Question about Brother MFC3240 Multifunction InkJet Printer
Brother 7420 fax/Scanner/Copier-only copier out of ink
I can fax and scan with no problems, but when i try to make any copies it seems there is no ink, although there it does not say out of ink on the screen? what the matter?
  • 133 Answers
You need to replace your toner.
if you still replaced your toner. Then unplug the machine and wait for 1 min. then plug it on the power to see what's up.
if still not working,
open the front cover, push option and push 00
Posted on May 22, 2009
Since upgrading to windows 10 I am unable to scan. Message Is Unable to write the file to this folder. Please make sure you have correct permissions to write to this folder. (CC3-107-00431005)
That sub folder is in a windows protected folder. See if you can create a folder un your libraries subdirectory and name is scanned docs. Then tell the scanner to send it to that folder
Aug 12, 2015 | Brother MFC-7420 Laser Multifunction...
Always says problem with connection on lexmart 85x never connects
Save yourself some frustration and money on ink and buy a new printer. I personally like Brother as they don't complain as much as the other brands when you use generic ink. Traditionally Lexmark ink is quite expensive.
Dec 04, 2013 | Lexmark Photo Printer, Scanner, Copier and...
Copies are being printed with a line vertically down the side of the page. Only happens when copying using the hopper.
If it's a thin, sharp line, it's just a blob of ball-point pen ink on the scanner glass. Lift the lid, and you'll see the narrow strip of glass that the scanner uses when you feed a document through the feeder. Clean that with a rag dampened with window cleaner, or, better yet, alcohol. Even a dot of ink too small to see will show as a solid black line on anything you copy, scan, or fax via the doc. feeder.
Don't use so much cleaner that it runs under the glass.
Nov 10, 2010 | Brother MFC 7420 All-In-One Laser Printer
Black lines in copies and fax's Brother MFC 7420
If the black lines comes when using the ADF (top feeder), try to see if you get the same problem when using the scanner glass or receiving faxes. If you don't, you simply have to clean the glass strip to the left of the a4 sized scanner glass. Wipe it with a dry cloth piece, no paper and no water/alcohol. If you see some dirt there that you're unable to simply wipe off, try to use a cotton wool to "rub" it off.
Jun 14, 2009 | Brother MFC-7420 Printer
How to scan a file plz explain me
Scanning is like copying, but instead of making a paper copy, the scanner puts a copy into a file in the computer. Search for something called 'twain' in your computer.
Apr 22, 2009 | Brother MFC 7420 All-In-One Laser Printer
Scanner - MFC 7420
Get the manual, and you may need the install disk too. Look carefully at the usb port on the copier so you get the correct usb cord.
Mar 31, 2009 | Brother MFC 7420 All-In-One Laser Printer
I have a brother mfc-7420 flatbed and am trying to scan multiple pages through the automatic feeder but it only scans whats on the flatbed? Is the feeder only for copies and not for scans? Anything i can...
First install everything, than go to my computer at the bottom u will have Scanners and Camera, click on Brother MFC-7420 USB
Than if the window pop ups than click on Microsoft Scanner and Camera Wizard
Now u will have new Window "Scanner and Camera Wizard" click Next
On next page u will see Choose Scanning Preferences in there u will find "Paper Source"
click on the Scroll down option and pick "DOCUMENT FEEDER" and Click next
than hopefully u know wat to do pick the name fro scans that u going to make pick the folder to place it in and it will start scanning by it self and will send i to ur computer.
And put ur Scan paper with the side that u wanna scan FACE UP in the FAX tray which is on the Top or all in one Printer
Dec 02, 2008 | Brother MFC 7420 All-In-One Laser Printer
I just got a new Dell Windows Vista Laptop. I currently have a Brother 7420 printer, fax, scanner, copier combo. I can't get the scanner to work. Please HELP... Thanks, Pam
I presume the print and fax parts work. Can you make a copy? Have you checked the driver software? The CD that came with the equipment usually installs the scanner software as well. try reinstalling the software and see if it works.
Dec 01, 2008 | Brother MFC 7420 All-In-One Laser Printer
Vertical lines on photocopies/faxes
The MFC-7420 Manual recommends cleaning the scanner glass and white plastic bar above it with isopropyl alcohol. Page 11-22 has a diagram.
I am having a similar problem but cleaning it did not work. But try that first.
Oct 15, 2008 | Brother MFC 7420 All-In-One Laser Printer
81 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
