Im trying to connect my living room heater and my bedroom heater to run off the same 240amp breaker my problem is my living room heater stays on all the time but i can control the bedroom heater on and off both heaters have single pole thermostates i have a double pole thermostate but not sure how to wire these heaters so they both turn on and off independently i hope you and help. thanks in advance Earl.
MY BEDROOM HEATER WONT SHUT OFF
FIRST YOU MUST DASIEY CHAIN THE 12-2 FROM THE PANEL TO FIRST HEATER IN THE LINE AND THEN TO THE SECOND HEATER IN THE LINE, ENDS OF BOTH WIRES IN THE SAME END OF HEATER,BREAK ONE SIDE OF THE LINE THROUGH THE THERMOSTAT AND TO THE ELEMENT OF THE FIRST HEATER AND THE SAME FOR THE SECOND HEATER BUT IN THE FIRST HEATER YOU WIRE IN TH LINE THE 2-BLACK WIRES AND THE 2-WHITE WIRES WILL STAY CONNECTED WITH WIRE NUTS AND YOU WILL CONNECT THE THERMOSTAT WIRING UNDER THESE SAME WIRE NUTS AFTER YOU STRIP THE ENDS OF BOTH WIRES ENTERING AND EXITING THE FIRST HEATER TREAT EACH HEATER AS IF YOU WERE ONLY WIRING ONE HEATER ONLY DIFF 2-BLACK AND 2-WHITE WIRES STRIPED OUT AT FIRST HEATER IN LINE FROM PANEL TO ACCESS AND CONNECT FIRST HEATER ,BB HEAT 250 WATTS PER FT
