Question about Refrigerators
GE TFX 22CR Freezer works but not Refrigerator.
My freezer is fine (ice is frozen) but the refrigerator is not cold as it should be (milk is clumpy) I've already vacuumed all dust and looked behind the panel inside at the top. I found that the refrigerator either has no fan or the fan is not working. The only cold air is coming from the freezer side, through the channel. Do I need to remove the entire panel to find a bad fan behind it? What should I be doing to fix this? Thank you.
  • Chuck Middaugh
    Chuck Middaugh Nov 12, 2008
    Ok, I have now removed the tall panel at the back of the freezer and found that the coils are covered with ice. I will get the hair dryer and begin to melt the ice away. If there is a fan back under the ice I'm sure it's not turning.
    There is certainly a a fan at the top of the freezer and I can feel the air moving and I can hear the fan, but the ice I mentioned above would be midway down if it exists.
    Any advice to proceed? Thank you.
  • Chuck Middaugh
    Chuck Middaugh Nov 13, 2008
    I removed the inside back panel of the freezer and used a hair dryer to melt the frost/ice. Everything is good now. The refrigerator is cooling as expected and the freezer is working as well. I imagine that the defroster had failed. It is likely a matter of time before it happens again and that will tell me that the defrost system is not working. How complicated is it to replace?
    Thanks again. (I've rated this thread as fixed even though I believe it is only a matter of time before it needs the defrost system replaced or repaired)
  • 66 Answers
If the evaporator fan isn`t working, the frig will not circulate the cold air needed from the freezer to the fresh food compartment. You will need to remove the panel and check for ice around the fan. Make sure it can turn free. If it isn`t blocked and you can turn it freely and there is voltage going to it, the fan motor has gone bad and needs to be replaced if there.
Posted on Nov 11, 2008
  • Charles Caldwell Nov 12, 2008
    Ok, you have determined that the fan is working. Is the evaperator coil covered with ice or frost biuldup. The deferance would be a deferant problem. If it is ice then I would assume the defrost system is working. The ice was formed when the defrost heater melted the frost off of the evaporator and turned into water that should be leaving the freezer through a drain under the evaporator. If this drain is blocked the water will not drain and then turn into ice when the freezer turns back on. If the evaporator is full of frost ( this is distinctly differant than ice), then I would think that the defrost system is not working. The problem can be one or a combination of three things. The defrost heater, Defrost limit or the defrost timer.Determine if it is ice or frost and then we can proceed with determining the problem.
  • Charles Caldwell Nov 14, 2008
    Depending on what has failed. It can be fairly easy. If the defrost limt has failed then it is a mater of cutting two wire and removing the old one, then replacing with a good one with wire nuts and clipping it back in place. The defrost heater is a little more defacult. You must remove one, two and sometimes even three heaters from a evaporator coil ( they will be at various points on the evaporator). Your may only have one. In installing a new one you must be carefull. They come with specific instrutions in the box. Make sure you read this, The defrost timer, if bad, can be positioned in many deferent places in or on the frig. Checking it first would be a good idea since these can be expensive. These are pretty strait forword on removal and replacement. If you decide that the defrost system is the problem, Let me know and I will help you.
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
Westinghouse RJ275M 194l fridge with top 81l freezer doesn't keep the fridge cold anymore. Freezer is fine. is it the thermostat?
If the upper compartment, the freezer part is open on the ends and the rest of the refrigerator is cold enough, that can't be fixed. If the the box is closed on the ends seperate, check the flow control of air if it has one, check the thermostat and set it till things nearly freeze in the lower non frozen section. If all this doesn't work and you can't keep the ice cream turning to milk, gotta get a new refrigerator.
Nov 25, 2010 | Westinghouse Refrigerators
GE Profile Performance: Fridge rose in temp to the point where milk is spoiling. Now Freezer is going up in temp as well. Ice is melting and food is no longer frozen. Ice forming on the back wall of...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Oct 30, 2010 | GE Profile Performance 25.2 cu. ft....
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Freezer not freezing ice cream and milk
Icecream is a tough call. Some brands have to many artaficial ingredients and that doesnt get solid. What temps are you getting in the freezer? Is everything else frozen solid?
Jul 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
Dec 27, 2008 | GE Refrigerators
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator not cold enough, again!
I emptied the freezer, unscrewed the freezer floor, pushed it out of the way, and saw the ice, just like last time. So I poured hot water over the ice, made sure the ice was all melted, even from below (under refrigerator), and put the floor back in - works fine, for now!
Jul 13, 2008 | GE PTC22MB Top Freezer Refrigerator
Refrigerators Logo
850 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
