Two computers can't get internet off a Linksys EG008W 8 port gigabit switch, while another gets it easy. I can't figure out why the damn thing reads their connection but doesn't return any internet. Assistance?
    Problem Solver:
  • 13 Answers
Hi man7,
There are a number of possibilities the most common solution to your problem is as below.
Are you getting a valid DHCP address, correct gateway details and DNS. Seeing as you have PC that already works this makes it simple.
Before we go any further what operating system are you using and what type of router are you using to connect to the internet?
CptHaddock
Posted on Nov 11, 2008
    Genius:
  • 1,913 Answers
Chec kfirewallalso check ip adreses of working internet pc.then chec kboth use same gayeway .
We have a Linksys SRW2048 48-Port Gigabit Ethernet Switch. The problem is, that we can't get a connection on the 8 ports on the very right side. What could be the problem, how can we solve it?
Disconnect all the Ethernet cables from all the ports.
Connect one of those eight "bad" ports to your laptop.
See if the port works when it is the ONLY active port.
If not, move the cable to the next of the eight "bad" ports, and test again. Repeat.
Move the cable to one of the 40 "good" ports, and test.
If it works, then you have a hardware problem with that "group" of 8 ports.
Your choice to use only the 40 "good" ports, or to replace the router, if you need those last 8 ports.
Jul 11, 2011 | Linksys SRW2048 48-Port Gigabit Ethernet...
Linksys SRW2008P 8-Port Gigabit Ethernet Switch Currently two of the ports do not work, can anyone help?
Not much you can do when you have dead ports on a switch but just to replace the whole switch. The cost of having someone take it apart and repair/replace the dead ports will probably cost more than a new switch.
Mar 09, 2011 | Linksys SRW2008P 8-Port Gigabit Ethernet...
Linksys SRW2008 blocking ports
blocking ports and QoS is a layer 3 function, switches are layer 2 unless you buy a layer two switch. You will need to do this on your router.
Mar 31, 2010 | Linksys SRW2008 8-Port Gigabit Ethernet...
How to reset settings of linksys srw2008p 8 port switch.
hmm.. router? try to check the router if it has an reset switch then press it with in 5-10 seconds...
Feb 04, 2009 | Linksys SRW2008P 8-Port Gigabit Ethernet...
Switching from Linksys 5 port switch to Netgear 8 Port Gigabit
Kindly check the Gateway used in the computer where internet is working.....
to find gateway follow this
start menu >>> RUN>> CMD>>>> Ipconfig
then configure this gateway in all other systems and ask for DNS from you isp as well..to provide DNS manulay.
If still dont work ...
tell me the all information you get by useing ipconfig command in the PC where internet is working.
like IP address
Gateway
DNS
i will make you a map to follow.
best regards,
Dec 02, 2008 | NetGear ProSafe GS108 8-Port Gigabit...
SD 2008 linksys switch slow
"Uninstall and Reinstall the Switch."
it's an umanaged switch - there is no install - powering off doesn't help
Oct 29, 2008 | Linksys SD2008 10/100/1000 Gigabit Switch...
Won't allow connection to router
Since each of these devices is rated for 1000Mb/s, everything should be compatible. Make sure the NIC driver is up-to-date on your computer....and use automatic settings for speed and duplex wherever you have the option of setting it. The only other thing I can think of is to try a "crossover" cable between the router and switch...although this function is usually handled automatically in most modern interfaces.
Jan 05, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Help me with this linksys product
You may not be able to do MAC Filter in SRW2008. but you can do Static MAC address on the device which allows the computers in Static MAC table can connect it in your switch.
Hope this may help you !
Oct 17, 2007 | Linksys SRW2008 8-Port Gigabit Ethernet...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
