Question about SanDisk Sansa View 8GB MP3 Player - Black
My computer doesnt recognize the Player (Code 10) error
The computer recognizes an "mtp device" but when i try to install it using "add new hardware" it comes up with a "code 10" error. I didnt receive any software with it, but its supposed to be able to be recognized by the computer anyways right?
  • 80 Answers
It should install try connecting it to another computer if it does it again try this:
1. turn on mp3
2. put it into hold :a lock should appearon the middle of the mp3's screen:
3. press the back button on the mp3 for about 10 seconds the screen should blink then connect it to your computer
i did this in mine and my computer recognized
hope it helps
Posted on Nov 14, 2008
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the smpk4083 mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
Tip
Sansa View: is not recognized by my computer
See myother TIP posted here on this site. About MSC and MTP Connection problems.
http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
First thing to do is:
Try otherUSB ports on your computer. A USB port on the back of a PC usually has better poweroutput.
Try adifferent cable if there's one available, to rule out if you have a bad cable.
Tryanother computer.
If none of the above works:
Then-Check and refresh the drivers in Windows, for a Portable Device.
1 -Connect your player to the PC
2 -Check under Device Manager
-> 1.Right-click My Computer, and select Manage.
NOTE: The player should show up on the Device Manager's right pane as:
2.Portable Device (if the player is set to MTP mode.)
(See my other TIP listed above for an Explanation of MSC and MTP modes)
If thereis a yellow exclamation point (!) or question mark (?) beside the device, tryto refresh the drivers.
Then -Refresh the drivers
1.Right-click the entry with the error mark, select Uninstall.
2. On thetop menu, click Action then select Scan for hardware changes.
If your BRAND NEW player is NOT recognized by the computer when plugged in:
This may becaused by one of the following:
1.Minimum system requirements were not met.
2.Corrupted drivers.
3.Computer restrictions, Vista or 7 authorizations.
4. Powerissue, plug your player into the back of the computer.
Next be sure you are using WindowsMedia player :
Version10 or 11
Downloadand install the latest Windows Media Player if it's not installed.
If all this has failed - Refresh the drivers again.
If allthat does not work - Manually add the hardware driver.
1. Connect the Sansa player in MTP mode
2. Manually install the device driver through Windows device manager in control panel. Install the Device as a Portable Device.
on Jan 11, 2010 | Audio Players & Recorders
I have just bought a new sansa clip. i have successfully uploaded music to the the player and i can hear it well. now when i try to access the player through the computer i cannot access the music and...
Hi, are you sure the computer is recognizing your player?...if not....
4. Power issue.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
STEP 1 - Connect the Sansa player to the PC
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
Hope it helped ..
Have a nice day..
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
Cannot be reconized by computer, ie states no device connected
Try other USB ports on your computer. A USB port behind a PC usually has the most power output. Try a different cable if there's one available, to rule out a cable malfunction. Try another computer.  NEXT - Refresh the drivers STEP 1 - Connect the Sansa player to the PC STEP 2 - Check under Device Manager -> 1. Right-click My Computer, and select Manage. NOTE: The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode.)
See this tip posted here on this site. This might be what is going on with your player.  http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.  STEP 3 - Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. A brand new Sansa player NOT recognized by the computer when plugged in: This may be caused by one of the following: 1. Minimum system requirements were not met. 2. Corrupted drivers. 3. Computer restrictions. 4. Power issue.   To resolve this issue, try the following solutions: Verify if minimum operating system requirements are met.
Operating systems supported by Sansa players: Windows Vista and Windows XP SP2
Windows Media player supported by Sansa players: Version 10 and 11 Download and install the latest Windows Media Player if it's not installed.
For MAC users, see Sansa player not recognized by a MAC OS Next Connect the device to the PC in MSC mode View/c200:  Turn on then press and hold the rewind button while plugging to the PC  See List of Sansa players with instructions on enabling MSC mode
STEP 1 - Connect the Sansa player to the PC STEP 2 - Check under Device Manager 1. Right-click My Computer, and select Manage. SOLUTION 4 - If that didn't work, and you are running Windows Vista, verify if you have Service Pack 1 installed.   If all that does not work - Manually add the hardware driver. STEP 1 - Connect the Sansa player in MTP mode STEP 2 - Manually install the device driver 1. Click Start select Control Panel then select Add Hardware. 2. Click Next to begin the Add Hardware Wizard. 3. Click Yes, I have already connected the hardware, then Next. 4. Scroll to the end of the list and select Add a new hardware device then click Next 5. Select Install the hardware that I manually select from a list (Advanced) then click Next 6. Select Portable Device or Windows Media Device from the list, then click Next 7. Select MTP device, then click Next. 8. Click Next to start loading the drivers. 9. Click Finish to close the wizard.
STEP 3 - Verify if the device is detected properly 1. Double-click My Computer. 2. Check if the device is showing up under Portable devices. SOLUTION 6 - Set user restrictions.
Some computers have user right restrictions that are set to disable access to new hardware. STEP 1 - Log-in as an Administrator STEP 2 - Edit restriction NOTE: Disconnect the Sansa player if connected. 1. Click Start then Run, 2. Type cmd, then the press Enter. 3. After the prompt, type Net localgroup Administrators local service /add then press Enter.
STEP 3 - Reconnect your device
Jan 10, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
My rca m4204 can not turn on
Go to control panel
then add hardware
connect your hardware device and click "yes i have connected the hardware"
After that scroll down and select install new hardware device
select install hardware that i manually select from a list
scroll down to windows portable devices
and choose MTP device
Jan 17, 2009 | RCA M4204 MP3 Player
My pearl mp3 player is not being recognized by my computer when I
go to control panel,choose hardware,click add new hardware,select that it has already plugged in,select MTP device-->click install->finish
Dec 24, 2008 | RCA Pearl TH1102 MP3 Player
Samsung yp-s3 won't install hardware
Unlike my other MP3 player, the S3 by default is not recognized as a stanrdard USB device. The S3 is an MTP device. MTP is Microsoft's protocol for communicating with the S3.
Window's Media Player 10 or higher will recognize the S3.
Vista will automatically recognize the S3 as well.
There is a firmware upgrade you can try to make the S3 be seen as standard USB device (UMS Mode).
For more info, follow this link:
http://www.anythingbutipod.com/forum/showthread.php?t=33445
Hope this helps
Sep 26, 2008 | Audio Players & Recorders
Zen vision m not recognized
Same problem. Solved by downgrading Windows Media Player to v.10. Do it through Control Panel and click Remove WMP11 and WMP11 runtime. Restart, connect your player and if not recognized do go to Control Panel=>System=>Hardware tab=>Devices. Find Portable Devices drivers in the menu and click Uninstall MTP device. If still not detected, go to Control Panel=>Detect New Hardware and run that. The player should connect automatically. WMP 11 has a glitch that disallows 3rd party MTP players. Intentional or purposeful? Ask B. Gates.
Jul 22, 2008 | Creative Labs Zen Vision Digital Media...
MY sansa e260 MP3 player
Try to add the device manually.
Plug the player in while it’s set to "MTP" mode. (This selection is in the Settings area)
On your computer, open Device Manager, and select: Add Hardware.
Choose the "already connected the hardware" option.
From list, choose "Add a new hardware device".
Select: "Install the hardware that I manually select from a list."
Select: Portable Devices, then MTP device.
Hope it works for you.
Dec 31, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
118 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
