool Parts Surplus is not responsible. Try that give us a call or hit that link and find your thermal fuse part number.
Posted on Apr 19, 2009
Whirlpool GEW9200L Electric Dryer won't heat up
The heating element can fail open. Curious that Whirlpool did not mention that possibility.
Jan 25, 2018 | Whirlpool GEW9200L Electric Dryer
Tip
Dryer Running, Will not heat
The Most common problem is a bad thermal fuse.
1 the thermal fuses are located in the cabinet of the dryer under the drum
they can also be located on the front of the blower wheel housing. on the back wall of the dryer or along the heating element can.
2. some kenmore, whirlpool machines have these fuses located in the rear of the machine.especially when the lint filter is located in the top of the dryer.
3. the heating element can also be bad.
4. if you have an ohm meter you can check the continuity of the thermal fuses,as well as the heating element.if there is no continuity on any of the above mentioned parts. Replace the faulty parts.
on Jan 25, 2010 | Dryers
Dryer runs but does not got hot, therefore does not properly dry clothes. I checked the heater element and it is good. Any suggestions?
Jan 10, 2011 | GE WSM2420T Top Load Stacked Washer /...
Not heating
Also check my tip on thermal fuse locations
Jan 09, 2011 | Whirlpool Dryers
My dryer will not produce any heat ? it is only air drying. Is there an element I need to replace or a fuse ?
Jan 08, 2011 | Whirlpool LER4634J Electric Dryer
How do you replace the heat element on a whirlpool LER8648 dryer?
Before replacing the heating element, check first the continuity of the thermal cut-off and the high-limit thermostat located on the heater box, the resistance of the heating element, and the continuity cycling thermostat located on the blower housing. Replace the heating element only when it reads open. Replace both the thermal cut-off and the high-limit thermostat should any one of them is found open. The cycling thermostat must have continuity between its thicker terminals; otherwise, replace it.
All of the above components are accessible through the rear of the dryer. Remove the rear panel by removing the screws securing i to the dryer cabinet. Replace the heating element by removing the screws attaching its housing to the heater box then securing the new heating element housing in place.
May 28, 2010 | Whirlpool Dryers
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Dryer, not heating
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse which is about an inch long is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Click the link to see a happy customer who is satisfied with the above solution http://www.fixya.com/support/t4612401-brand_new_dryer_will_run_tumble_but_no
Thank you
May 24, 2010 | Whirlpool LER4634J Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dryers Logo
449 people viewed this question
Top Dryers Experts
