Question about RCA E13309 13-Inch Diagonal XL-100¿ Color Television Television
Rca xl100 tv needs to reset all settings
I have old rca xl 100 tv , i set color 0(minimum), picture option to minimum using menu option and now my tv is completely black so i can't see my menu option again on screen and i can't chnage the color or any option. pl help me i need all menu options to set in sequence or i need help to reset all settings.
  • 3130 Answers
SOURCE: rca 52' projection convergence problem
Its a good possibility that your convergence problem could for now be cold solder connections on the driver ICs on the convergence board. The longer you use it the more of a problem its going to surge those ICs till they go bad and maybe cause other componet falure as well. If your not a technician i would have this set serviced asap before it becomes a major repair Good Luck
Posted on May 22, 2006
SOURCE: "weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Posted on Apr 12, 2007
just found the problem fuse that causes this to happen. The set I have also was not converging, and the auto convergences option was also gone. The small fuse labeled fl231 which is right next to the big plastic piece with the large red wire coming from it in the left corner of the circuit board closest to the back. It is the middle of the 3 small fuses that are smaller than a Chiclets gum. I was able to pull up the circuit board and jump the fuse with some alligator clips and the set looked great again. Every one says watch out for the unit with that red wire SO WATCH OUT!
damortch check out I think I found them on there gonna call them tomorrow to see if I can get mine there.
Posted on Dec 28, 2007
SOURCE: Caller ID Stopped Working - Think the phone needs to be reset?
Not sure why this worked, but I went to the Menu and the Set Area Code selection. The area code setting was blank, so I entered my area code and saved it. Caller ID started to work again. As a test, I went back to the Set Area Code selection and deleted the area code and saved it. It is currently still working. Seems really odd, but it worked for me.
Posted on Feb 24, 2008
SOURCE: RCA XL100 Remote Code?
I found a remote on the web for that model and purchased it.
Posted on Apr 11, 2008
Can't get the tv to set to cable
Need to use the original remote to enter the menu and change from air/antenna to catv or cable.
May 02, 2012 | RCA E13309 13-Inch Diagonal XL-100 Color...
I have a rca xl100 commercial tv and have forgotten the parental password.please help
To unlock RCA TV, try the following.
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
May 14, 2011 | Daewoo DTQ-13P2FC 13" TV
Need remote code for an RCA XL100 tv
I just programmed my RCA XL-100 today! The code is 11447
Jun 11, 2010 | RCA E13309 13-Inch Diagonal XL-100¿...
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
Dec 25, 2009 | RCA F27442 27" TV
RCA XL100 20" Snow on screen
you have lost one of 3 things,Antenna/Cable, Tuner or part of your tv's power supply
Sep 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
My citizen tv is locked and i dont have the remote to unlock it is there a way to do it manually
Hold menu button +power+volume up you will go into service mode. Scroll down to see if you can find the reset which will reset the tv to factory setting erasing the password. I never had to do this it might work.
Jun 30, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Blurry picture
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 6 order to dessipitate the charge current.
2. Unplug any connected devices (Satellite, DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Jan 08, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
DTV hookup for an RCA XL-100
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Wake Up Timer
u have to set real time first then set the desired time when u want to on ur tv and standby the tv via remote,
May 15, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
Televison & Video Logo
552 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
