Question about Samsung HT-X20 Home Cinema 600W Theater System
Problem with SAMSUNG HT-X20!!
When in Aux mode after 1 hour it write protection and shut down! when i turn on again it shut down after 5 minutes! When i play dvd there is not problem!
  • gtapro151 May 24, 2009
    Protection beeing displayed but i fixed it check out my sulution
  • Anonymous Mar 13, 2014
    The receiver will switch to all modes Aux 1, aux 2, cd/DVD, radio but it does not always work right away but will after changing modes a few times
  • 4 Answers
The fan is going bad and when u play dvd's the spining of the cd is acting as a fan witch is why they play longer then any other mode i had the same problem 2 times the second time samsung wanted 160$!!! thats bull because it keeps going out so what u do is open the case and remove the cover over all the capaciters and whatnot and replace that fan in the back then cut a hole in the top of the metal case directly about the cap's that warm up and install a aditional fan to act as a chimney a little noisy but i did this and the player had been runing in aux and radio mode for a few days stright now no problems at all it's alot of work and skill but for 2 5-15 dolar fans sure beats the 160 for repair or buying a new recever!
Posted on May 24, 2009
My HT-X20 keeps on going into protection mode after 1 hour then every 5 minutes. What should i do?
Suspect heat.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Sep 01, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
After 20-30 minutes work in the USB or AUX mode, the unit turns off. At display panel says PROTECTION. After that this problem (when I turn on) repeats after 3-5 minutes.
  • make sure the speakers are plugged in correctly
  • if you tried that already check if your system gets hot when it turns off
  • maybe you need more ventalation on your system...
Jan 16, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
Ht-z210 home cinema protect error
Protection Error means that there is a malfunctioning component inside your unit. It will go into protection mode and immediately shut down to protect your system from any further damage. Unfortunately you would have to bring it to a dealer or repair shop to diagnose the exact malfunction and that could be expensive.
Gary
Jul 18, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
The system goes into Sleep mode every 5 minutes and just before going into the sleep mode,''protection Error'' flases on the screen
Unfortunately, the unit is not going into "Sleep mode".
The PROTECTION error actually means that the unit is overheating.
The unit shuts itself off to avoid further damage.
Try to make sure that no other device is below the unit. Also make sure the unit has adequate ventilation on the back of it.
If not, call 1-800-7267864 and let them set up a repair order for the unit.
Jun 30, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Protection Error
maybe the audio amplifier IC´s are in bad conditions and need to be replaced
Dvd turns off after displaying ''protection''
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation or replace the fan
May 29, 2009 | Samsung Audio Players & Recorders
Audio
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 21, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
My Samsung HT-40 home theater system throws itself into protection mode and shuts down. I put a new fan motor in but it insists on shutting down anywhere from 10 to 60 minutes of operation. No dust...
The fan is going bad and if you have replaced it try to open the case and remove the cover over all the capaciters and what not and replace that fan in the back then cut a hole in the top of the metal case directly about the cap's that warm up and install a aditional fan to act as a chimney a little noisy but i did this and the player had been runing in aux and radio mode for a few days stright now no problems at all it's alot of work and skill but for 2 5-15 dolar fans sure beats the 160 for repair or buying a new recever! make sure u turn on the recever for 10 min if the fan is not turning by then its still not good
Dec 18, 2008 | Samsung Televison & Video
Samsung HT-X20 Home Cinema 600W Theater System Logo
646 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
