Question about D-Link DI 514 Wireless Router (DI-514)
Using a Dlink DI-514 as a simple hub
I have a DI-514 that I would like to use just as a hub not a router. Is it possible to configure it so that the router side is disabled and it just give me more ports for my existing router?
    Novelist:
    Scholar:
  • 160 Answers
Any router can be used as a hub by not using the WAN port. The cable which connects to the rest of your network goes into one of the 4 LAN ports, leaving you 3 wired open ports to connect additional devices. The wireless part will continue to function nomally.
You'll want to disable the DHCP router function in this router. Do this before setting it up as the hub. Connect to it with a cable from a desktop machine into the router - no other network connections at the same time.
Either use the setup CD for the router, or browse to the router address (192.168.x.x) depending on if you're using the default address, or it's been reconfigured.
Then turn the DHCP server function off.
Connect it to the rest of the network, and you're good to go.
Posted on Nov 14, 2008
    Scholar:
  • 120 Answers
If you are trying to use a router as a hub it should be straight plug and play, unfortunatly hubs are a bit different from routers. You see routers smartly select which connections are most important and allow those connections to take presidence. Hubs allow all information to be shouted at once causing more of a congestion and a slower connection. As for the router once more, you will not get more connections unless your wireless.
I went on a tangent, i hope i helped your question.  If this doesn't answer your problem please post again.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 12, 2008
I want to insert a password in internet connection Braggion Giorgio
You should connect to router configuration page using your web browser. Normlly the adress you should type is 192.168.0.1. If is the first time you install it or it has factory defaults you will be asked a username and a password. Type admin as username and leave the password field blank.
Now you are in router configuration page. From here you can choose a password to protect your wireless lan and a password to protect router access.
For more info contact me or go to www.dlink.com
Mar 30, 2011 | D-Link DI 514 Wireless Router (DI-514)
I want to change my username and password..i have wi-fi connection.and my router is from d-link.
To reset your wireless router to the default, hit the the reset button
46e1c92.jpg Whenever you want to configure your network or the DI-514, you can access the Configuration Utility by opening the web-browser and typing in the IP Address of the DI-514. The DI-514 default IP Address 192.168.0.1
· Open the web browser
· Type in the IP Address of the Access Point
Type admin in the User Name field (lower case)
Leave the Password blank
Click OK
The Setup Wizard page is the first page that appears when logging into the web-based management interface. The Setup Wizard is a utility used to quickly configure the DI-514. It will guide you through four quick and basic steps to help you connect to your ISP. You will be connected to your ISP (Internet Service Provider) and have Internet access within minutes.
If you need the entire user manual, follow this link and choose Product Manual. You can download a zip file with the manual in it.
http://www.dlink.com/products/?tab=3&pid=DI-514&rev=DI-514
Mar 12, 2010 | D-Link DI 514 Wireless Router (DI-514)
How to reset my new password (D-link DIR-300)
when we forgot all.so from which purpose we can reset the router password i want the solution urgently.
May 18, 2009 | D-Link DI 514 Wireless Router (DI-514)
Ssh remote computer access
It is possible to limit outgoing connections, but generally a firewall is used to limit connections being initiated from the outside (incoming connection attempts). Check the settings in your router to ensure that it isn't limiting outgoing connection attempts, but it sounds more like a permissions issue on the server your are trying to connect to.
Apr 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
Wont connect to internet
I might advise you to reconfigure the DI-514 Wireless Router, Access the IP address 192.168.0.1 using the Internet browser and configure as Dynamic IP address. You got a red light because the router is not configure yet or no Internet connection from your provider.
Mar 21, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Cant acess dlink keeps asking for domain
Setup the Local Domain Name on your router. To do this you may need to logon to the configuration page of your router.
Feb 28, 2009 | D-Link DI 514 Wireless Router (DI-514)
Want to use Dlink DI-514 with Qwest modem to hardwire 2 computers
Believe it or not, Actiontec modems from Qwest are setup as a router already (even though ports are missing from it). You should use a switch instead of another router. Otherwise you will have to configure the DI-514 to act as a switch rather than a router. This is done by assigning a new starting IP address into your DI-514. By default both routers use 192.168.0.1 as the default. You will have to plug the DI-514 seperately into a computer (to take it off the network) and assign a new starting IP address for the DI-514 such as 10.150.1.1 for example. Then you will be able to get it work. I would strongly recommend using a switch instead and turn the wireless on the modem itself (this is why the modem is the router). It will save you some headaches if the power goes out.
Feb 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
DI-514 - Cant get myyahoo pages as well as vpn
are you sure its not your internet
check tools internet options
security reset all zones to default
advanced and then restore settings
then content click on publishers make sure there is nothing in there then press apply and restart
You can also reset the router a very tiny hole beside the power on router or unplug power for a about a minute
Jan 25, 2009 | D-Link DI 514 Wireless Router (DI-514)
DI Liks DI-514
http://support.dlink.com/downloads/
Select: DI Select One: 514
This is all that is available for this router from D-Link.
http://support.dlink.com/faq/view.asp?prod_id=1513
This page probably can answer any question you have about configuring this router.
Oct 18, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI 514 Wireless Router (DI-514) Logo
431 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
