Question about Tomtom ONE GPS Receiver
No sound in tomtom
I have a tomtom one ,was working perfectly but for a reason???i have no voice now although my vice sound is on,i updated it and still nothing i can hear.what shall i do?please help!!!
thank you in advance
    Novelist:
  • 158 Answers
The speaker has gone open circuit ( faulty speaker is common on this model ) or the headphone jack in the bottom is faulty ( also common on this model ) . The headphone socket has a switch inside it that switches the internal speaker OFF when an external speaker is plugged in . If this switch stays open you get NO VOICE .
You can check easily to see which fault you have.
  1. Take the SD card out
  2. switch on the tomtom
  3. do you hear the drums sound ?
  4. if you do ...... the speaker is OK
  5. Insert the SD card and wait till it loads up
  6. tap screen then select preferences
  7. move through and select " change voice "
  8. Check to see if you have a voice selected
  9. Return to main nav screen
  10. Tap screen just above lower left ( in the rectangle )
  11. The volume control should be UP
  12. if you have no sound when tapped here , the likely cause is open switch on the socket .
  13. Open up the tomtom , and clean switch carefully
  14. make sure when a PLUG is inserted the switch opens and when the plug is REMOVED the contacts close. properly
  15. Good luck , you have probably fixed it by now.
Please rate this if its been found to be useful to you.
Posted on Nov 11, 2008
Do I need to plug my new Tomtom into the computer before starting it for the first time? Picture directions suggest perhaps. Written directions do not say to. Which? donnabmu@nb.sympatico.ca
You don'y have to connect your new TomTom to your PC/Mac before using it.
The most important reason to connect it at some point is to download updates to fix any bugs. it will automatically detect if your TomTom device is connected and offer you any available updates. Installing TomTom Home (Free download from xxx) gives you all these benefits.
You can also use it to download voice packs, extra maps and premium features (all mostly cost money)
Mar 13, 2011 | Tomtom GPS
Voice lost after aprox 1 hour
could be a faulty speaker, or loose speaker wire.
but dont expect a cheap fix from TOMTOM
Jun 30, 2009 | Tomtom One XL GPS Receiver
My Tomtom 125 loops when I turn it on. It starts ok like when I first bought it--asking for language, time, date--but when it gets to selectign the voice, It stops responding. This happened after I updated...
As crazy as it sounds...try updating it again. I recently had an issue with mine (also a 125) where it locked up and took 2-3 minutes to acquire a GPS signal. Another update fixed the problem. If that doesn't work, call TomTom and let them know that the update screwed it up. A friend of mine did this after having an update corrupt her GPS and they were very accomodating.
Feb 22, 2009 | Tomtom ONE GPS Receiver
Can not use computer voices on my tomtom 520t
I downgraded to the original files, saved em on my PC. No more probs with the voice but I will wait a while till I "upgrade" again.
Dec 15, 2008 | Tomtom GO 520/720 Remote Control
On your device you may have a corrupt file that is causing the noise distortion when you use the computer voices. The solution to this is to completely remove the software from your device and reinstall it again as described in the steps below. Please ensure that you have the latest TomTom Home software installed on your computer:-
You can download and install the latest version of TomTom HOME from the following link:
http://www.tomtom.com/home
Once you have the latest version of TomTom Home installed, please follow these steps:-
STEP 1. Creating a Manual backup of your TomTom
• Charge your unit for at least two hours (preferably via the home charger)
• Perform a reset on your device (see: http://www.tomtom.com/6965 )
If you have not made a backup yet you can do so by making a manual backup of your TomTom. To do this, please look at the following web page:-
http://www.tomtom.com/3171#backup
• Connect your TomTom to the computer
• Open My Computer, you should see the TomTom as a removable drive, double click into it. (on a mac you will see the TomTom as a disk drive on your desktop)
• You will see a list of files and folders.
• Copy all of the folders on the TomTom, one by one to the backup folder. DO NOT copy the 'Loquendo' folder.
• This can take up to 1 hour to complete depending on the device.
• If you get any error messages while copying, move on to the next folder and copy that to the backup folder.
• If possible, please make a note of any error message that occur while copying the folders, and make a note of which folder causes the error message.
IMPORTANT: We advise you to follow the next steps ONLY if you have made a successful backup of your device as described in step 1. If you are unable to complete step 1, please reply back with a list of yellow folders that you have managed to successfully copy to your PC and also reply back with any error messages that you receive at this point.
STEP 2. Format the hard-disk,
• Open 'My Computer'
• Right click on the TomTom icon (the device should be seen in drive E,F,G,H,I etc) and select 'Format'.
• Do a full format by selecting FAT 32 and click on Start, do not select 'quick format'. The TomTom is now formatted.
• Disconnect the TomTom from the computer and switch it on. It will load up with a red cross on the screen.
• Reset the TomTom with a paperclip in the reset hole for 30 seconds, see http://www.tomtom.com/6965 in how to do this.
• Once Reset, switch the TomTom off, disconnect it from the computer and then switch it back on again, it will still show a red cross on the screen.
STEP 3. Restore the Folders to the TomTom
• Connect your TomTom back to the computer and make sure it is switched on
• Go to your backup folder on your desktop, double left click into it. You will see all of your backup folders.
• Copy the folders one by one to the TomTom by right clicking on the folder, select copy then open My Computer, double left click onto the TomTom drive and choose paste.
• Turn the device off (with the on/off switch) and disconnect it from the computer.
• Switch the TomTom back on.
STEP 4. Update your device
• Open TomTom Home
• Connect your device to the PC
• A list of updates should appear, if not, click on Update my Go
• Select only the program application update.
• Click on Update and Install.
• Once Installed, open TomTom Home
• Click on 'Device -> Disconnect Device'.
• Switch your TomTom On to complete the installation.
The Application is now installed, and your TomTom should now be working.
STEP 5. Run the Clear Flash Tool
• Close TomTom Home. (on a PC, make sure you close TomTom Home from the system tray in the bottom right hand corner of your screen by the computer clock)
• Download and run the clear flash tool from : http://www.tomtom.com/updates/clear_flash/clear_flash.exe Make sure your TomTom is connected to the computer and switched on when you do this.
STEP 6. Install a computer voice
• Open TomTom Home
• Click on 'Add maps, traffic and voices -> computer voices
• select the voice of Kate and install it.
The Computer voice is now installed, and your TomTom should now be working.
Dec 06, 2008 | Tomtom GO 910 GPS Receiver
Voice is on but the unit stopped talking.
I don't know if this will help any, but when I updated my recently purchased tomtom go 720 with the newest app (8.3) and the new voices, map, etc...the voice feature completely stopped working on my unit. Everything else was working fine except the voice. However, I had installed an 8 gig sd card into my tomtom and put all the updates on the sd card because I was running low on the internal memory. Bythe way, only the voice instructions were not working..it would still play mp3's through the internal speaker, so I knew it must be a software problem. After several days with no voice instructions, I then proceeded to re-format the sd card and start all over, as the problem appeared to be a software issue. After re-formatting the sd card, I removed it and installed the back-up file from my tomtom before I did the first update. This time, I deleted a couple of the voices in the update package, so that I would have enough room to install the updates to the internal memory. "Bam" now everything is working perfectly again. I believe for me...the tomtom was having trouble communicating with the new application that I had previously installed on the sd card. I hope this may help someone.
Sep 28, 2008 | Tomtom GO 720 GPS Receiver
There are no speaking directions on my TomTom GO720 e.g. for 'turn left' or 'take the next exit' or 'continue for 3 miles'. It only beeps for speed cameras etc. We have ticked all the boxes on the sound...
Hi there
As the TomTom is making beeping sounds, its a good indication that its not a hardware fault, it sounds to me its a software issue.
What you could do is try to reinstall the voices on your device. To do this, follow these steps:-
I presume you have TomTom Home installed already, if not you can download it from
STEP 1 Make a Backup
  • Connect your TomTom to the computer and switch it on
  • Open TomTom Home
  • Click on 'backup and restore' and make a backup if you haven't done so already
Once the backup has been made, please do the following:-
STEP 2 Remove the existing voice files
  • Open My Computer, you will see the TomTom as two removable drives, one will be the internal memory and one will be for the SD card slot on the device.
  • Click into the Internal memory drive, you should see a whole load of files and folders.
  • You should see a folder called LoquendoTTS or Loquendo, click into this folder and delete the contents (all the files and folders inside the loquendo folder)
  • Go back to the root directory of the TomTom and delete the folder 'Voices'
STEP 3 Download and Reinstall the voices via TomTom Home
  • Go back to TomTom Home
  • Click on Add Maps, traffic and Voices
  • Select Voices. Loacate the voice of Jane and Tim and add them to your device
  • Go back to the main menu of TomTom Home, click on Add Maps, traffic and Voices -> Computer Voices and install the voice of Kate or Simon (UK English computer voices)
  • Close TomTom Home and also Close it from the system tray. (in the bottom right hand corner of your screen down by the computer clock, you should see a red icon for TomTom Home, Right click on it and choose 'exit')
STEP 4 Install the Clear Flash Tool from TomTom
  • Once Home has closed completely, please download and install the clear flash tool from:- http://www.tomtom.com/updates/clear_flash/clear_flash.exe (Home must be completely closed, otherwise it may not install correctly)
  • Accept the license agreement and keep pressing the Next arrow until the clear flash tool has installed.
  • Your device will start flashing to say there is some activity on your device
  • When your device has finished flashing on the screen (might take a minute), use the 'safely remove hardware' feature of your PC to disconnect the TomTom
  • Switch the TomTom off then take it out of the dock.
STEP 5 Test the voices
  • Switch the TomTom back on, but not connected to the dock
  • Let it load up to the main navigation screen
  • Tap onto the menu and tap onto 'Change Preferences -> Voice Preferences'.
  • Select a non-computer voice i.e. Jane or Tim and press test. You should now hear the voice instruction
  • Try selecting the voice of Kate or Simon i.e. the computer voices, and press test, you should now hear the computer voice.
This should get the voices working again, if not it might be worth giving TomTom Support a call and they can talk you through it.
Hope this works for you
regards
The Warlock
Sep 17, 2008 | GPS
Voice
Try activating the voice agian or the voice file might be corrputed or deleted.
Aug 27, 2008 | Tomtom ONE GPS Receiver
Tomtom 'Mount to the car screen'-travelling voice fails
Are you using a generic charger? or the official TomTom one? While they might all be 12v output (car)- 5v input (unit end) they are different ampages etc. If you are using a generic car charger then a lot of GPS units consider it to be a computer and so goes to docking/sync mode.
The unit may only sound the voice properly if you running off a tomtom charger.
Jun 01, 2008 | Tomtom GO 910 GPS Receiver
Tomtom ONE GPS Receiver Logo
184 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
