For a hard drive to even be detected it has to spin - if not spinning it is kaput and needs to be replaced. Make sure that the unit is receiving power before you do anything drastic.
Check the data and power connections to the hard drive. Go into the BIOS settings and see if the hard drive is detected. If the BIOS cannot detect the hard drive then most likely the hard drive is faulty, especially if you cannot hear the hard drive spinning.
Check to see if hard drive is fully plugged in/reseat cables/harddrive. see if this fixes the problem if not listen to see if the drive spins up, if it fails to spin up then the hard drive is bad if hard drive spins up but clicks at regular intervals, it is bad Try a different drive cable Try to replace with a known good hard drive, if it still is not detected check the bios to see if the drive controller is enabled.
If the controller is enabled and cannot detect a hard drive the controller may have failed.
You can try by taking out the bios battery first it might of died on you theres also a ultimate boot cd you can find and download for free i had this problem before put on usb if you get to the bios screen see if it detects your cd drive once the batterys are out hold power button down for 15 to 30 seconds this should at least give you basic function drivers and make sure you have it detect your hardrive and move boot device to cdrom first then have windows cd in computer on reboot windows xp without sp3 probly wont detect a sata drivenot sure might have to use vista
it is phyisically damage and will not work it is bettre just replace the hard dirve. Hope this helps. Please rate my response. Thanks. Have a good day.
A clicking noise from a hard drive typically indicates that the drive is about to fail or has failed completely. If the drive is still under warranty, contact Western Digital for a replacement drive. If not, you will need to purchase a new hard drive. There are services to recover some of the data off of a failed hard drive, but the rates can be quite high.
Do the neccesary jumper cable settings. then manually detect it through your bios. If not detected, try to replace the ide cable. if still not detected, try to feel the hard drive if it spins, if not, the had drive is damage.
