Unable to adjust the "red" setting in the convergence mode on a TOSHIBA 578H1 projection TV
  • mcwhorterg Nov 11, 2008
    pressing the power button for 10 seconds did not work. How do I reset the projectors?
    Sergeant:
    Novelist:
  • 196 Answers
Its on the back side of the tv.the adusting buttons.
Posted on Nov 11, 2008
    Genius:
  • 1,913 Answers
Reset your projectors.
or press power buttom for 10 seconds.
Unable to adjust red convergence much red shadowing
Not able to do auto or manual convergence adjustment.The tv convergence board is dead.The tv convergence board,must be replacing 2 STK convergence ICS and some or all of it resistors too.To fix the convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Philips 60PP9202 60" Rear Projection...
I have a toshiba tv model tp50g90 I have replaced the convergence chips stk392-110 convergence was corrected but I have a problem yet red not managed to focus on the user menu in the option of...
Thats the way it works. You have to adjust the other colors to the red. You adjust the red from the back of the set using the convergence magnets on the tubes. Then you adjust the other colors to match the red. It's much easier if you have the plastic screen from Toshiba used to align this set.
Feb 20, 2011 | Toshiba TP50G90 50" Rear Projection...
Picture started flashing like 3-D in the hd ed mode
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 14, 2011 | Toshiba 57HX81 57" Rear Projection...
Screen had a red an blue blur
lilretard93,
Try using the convergence adjustment; listed at the bottom under the picture settings in the menu. If you are unable to focus the TV using its convergence adjustment it's time to call the TV repair guy. Figure about $300.00 USD for your model.
-Chris
Aug 23, 2010 | Toshiba 51H93 51" Rear Projection HDTV
Unable to align cross hairs on the blue lense. Dose the lense need to be replaced?
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
May 08, 2010 | Hitachi 50UX57B 50" Rear Projection...
I just moved my 42in. Toshiba rear projectiom Tv from my basement to the upstairs and now my convergence is off. The red tube cross is low on the manual adjustment and will not go up to the other colors.IT...
It sounds like you jostled the red CRT gun when you moved the set. If the convergence adjustment still moves the red cross hair the the circuitry is okay. Your red gun needs to be realigned. This requires a service call unless you want to attempt it yourself. It is fairly involved and requires some specific tools as well as using the service mode on the remote to reset the convergence after the gun is repositioned.
Dec 06, 2009 | Toshiba 53H71 53 in. Rear Projection...
Unable to enter convergence menu
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 08, 2009 | Toshiba 42H82 42" Rear Projection...
Convergence Issue on Toshiba TN50X81 - Service Manual & Parts Source?
Replace the convergence IC's - P/N STK192-110 with part STK192-150 or 180. Then you can go back in and make the detailed convergence settings and get your picture back in alignement. Also check the flame-resistant resistors around the ICs to make sure that none of them have opened up.
Jan 11, 2009 | Toshiba TN50X81 50" Rear Projection...
Convergence for toshiba 50h82
Either mode is fine...just save your session when done!
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 16, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 55H70 convergence problem fixed but now vol.is gone
I just posted a question about a convergence problem( juice07 ). I am unable to adjust the red color in the convergence adjustment mode. Did you have a similar problem ?? Please help.
Sep 28, 2006 | Toshiba TP50H50 50" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
