Question about Pioneer PRO-100 TV
Pioneer sd532hd5/kuxc/ca powers down on its own
TV can be on for 1hr up to 4-5hrs and it turns itself off.The main power cuts off and you have to turn the power off to reset the tv.After this the tv will work for 10min,1hr,3hrs.then it my do it one or two times more,after that the tv will work ok.This my happen every day or it may go 3 or 4 days,it may happen only one or two times a week. when this happens a red power down light will come no a power board in the rear on the tv.after reset the red light will go off.the red light only comes on when it shuts itself off.
    Problem Solver:
  • 4 Answers
Could be a few things.First check your sleep timer.Sounds like a fail safe mode that when the tvs left on accidentally it shuts itself down so it wont overheat and die prematurely.The last resort is to remove the circuit board and carefully inspect the solder joints near the power supply with a magnifying glass and a bright light.Then resolder those.
Posted on Dec 28, 2006
How do I find a reset button fo my pioneer projection tv model # sd582hd5?
If the Projection Monitor does not operate properly, reset it as
follows:
1. Turn off the power of the unit with the MAIN POWER switch.
2. After approximately 1 minute, turn on the power with MAIN POWER switch and POWER button.
Page 18 of the Users Manual
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000033272.pdf
Feb 03, 2015 | Pioneer Televison & Video
My pioneer overloads and cuts out
this unit draws alot of power if you have too many things plugged in on the same circuit then it will shutdown and reset itself. unplug reciever and plug straight into the wall
Nov 13, 2011 | Pioneer SX-315
Pioneer Plasma TV-PDP-4270HD won't turn on. TV
Try this! There should be a power button on the bottom of the panel that has to be depressed for the television to power on. It is the main power supply button and without it there is no power going into the TV.
Mar 16, 2010 | Pioneer PDP-4270HD 42 in. Plasma...
Philips magnavox smart series pr1920c601 turning off itself!
well let me ask ya something so it is coming back by its self then going back out may be solder connection okay call tv shop good luck shad
May 03, 2009 | Zenith B27A11Z 27" TV
Pioneer 50 inch projection tv won't turn on
I only fine 5 fuse where is the 6 fuse locate? Please help I found the 5 on the power board... is the 6 fuse somewhere else not with the power board?
Mar 15, 2009 | Pioneer SD-P50A3Q 50" Rear Projection...
I cant get the fans to turn on!!!!!!!!!!!
Call up the 'Integration Menu" - the fans can be switched between 'auto' and 'full speed'.
To do this switch the display into standby. If the standby light flashes 4 times it is indicating a fault in the Thermal Sensor Assembly which will explain why your fans aren't working. With the display in standby press the menu button and within 3 seconds press the power button. The display will turn on with the integration menu. Select the option tab and scroll down until you see 'fan control' - press 'set' to toggle between 'auto' and 'max'. When you select 'max' the fans will run at full speed within a few seconds. The fans are a bit noisey at full speed so you may want to look into replacing the sensor eventually.
Feb 19, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Problem with pioneer elite pro-99
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
Pioneer PRO-100 TV Logo
433 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
