Question about Canon MultiPASS MP370 All-In-One InkJet Printer
PLEASE HELP!! Have been using my printer today with no problems. Turned it off and just turned it back on. It started printing, even though there were no jobs pending when I turned it off. Now the cartridges are stuck on the right side and making a loud clicking noise - seems like it is trying to print something but the cartridges won't move.
  • sam barrish Nov 09, 2006
    Thanks for taking the time to reply, but that hasn't fixed it at all. The printer is still making the loud clicking noise. Any other ideas?
  • Jackpine Dec 28, 2007
    New printer today.Set it up says toners are fine .It prints but makes loud clicking noises when it prints and after it it is finished.I checked to make sure the image drawer clicked into place.Have unplugged it and waited 60 seconds and restarted.Printed a sample page and it still make the noise.
I had this same "loud clicking" issue after I replaced my first toner cartridge. The magenta ran out, I ordered from a discount online store, installed it, then had the clicking problem while printing (though the print quality seemed ok). I compared the old, empty cartridge that came with the printer the new one, and found them identical except the new one had a little square transistor board on the surface that is inserted into the printer, next to the round, black thing, which I think are gears... like a little round black flywheel. I noticed the old, empty cartridge had no such board, but just a square hole instead. What was happening was this little circuit board wasn't letting me push the cartridge in far enough to allow the “flywheel” to fully connect (or at least they couldn't connect without continually disconnecting too, which was causing the loud clicking noise). So I got a little knife and pried off the circuit board, and then took out this little grey, spongy, sticky thing under it. I reinserted the cartridge and noticed it slid in just a little bit more (maybe 1/8 in. more). But then the printer didn't register I had a magenta cartridge, so it wouldn't print anything for me! So I put the spongy thing back in, then the circuit board. But when I put the circuit board back in, I pressed it in about an 1/8 in. past being flush with the plastic it was resting on before... so about 1/8 in. past where it originally was. So, now, instead of being stuck, flush with the plastic, it sort of floats on this spongy thing and goes in slightly when you push on it with your finger, creating a small, square hole like the original cartridge I examined. Perhaps this is how it's supposed to be but it had a manufacturing defect. Anyway, I reinserted it again and it slid in just a bit further than originally. It works fine. No more clicking noise while printing! So obviously the little black gears are now firmly in place. Hope this helps.
Posted on Feb 29, 2008
Try manually turning the gears on each of the toner catridges. You'll probably find one that needs some back and forth loosening. My black started clicking after 5 prints. It should move freely in both directions. The gears are smald enough that my black catridge had a tooth on the gear break.
Posted on Dec 31, 2007
Sounds like the clean cycle/calibrating. open the door and insert something into the slot for the door closure to cheat it to think its closed and let it run to see which toner is making the noise. You can remove and re-insert it. Make sure the imaging unit is fully seated into the printer. Remove and replace and make sure it clicks into place. Sam has sent a new printer for me they know there is a problem this is second one I have worked on.
Posted on Nov 14, 2007
I agree that it's a cartridge problem. I got 2 different brands of knock-off cartridges. The first I didn't have the noise problem with, but the second brand does cause it because the cartridge doesn't fit into the socket properly. It's exasperating. $85 down the drain. The knock-off brand that does work for me is compatible brand sold by 4inkjets:
https://www.4inkjets.com
A little more money, but worth it for not pissing off office mates, not to mention avoiding the irritating clicking noise!!
Julia
Posted on Jul 01, 2008
My ML-2010 was clicking after installing a generic replacement blue cartridge. I removed the cartridge and attempted to turn the black "gear" thing - it was stuck! Then a tiny puff of blue and my gear began to move freely. I guess it was just stuck! All better now, no more clicking!
Posted on Sep 20, 2009
Can someone suggest a solution why my lexmark X1150 will not print? the paper runs through and i have ink but the paper comes out blank?
Posted on Jan 13, 2007
I had the same problem. I fed a rubber band behind the carriage then used the screws by the toner to secure the rubber band. There was a piece on the carriage that was dragging.
Posted on Dec 20, 2006
Do you work with more people? Sometimes classmates or partners like to play jokes which can't have a happy ending. Try checking any strange element inside your printer. If you don't find anything try to check if the printer has any evidence of shock.Finally check the axis where the inks are inserted, there is a rubber which can be damaged.
Posted on Jan 10, 2007
This has happened to me once on the Alps MD-5000 (though the cartridge got stuck on the left side). The only solution I can think of, and what worked for me, is to power off and unplug the printer, open the lid, and with some needle-nose pliers gently but firmly pry the cartridge out, taking extra care not to break any of the components in the printer. Because I didn't want to force the head out of the way, I actually used lock-jaw pliers to crack the housing of the stuck cartridge (though this may be extreme and unnecessary, all depends how stuck the cartridge really is). By cracking the housing, I destroyed a black print cartridge, but saved my printer. Note-- If attempting this make sure to do it in good lighting so that you can see any pieces that may break off the cartridge and remove them prior to powering the printer on again. Hopefully this does the trick for you! Good luck!
Posted on Nov 11, 2006
    President:
  • 2,961 Answers
As mentioned, disconnect printer from pc and turn off. Go to your printers folder and uninstal your printer and drivers from Add/Remove programmes. Re-install your printers installation cd drivers and re-connect printer when prompted. If the problem persists, you will then know it's not a software problem but unfortunately a hardware fault. Please reate this solution.
Posted on Nov 09, 2006
    Problem Solver:
  • 8 Answers
Have you tried to unplug the printer, make sure the power is shut off on the computer. Then plug the printer back in. This will usually reset the print cartridges and clear anything that is in the queue.
  • Wendy Hepple Nov 09, 2006
    I forgot to tell you to wait for at least 30 seconds to allow the unit to totally shut down before attempting to restart it.
4 Suggested Answers
SOURCE: Canon Pixma MP530 clicking
it is nothing to do with a phone jack, trust me this sounds like internal crunching and munching... but as reported by the others, no jams, no printing errors, just loud clicking and clunking!
Posted on Mar 11, 2008
  • 3 Answers
SOURCE: Unable to print PDF files
use the PS driver for that
Posted on Feb 24, 2009
komguy
  • 2306 Answers
SOURCE: My canon PIXMA MP190 All in one Injet Printer
Use a flashlight and small mirror to look down where the paper goes in the back, usually something has fallen in where it shouldn't be. A lady last week turned her printer upside down and shook until a bic pen fell out.I find pins, paper clips, toys, or gum inside. That one roller us usually enough.
Posted on Oct 23, 2009
General Error message on a Epson Stylus NX100
Incase you have used a compatible cartridge , they may not work at times . Insert the old cartridge and check , if it prints ( even though partially ) . The problem could bein the cartrige or the fitting of the same .
Dec 20, 2012 | Epson Stylus NX100 Multifunction Printer...
My MP830 printer won't print in black. I've changed the two black cartridges, even though they weren't empty, and have re-installed the driver, restarted my computer, turned off the printer, disconnected...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Dec 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
Printer always says its offline even though its on and connected
If you are Windows XP Operating System, perform the steps below:
1. Click Start --> Printers and Fax.
2. Right click the printer icon and check the following:
a. Check whether the All-in-One is set as default printer.
b. Ensure that the there is a check mark on the "Use printer online". If you have the Use printer offline, make it online by selecting the option.
c. Ensure that there is no check mark on the Pause printing.
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Sep 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Have a Dell photo all-in-one printer 962. When it is turned on, it says "right cartridge incorrect" even though the cartridge has ink.
Try pulling out cartrige.Starting printer without it.Then turn it off and put back cartrige.Start it again.
Also, many other printers have problem in recognizing ink level. So just print until you see there isn't any more link left.
Sep 05, 2009 | Dell 962 Photo All-In-One InkJet Printer
Unable to print from the internet using dell printer 948
We had a similar problem that the printer could not print online content (see here).
Turned out to be a Windows firewall problem and reinstalling the software solved the problem.
Just to make sure: open your firewall settings (Start->Control Panel->Windows Firewall) and disable it.
If you can print now form the internet, you found the culprit.
The easiest way to solve this problem is to either re-install the printer software and open the ports or look into your printer manual and find the information about necessary ports that have to be opened.
If you need more help with that come back here and leave more details (esp. which printer you are using) and I'm happy to help.
Feb 07, 2009 | Dell Office Equipment & Supplies
R2400 foreign object error
return printer back you not gonna solve this problem this is head malfunction
Jan 16, 2009 | Epson Stylus Photo R2400 InkJet Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Canon MultiPASS MP370 All-In-One InkJet Printer Logo
1,167 people viewed this question
Clive
Clive
old marine
old marine
