Question about Kenmore 43042 Front Load Washer
Won't spin clothes dry... possibly bad wiring??
I started a load around noon and when I came home (hours later around 6pm) the machine was making noise like it was still spinning, but when I looked in, the drum was just sitting there and the clothes were soaking wet. It would tumble the clothes left to right a few times, but when it was supposed to spin real fast it just sat there and made noise and never stopped. My husband took off the back panel and spun the drum and moved the wires. We decided it was the wires since it worked when he?d hold them down. He unplugged them to see if they were dirty or not connected right and when he plugged them back in it wouldn't spin again. As far as the wiring goes, what do we check first? Or do we just need all new wiring (is that something easier to just buy all new of, like a kit sort of thing) and how much would than run us?
  • 3 more comments
  • Candice Charlson Nov 09, 2006
    Also, someone else mentioned a rest button... could that possibly be something to try - if so, where do I find that on the machine?
  • Candice Charlson Nov 10, 2006
    It is not 417, it's 026. It spun fast when he would push in 2 plug the wires were in, so he pulled them out and put them back in and then it wouldn't go. Would that still be a draining issue? I saw a black container looking thing connected to the hose, is that were a clog might be, or is it more likely to be further up in the hose before that or after?
    Removing the drain boot - do I do that from the front or back of the machine? I'm assuming it's easier from the front because it's closer. (that's the view in this picture) There's a screw and a few green wire clips... what do I need to take off to remove it?
  • Candice Charlson Nov 11, 2006
    We found a drill bit on the bottom of the boot, nothing real dirty or anything that would cause a clog, we flushed the hose and nothing was in that, but when we put it all back together it worked fine. I've done 3 loads and it's been alright.
  • ralajabr Aug 24, 2008
    washer spin when washing after it drains it don't spin
Perfect timing for the above problem and solution. My front loading Kenmore model 417.4104200 would, during the final spin time, tumble in one direction a few times then stop and reverse tumble and repeat the cycle until the cycle completed. There would be no abnormal sounds during this time. The drum would not spin at either normal or high speed. The one sentence in the comments from 'catriver' that saved me was, "This model will not go into high spin if the pressure switch detects there is water in the tub." Sure enough there was still very wet towels in the tub. I checked the water pump and found a paper clip which was preventing the pump from pulling the water from the tub. Once the clip was removed, the spin function began performing fine. If I were to do this again, I would try to avoid removing the rubber bellows. It turned out fairly difficult to re-install after I removed and cleaned it. Replacing the clamps without the correct tool was the problem. It looks like the pump can be removed and cleaned out with the bellows still attached.
Posted on Dec 02, 2006
    President:
  • 878 Answers
Casa, make sure your model number starts with 417.43042 otherwise this post is trash. First have your husband drop the bottom panel and check the drain pump for debris, coins, etc. This model will not go into high spin if the pressure switch detects there is water in the tub. There was also a service flash out on this model regarding the timer not advancing. This had to do with electrical noise generated by the opening and closing of the timer contacts. This sent corrupt signals to the motor controller and the washer would stall in cycle. They corrected this problem by adding 3 jumpers to the motor controller. Part 134306000. My feeling is that you have a pump drain issue, but it's hard to tell without being there....Catriver...post back.
Posted on Nov 10, 2006
  • Ron Marek
    Ron Marek Nov 10, 2006
    Casa, good pictures, the board is the motor control board. I would still remove the drain boot from the pump and see if there is anything in the impeller or boot itself...Catriver...post back.
    Problem Solver:
I have this very issue on the final spin of the regular wash cycle. Tub will not go into high speed spin because there is water in the tub. Select a different cycle and no problem pumping and spinning. Why is my washer not high speed spinning on the regular wash cycle but it will on the other 2 cycles?
Posted on Nov 29, 2009
On my ge front load dryer the start button is broken i just washed a load of laundry is there a way to turn it on with out the start button so i can dry this load of wet clothes? The model # is...
the start button is part of the control assembly.
the assembly is probably bad.
here's the part if you are interested...
http://www.appliancepartspros.com/ge-cntrl-pnl-asm-we19m1656-ap4980791.html
have you tried unplugging it for a minute then plugging back in to see if resets the panel?
Feb 03, 2018 | GE Washing Machines
I dry clothes then put another load in and it won`t do anything i have to wait awhile to start. What could be the problem?
sounds like a bad motor windings problem. Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Mar 22, 2015 | Washing Machines
Why does my washer do every thing but spin dry could a pressure swicth be bad on door?
Good Afternoon Dale,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000ES, not spinning your clothes dry. First, if the drum is not spinning at all, I suggest resetting your appliance by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored run a spin only cycle. If it starts spinning and the clothes are still coming out damp, try one of the following:
    1)Try changing the spin speed to a higher speed.
    2)Make sure that you have not overloaded your washer.
    3)Make sure that the wash load is not too small. If you are only washing a couple of items, try adding 1 or 2 similar items to balance the load.
    4)Try rearranging the load to allow proper spinning.
    5)Check the drain hose for any kinks. If it is kinked, straighten it.
    If you are still having trouble with your washer spin drying, I suggest contacting your local authorized technician. Hope this helps.
    -Best Regards-
    WP
May 01, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Washer not spinning properly
This should be belt driven? I would imagine jut adjusting the tensionwould work.
Dec 02, 2013 | Roper RAS8445KQ Top Load Washer
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Washer would spin dry but the clothes is still wet
Sounds like your transmission is starting to go bad. It is not creating enough power to spin fast enough to dry the clothes. A new transmission is going to run about 400 I would start shopping for new machines. Do light loads of laundry til you get a new washer..
Jul 14, 2011 | Whirlpool Washing Machines
I have an indesit widxl146 washer drier and the machine takes an age to dry clothes, 9 hours as oppose to 2 hours when new
9 Hours!!! I hope it isn't because the clothes are too wet because if it is I wouldn't like your electricity bill!!
There are a number of things you need to check.
I assume that you are not overloading the machine, and that you are using the correct spin cycle
Don't start the drying cycle directly after the wash, take out the clothes and see how dry they are after the wash, you need to ascertain if it is spinning the load sufficiently fast to dry them. How dry are they directly after the spin? If they are not wetter than they should be then the dryer is not getting hot enough during the drying cycle, this could be due to a faulty thermostat or element.
Make sure all the filters are clean including the pre chamber down below so that it can pump out the water (I guess it must be clear if it is washing ok? but check anyway.
The principal parts involved, assuming that
Also check that you haven't got a delay set for the dryer (unlikely I know but I thought I would mention it anyway)
I hope that helps.
Jan 26, 2011 | Indesit Dryers
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Fisher & Paykel GWL10 US won't spin
its possible that the pump is either going bad or there is somethin gin the pumps/sump assy. on this model the unit generally tends to shut down when the pump overheats, and will only restart when the pump cools off, a warnig obout replaing hte pump if need be is the pump is actually 220v. you MUST UNPLUG MACHINE BEFORE SERVICING. its a foriegn brand remember so theres abuncha wierd wiring and the pump is one of them!
Mar 25, 2008 | Fisher and Paykel IWL12 Top Load Washer
Spin Option
The problems posted by kim875 and kirsty2 all seem to be the result of faulty signals from the electronic board. This seems to be a real problem with this model machine. I would try to get board replaced under warranty , if at all possible.
Dec 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 43042 Front Load Washer Logo
646 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
