Question about HP Color LaserJet 2600n Printer
HP2600n color printing not registering
When I print gray mode all is fine. When I print color the colors are not registering. In other words Magenta Cyan and Yellow are not printing close enough to create a new color by combining properly.
  • jedthe2nd Nov 19, 2008
    Thanks it worked. After oine it was better and I did calibrate a second time and is great.
  • helpforas Dec 02, 2008
    Similar situation (on 2605dn) however the cyan appears to work fine but yellow and magenta do not print properly. I can't get green, orange, yellow, red to print.
    I have tried the calibration multiple times.
    I have turned off, unplugged the power supply, unplugged the connection to the computer.
    I have reset the printer to default settings using the printer menu.
    I have reset the printer preferences (software end) to default settings.
    I replaced the cartridges with aftermarket cartridges first and the problem started but I can't say that the aftermarket cartridges caused the problem because I then replaced the cartridges with HP Brand cartridges and the same problem continues.
  • 32 Answers
Looks like theres a problem with the color ragistration.
I would calibrate the printer. Heres how;
  1. Go to "System Setup" on the display. Press Select.
  2. Go to "Print Quality". Press Select.
  3. Go to "Calibrate Color". Press Select.
  4. Go to "Calibrate Now''. Press Select.
  5. Press Select again to confirm Calibrate Now.
This will calibrate the printer and should eliminate the color registration problem you are having.
Posted on Nov 19, 2008
    Sergeant:
  • HP Expert
  • 224 Answers
Re install soft ware
Posted on Jan 27, 2015
    New Friend:
    Problem Solver:
  • 9 Answers
Some people have had luck getting the unit to calibrate by removing toner cartridges, and blowing out the toner trays and wherever else you can reach with compressed air. I personally suspect it is removal and reinsertion of the cartridges, but the blowing out will cover all the bases.
Luck
Posted on Nov 21, 2014
I have a Konica C250 machine which cannot print red color at all. I had changed the toner and image unit but still cannot print red color. How can I solve this problem?
Recommended that you have a tech come out and look at it might have a bad LED assy. for the Magenta Image unit. All other color print OK? Can you print gradation test pattern for each color in service mode? Meter count, details, stop 00 stop 01 Test Output Gradation pattern select magenta. If you open the side cover after printing a document with the color magenta try to catch a print of paper do you see the color magenta on the transfer belt if yes the drum is ok could be the transfer belt magenta 1st transfer roller on the belt replace the belt assy.
Oct 28, 2015 | Konica Minolta BizHub C252
Gray color prints as brown using Photoshop CS6
check your image mode.. click image, then mode, then cmyk color.
Sep 23, 2017 | Epson Stylus Office T1100
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
How do print black only on a HP C3100
maybe you just need to check the "grayscale printing" option in the printer menu..
May 27, 2009 | HP Office Equipment & Supplies
Printed gray looks pink
maybe the print heads need cleaning?
Jan 27, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP Color LaserJet 2600n Printer Logo
494 people viewed this question
Ben Johnson
