Question about Whirlpool Dryers
How do u replace heating element in whirlpool elec mod# le7010xs
Can't remove old element. Need instructions on how to remove so that new element can be installed.
  • 60 Answers
There are 2 screws in the top under the lint filter remove them then with a flat head screw driver pop the lid up at the front then you should see the top of the element and there is 1 screw holding it in remove that screw then remove the back panel remove the wires and label them and lift slightly up and slide the element hosing out
Posted on Nov 12, 2008
How to replace bottom heating element in whirlpool mod-GR563LXSB? this is a floor mod electric stove
In most cases you unplug it from the power, take off the back, locate the wires to the element, remove the connectors and retainer nuts, go to the front and remove the element, replace it in reverse order.
Feb 04, 2017 | Whirlpool Kitchen Ranges
I have a built in wall oven whirlpool gold mod.gbs309pvsoo controls turn on but no heat from element
Could be element could be Hi limit thermostat could be control. In that order. First step is turn breaker off and remove element to make sure the wires are still connected to back of element. Visually inspect element very good for burns or a white powder residue signally the element burned up. Next step is harder, need to remove the oven and take off back panel, there you will find the hi temp thermostat. Check for continuity, if none replace.
Feb 02, 2015 | Whirlpool GSC309PVB 30" Built-in Microwave...
My Maytag Mod. DE7500 elec. dryer is no longer heating up. Starts and goes around fine just no heat
On this dryer the element is what fails, the screws are on the lower front that hold front on. You will need an ohm meter to verify unless you pull the element out and visually inspect it.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Maytag Dryers
Need instructions for replacing the heating element
First UNPLUG UNIT remove the 7 or 8 screws securing the back to the dryer,the heating element is on the lower right ride where the wires are going. 2 screws hold the element in position. You will need to transfer the high limit thermostat to the new element, reinstall and reconnect all wiring, reinstall back ...Now enjoy the fact that you fixed it yourself and saved some cash as well... Good luck
Aug 15, 2010 | Whirlpool WED5300S Electric Dryer
Whirlpool elec. Single built in oven...lower element wont heat at all upper gets warm doesnt seem to get real hot. Metered lower element got continuity.metered wires to element nothing... Please help I'm...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 09, 2010 | GE JGBP26 Gas Kitchen Range
New GE Profile dryer DPSE810EG7WT does not work. I wired exactly as old dryer. L1 L2 and neutral. The timer comes on but the machine does nothing! Thanks, Roger
if this is a gas dryer you would only need L1 OR L2.... NOT BOTH PHASES, this unit only needs the one leg of either A 120Volts or B 120Volts phase NOT BOTH PHASES 240 volts A.C. not 240 V.A.C. as in an electrically heated element will require to heat the system, NOW ...be careful now because one hot phase is connected where it shouldn't be!!!!
Apr 26, 2010 | GE DCVH515GF Gas Dryer
Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Dec 12, 2009 | Whirlpool Dryers
Whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Jul 12, 2009 | Whirlpool LER5636P Electric Dryer
Installing a new heating element on my Whirlpool dryer.
shouldnt make a diff, the orange wire can only go in one place,adn the 2 reds make no difference.. the only thing you need to do is remove the thermostat from the oldelemnt and install it on the new heater
Dec 04, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
99 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
