Question about Kenmore 75022 / 75024 / 75029 Gas Kitchen Range
Error message EO-F2 on Kenmore range/oven
The range works, not the oven, the panel displays EO-F2. Model #665.75822 and serial #RK3710371...I would like to fix before the holidays, thanks!
  • 1 more comment
  • bigdaddyh Nov 21, 2008
    Mod# 362 75701000 Ser# OF211276P Getting Error Code F2 when oven is on
  • Anonymous Dec 25, 2008
    Error EO-F2 on the Kitchen Aid Stove/Oven. Oven will not work.
  • Anonymous Feb 04, 2009
    The oven has started taking upwards of an hour to heat to 350... but the stove top works great. Once the oven is hot, it works fine, but I cannot spend the gas or the time waiting for it to heat up!
    oh, ours is a 665.75775
Model790.9503 gives f31 code
Posted on Jun 24, 2010
This message is displayed on my oven: EO - F2 - What does it mean?
E0 F2 fault code usually indicates a shorted touchpad on the oven control. Firs disconnect power to the range for 30 seconds and restore it. This will cause the electronic range control to reset and sometimes will clean errors.
If the error returns the touchpad on the control will have to be replaced. Some ranges have the touchpad made on the control and the oven control has to be replaced.
Open the drawer under the oven and look on the frame of the range around the opening the drawer slides into for a model number tag. Get the model number of the range and go to searspartsdirect and you can see a parts diagram and list for your range.
Hope this helps.
Sep 21, 2011 | Ovens
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
CONTINUE TO GET THIS ERROR MESSAGE EO-F2
you may have an oven temp sensor out of wack. may have carbon on it . wires going to it may have burned
Feb 03, 2010 | Kitchen Ranges
EO F2 on our Kenmore oven keeps coming up.
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Oct 24, 2008 | Kitchen Ranges
Errror code
HI. thanks for the question. the fault code EO F2. means the touch pad key board is the problem. to repair new parts listed . thanks the appliance doc
Sep 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Error message EO F2
that fault refers to a shorted key panel, recommended repair is to replace replace Electronic Range Control/Clock (erc)
Feb 24, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
Control Panel Display Reading
mommaT, the code has to do with the keypad, key held down too long or stuck or shorted keypad. Have someone remove the key pad ribbon cable from the control board and clean the ends with an eraser. If that doesn't do it, you may need a new keypad. Catriver..post back
May 13, 2007 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore 75022 / 75024 / 75029 Gas Kitchen Range Logo
1,464 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
