Question about Casio Exilim EX-Z57 Digital Camera
Lens wont retract, Camera unresponsive
I just got the camera less than one month ago and yesterday when I went to turn it on the lens extended out but the camera never came on. Now the lens remains in the extended position and the camera is unreponsive to anything I do. I have fully charged the battery and tried again with the same results. The green light flashes once when I press the power button but then there is no sign of life at all. I can here a sof clicking noise for about one second inside the camera if I hold down on the power button but that accomplishes nothing either.
  • Anonymous May 26, 2008
    Wxact same problem here :(
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
I like Google. In an attempt to find a solution for this same problem, I stumbled upon this site. Seeing as this was posted months ago, I'm not sure if this will be checked again, but it can't hurt to have a suggestion, just in case it turns out to be right. Without opening the camera for sure, what I can tell is that the lens extends and retracts by rotating. Essentially, the lens is a series of threaded cylinders that, when turned one way, move outwards, and when turned the other way, move inwards. What you're describing, especially the bit about the clicking, sounds like this threaded bit of the lens casing has come either off-track, or snapped, or something to that effect. I would suggest (if you're feeling secure in your abilities) taking the device apart and getting a good idea of exactly how the lens retracts and extends. Once you've determined this, you may simply be able to reason what would stop it from moving. I can almost guarantee that if the lens is designed to extend upon power-up and retract upon power-down, then an attempted power-up would be aborted if the lens can not extend. I might be losing the focus a tiny bit, but the idea is that essentially the lens will not screw in or out because it's either jammed, or cracked, or just off its track somehow. This can easily happen if the camera is dropped or jostled just hard enough. So my solution, if you can consider it that, is to disassemble the camera to see whether the threads are just off-track, or if there's some sort of mechanical breakage inside. If it's the former, then it may be as simple as realigning the threads. If it's the latter, the cheapest solution would be to find another of the same camera on eBay that is broken in a different fashion, then use the part(s) that you need to get yours working again. I hope this helps someone!
Posted on Feb 01, 2007
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
LENS ERROR RESTART CAMERA
The lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Feb 25, 2011 | Canon IXUS80ISS Digital Camera
Lens error, cannot focus, lens not retracting
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Mar 21, 2010 | Canon IXUS 860 IS Digital Camera
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
Sep 25, 2009 | Samsung SL201 Digital Camera
Sony dsc-w5 lens not returniing
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Lens error of casio EX Z300
Apr 18, 2009 | Casio EXILIM EX-Z300 Digital Camera
Wont turn on but light is blinking
Are there any error messages on the LCD display?
Will the camera lens stay out when the camera is turned on?
Can you still take a photo/flash/sound without seeing the photo?
If the camera will not turn on even with a fresh set of batteries it could have a system or lens error in the camera.
a possible lens jamb when closed and the green led on top comes on then shuts off after the lens attemps to extend but cant.
Aug 29, 2008 | Nikon Coolpix L11 Digital Camera
I have a canon ixus 900Ti. I turned it on yesterday and the lens came out as normal. when i went to take a pic the camera shut off but the lense never retracted. when i turned the camera back on the splash...
Apr 22, 2008 | Cameras
Lens error Help please
The Lens Error usually means the lens has sand or another obstruction stopping it from retracting.
Nov 07, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Casio Exilim EX-Z57 Digital Camera Logo
159 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
