Question about Sharp Office Equipment & Supplies
How can I reset meter reading for Sharp AR-M277
2 Suggested Answers
  • 2072 Answers
SOURCE: SHARP AR-M277
this should resolve it.
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
Posted on Jan 22, 2008
mickspaceNET
  • 115 Answers
SOURCE: Reset Error Code F6-10 for Sharp AR-M277
This code is communication problem between the machine and fax board... The battery on the fax board will need to be replaced.
Usually turning off your machine will make this go away,
for awhile.
Sometimes preventing your machine from going into Sleep Mode also helps.
The Fax Battery is much like the CMOS battery in a computer.
A large round thin battery, (much like a watch battery)
To replace this, the fax board has to be removed, The battery is Soldered to the Board, you have to unsolder the battery, then solder the new battery to the fax board, then reinstall fax board, then set jumpers on fax board. Turn machine on, do some simulation settings, turn machine off, remove jumper from fax board. Then restart, hopefully you will not have to reset the county code.
Unless your experienced with this, do yourself a favor and call a tech..
Posted on Oct 03, 2009
Due to a power surge, my Sharp AR-M277 won't turn
There is a 20A fuse on the AC power board it is most likely blown. Follow the power cable to the board the big white ceramic fuse is the main, check continuity with meter and replace.
Sep 02, 2011 | Sharp AR-M277 Digital Copier Copier
Does a Sharp AR-M277 use 1 or 2 bags of developer?
Hi, the Sharp AR-M277 takes 1 bag developer (type AR-271MD).
Jan 05, 2011 | Sharp AR-M277 Digital Copier Copier
Does a Sharp A RM 277 have a hard drive and if so how can it be erased?
AR-M277, 237, 257, 310 models do not have hard drive. The data is stored in memory. If you have any job pending and turn the power switch off, the data will be deleted.
Dec 09, 2010 | Sharp AR-M277 Digital Copier Copier
How to scan a document using a Sharp copier model number AR-M277.
Requires optional network scan kit. When installed it comes with software for scanning
Jul 17, 2010 | Sharp AR-M277 Digital Copier Copier
We have a Sharp AR-M277. The screen says maintenance required.
Hello sir; Which means is you need a PM that including replace drum, drum blade, developer, corona wire etc. very complicate, if you really interest let me know, I'm happy to give you instruction.
Oct 26, 2009 | Sharp AR-M277 Digital Copier Copier
I am trying to install my ar-m277 on windows vista operating system, and i can't even print
you may need updated drivers for that. check the support for that printer.
Oct 17, 2009 | Sharp AR-M277 All-In-One Printer
Knocking noise
sounds like the developper
it may start to stiffen up.
remove the developper (toner cartridge and try turning the gears by hand, if it's practically impossible to do) replace.
Aug 12, 2008 | Sharp AR-M277 Black and White Copier
46 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
