Question about HP Office Equipment & Supplies
HP 5850 IInkjet printer. The print cartridge hold down cover for the hp 56/hp 58 cartridges is cracked and will not last long.
    Scholar:
  • 121 Answers
IT would be hard to find this part......but easier way to fix this problem is to do a plastic solder
Get a small piece of hard plastic....
Heat up your soldering iron....
Put the small piece of plastic as where the crack is and melt it down on the crack using the hot solder..
evenly press down this hard plastic over the cracks.... with the solder for neatness and for toughness
you can even put in a few staple pins bent across the crack and melt it in the plastic for more stronger bond
the wider the area you use the stronger it will be...
Do a few off hand practice for perfection
Hope this was of help
Cheers!
Posted on Nov 11, 2008
HOW DO I INSTALL INK
Sir/Madam
Tell Me Your HP Printer Model Or You Can Perform These Below Step To Change HP Printer Ink cartridge,
Step 1: Open the printer
Turn on the printer. Press the Power button if it is not lit.
Open the printer cover, then wait until the print cartridge cradle moves to the right side of the printer and is idle and silent.
Figure 1: Raise the cover
Step 2 - Remove old cartridges
1 Press down lightly on top of the cartridge latch.
2 Pull out the bottom of the latch to unhook it.
3 Slide the cartridge out.
Step three: Use a cartridge protector
If you are temporarily removing a working cartridge (for instance, removing a Black cartridge in order to install a Photo cartridge), put it in a cartridge protector. Cartridge protectors come with Photo cartridges.
4100022b-6f18-428e-a2bc-bbd00a59c50f.gif 12806acc-4ccc-4074-b41c-6ca5d04702b4.gif
Step 4 - Make sure the new cartridges are compatible
Step 5 - Install the new cartridges
Figure 6: Remove the protective tape
Figure 7: Contacts and nozzles
1 - Contacts
2 - Nozzles
Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
Cartridges marked with a triangle go into the left carriage slot.
Cartridges marked with a square or pentagon go into the right carriage slot.
Figure 8: Put each cartridge into the proper slot
3 Push down on the print cartridge latch until it snaps closed.
5e2afb9d-cef4-415d-bd5c-a6c08dc7a1c6.gif acbe1f2c-5f74-4596-9d01-84173e86e0c8.gif
4 Close the printer cover.
Print cartridge maintenance
After removing the print cartridges from the printer, it is necessary to follow basic care and maintenance guidelines to keep them from drying out. The following guidelines will help maintain HP inkjet print cartridges and ensure consistent print quality.
Do not reattach the plastic tape that covered the ink nozzles since this can damage the nozzles.
Store the print cartridge(s) in a print cartridge protector or airtight plastic container. If the cartridge is stored in an airtight plastic container, make sure the nozzles face down and are not in contact with the container. Do not use plastic bags: this may damage the print cartridges.
Placing a moist paper towel in the airtight container may help to keep the cartridges from drying out.
A print cartridge protector is provided with the photo print cartridge.
To insert the cartridge into this protector, slide the cartridge at a slight angle into the protector and snap it securely in place.
To remove the cartridge, press down and back on the top of the protector to release the cartridge. Slide the cartridge out of the protector.
Do not drop the print cartridge since it could be damaged.
In case You still Having Problem Then I suggest You Visit HP Printer Official Website
Removing and Installing Print Cartridges
Or
still Having Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP PhotoSmart Office Equipment & Supplies
I cant get the ink cartridges into my hp 6940 printer
this steps might help you
Step 1: Open the printer WARNING: If the HP Deskjet printer is turned off when the print-cartridge access door is lifted to access the print cartridges, the printer will not release the cartridges for changing. Damage may occur to the HP Deskjet printer if the print cartridges are not docked safely on the right side when you try to remove them. Push the scraper bar gently with your finger if it is blocking the cartridges, then press the Power button.
  1. Turn on the printer. Press the Power button if it is not lit.
  2. Open the printer cover, then wait until the print cartridge cradle moves to the right side of the printer and is idle and silent.
  1. Press down lightly on top of the cartridge latch.
  2. Pull out the bottom of the latch to unhook it.
  3. Slide the cartridge out.
Step three: Use a cartridge protector If you are temporarily removing a working cartridge (for instance, removing a Black cartridge in order to install a Photo cartridge), put it in a cartridge protector. Cartridge protectors come with Photo cartridges.
Step 4 - Make sure the new cartridges are compatible Which cartridges you use depends on your country or region. To check the cartridge compatibility for your product, click this link, HP SureSupply . If your language or country does not display next to the globe icon (c01906983.gif ) select your language and location.Step 5 - Install the new cartridges If you are installing a new print cartridge, remove the protective tape.
CAUTION: Do not attempt to remove the copper strip.
  1. Close the printer cover.
Print cartridge maintenance After removing the print cartridges from the printer, it is necessary to follow basic care and maintenance guidelines to keep them from drying out. The following guidelines will help maintain HP inkjet print cartridges and ensure consistent print quality.
Store the print cartridge(s) in a print cartridge protector or airtight plastic container. If the cartridge is stored in an airtight plastic container, make sure the nozzles face down and are not in contact with the container. Do not use plastic bags: this may damage the print crtridges.
link below with pictures
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00569593&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=467980
Mar 30, 2011 | HP Deskjet 6940 InkJet Printer
My hp d2360 is not working properly and i bought new cartridge but printer wasnt recognize the cartrige..
Please follow the steps below to install the Cartridge:
Install or replace the print cartridges
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Printer cover openc00658567.gif
  3. Wait until the print cartridge cradle moves to the center of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    NOTE: HP recommends using a print cartridge protector to store an opened print cartridge for later use. Figure 2: Print cartridge being inserted into a print cartridge protectorc00658568.gif
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 3: Removing the protective tapec00658569.gif
    CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 4: Print cartridge facing upc00658570.gif 1 - Ink nozzles 2 - Copper contacts
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 5: Installing the print cartridgec00658571.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Mar 07, 2011 | HP Deskjet D2360 InkJet Printer
My HP 5850 inkjet has been idle for about four years. I downloaded the drivers for it tonight and attempted a test print and received no response from the unit. Any ideas what could be wrong?
If the printer appears to print but there is no print or images on the paper then most likely the cause is the print head nozzles are blocked with dried ink and inserting new ink cartridges won't fix this problem. You need a new print head.
Print heads are not cheap, you may be better putting your money towards a new printer.
Jan 09, 2011 | HP DeskJet 5850 InkJet Printer
My deskjet 5850 is not printing properly. I would like to try cleaning the cartridge before purchasing another. I do not have an icon on my desktop and when I go to printers on my hp computer there is...
go to printers & Faxes in control Panel Right click on your printer Choose printer preferences Click the Services tab. Click Clean the Print Cartridges . Follow the instructions that display on the screen
Oct 25, 2010 | HP DeskJet 5850 InkJet Printer
I dont know how to get into printer to change the ink cartridge hp deskjet 5850
Do this to change the cartride.
1 - Switch the printer on.
2 - Open the front cover by raising the black lid upwards.
3 - Wait a while and the print cradle will move to the right and will become idle and quiet.
4 - Press down on the cartridge to be replaced and slide it out.
5 - Remove the new cartridge from its packaging and remove the safety tape - dont touch the copper parts.
6 - Slide the new cartridge in, use a slight angle, and press until you hear a click.
7 - Close the lid.
8 The printer may print a test page
Apr 26, 2010 | HP Office Equipment & Supplies
I need step by step instructions as far as how to change cartridges in hp deskjet 5440 printer
[This is from HP.com]
Introduction This document explains the basics of installing or replacing the print cartridges. It is for a 5940 which is the same printer design, yours may look a bit different but I copied this from HP at the section for your printer so follow the instructions and you should be okay.
Insert the print cartridges
NOTE: The printer shown below is the HP Deskjet 5940 series printer. Your printer might look slightly different.
  2. Open the printer cover. Figure 1: Open the cover c00393707.gif
  3. Wait until the print cartridge cradle moves to the right side of the printer and is idle and quiet.
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 2: Remove tape c00393708.gif 1 - Protective tape CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 3: Install the print cartridge c00393709.gif
Original Page here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00411520&lc=en&dlc=en&cc=us&product=445441&os=228&rule=27868&lang=en
Regards,
Worldvet
Dec 01, 2008 | HP Deskjet 5440 InkJet Photo Printer
HP PhotoSmart 7960 InkJet Printer
Make sure the cover that holds the ink cartridge in place is completely closed down on the cartridge. Also make sure there is not a pencil or something under the cover where the ink is , obstructing the print head
Jun 15, 2007 | HP PhotoSmart 7960 InkJet Printer
44 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
