Question about Ricoh Aficio CL7200 Laser Printer
Paper jam indication, but cannot find the paper that is jammed
ON my Ricoh CL7200, I continue to receive a notification that there is a paper jam in the "A section" of the paper feed. When I open the printer, I see no paper that is jammed. Is there some other place I should be looking or something I should remove or lift in order to find the paper that is jammed?
  • michael Mar 09, 2009
    I have the same problem with the Ricoh Aficio CL7200 - it gives a false jam message from area "A". I have cleaned and thoroughly inspected the machine, the message persist.
  • 4 Answers
I would check to see if the paper is even making it out of the tray. A lot of times, the feed rollers can get dirty, and the printer will display a jam if it doesn't feed in time. If the feed rollers look ok, then I would check and see if the feed rollers are even turning. Sometimes the motor that turns the feed rollers wears out.
Posted on Apr 27, 2009
  • Ryan Caputo
    Ryan Caputo Nov 11, 2016
    CG SOLUTIONS- You are the freaking man!!!!! I was having the same exact issue with my Afficio 2018, and I was beginning to freak out, but after a little cleaning of the feed roller, I am back in business!!!!!!!!!
Ricoh c2050 continuous paper jams
Problem with the hot section, service call needed. -Carl
Mar 25, 2014 | Ricoh Office Equipment & Supplies
My ricoh aficio 1035 shows a paper jam and it is cleared. There is nothing in the pathway. It continues to say there is a paper jam. What can I do? I've taken it apart in the area of the jam and...
There is an actuator type sensor between 1st paper tray and reg sensor.sometimes a piece of paper gets stuck there. Open the door on right dude and shine s torch down u may c a piece there. If not go into service mode and do an smc print and identify sensor with jam and test it in input mode.
Sep 13, 2011 | Ricoh Aficio 1035 Copier
Our Canon ImageClass D860 copier had a paper jam. We cleared the jam and did everything we were supposed to do and it still says Paper jam on the screen. We've turned it off, unplugged it and still it says...
There mite be some paper dust on the sensor where the copier indicate the paper jam is. some can air mite solve the problem. Be careful to direct can air towards the outside of the copier don't want to blow the paper dust to a different sensor
Jul 12, 2009 | Ricoh Aficio 2015 Copier
The 2022SP gives me a jam indication but there is no paper jammed.
If it shows it all the time there is paper or at least something, if it jams on the first copy paper size or paper direction issue. Does the display show the paper size and direction correctly? All drawers fail? May have torn paper behind the cover that the bypass tray sits on. -Carl
Jul 08, 2009 | Ricoh Office Equipment & Supplies
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Paper jam leading to error code sc440-01
I think the code is a black pcu motor lock. Replacing the black pcu might fix it, but the black waste toner section could be backed up.
Jan 29, 2009 | Ricoh Aficio CL7200 Laser Printer
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
Ricoh Aficio CL7200 Laser Printer Logo
1,322 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
