FixYa.com
Tags:
D-Link DI-704P Router
Cnet broadband cnig-914
posted by vintiques on Nov 09, 2006
I was just recently switched over to Time Warner from Comcast.
I have been using this hub cnig-914 to hook up all the computers in my home. Everything was fine until the transaction process started.
I have a hookup only if I directly go to my main pc, but when I try to go through the hub I have no connection to any of the computers
Any advice is very appreciated.
Thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 09, 2006
Helpful (85)
Whepple
Rank:Guide Guide
Rating: 77%, 64 votes
Can you log into the Hub at the IP http://192.168.1.1/ when it is connected to the computer and the internet connection? Perhaps it is just a configuration issue. http://www.cnetusa.com/support/manuals/C... is the link to the manual to setup your router. Without further information about your network and its configuration I can't give more specific information. If you will please post any specifics about your configuration I can hopefully assist further. Please tell me how many computers there are, how many are directly connected to the router and how many are wirelessly trying to connect.
Another suggestion is check your boot up order. Often times you have to unplug everything, then plug in the internet router, give it time to full boot up and have all lights on, then plug in the additional router (in this case I am assuming that it would be the CNet Cnig914), again allowing all the lights to come on, then plug in or turn on any pc that is connected directly to the router, followed by any computer that is wireless. This allows each system to be assigned the IP address and recognize the previous equipment. Once it gets an IP and everything is working you shouldn't have to repeat this process.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 01, 2008
Not Rated (0)
ashleyjaicee
Rank:Apprentice Apprentice
Rating: 100%, 3 votes
hi vintiques,
as you have mention, you switch from comcast to time warner, means that you need to reconfigure your cnig-914. Since both providers required a registered mac address, you need to do a mac cloning with your cnig-914, take note that it should be the MAC ADDRESS or PHYSICAL ADDRESS of the computer can go online with the modem. Then, after that you can just simply do a power cycle
how to do mac address cloning check your cnig-914 manual
How to do a power cyle :
* turn off the computer
* turn off the router
* turn off the modem
after a minute or two
* turn on the modem (if all lights are ok)
* turn on the router
* turn on the pc (check the connection)
hopefully everything works fine
This Problem Also Relates To: Motorola Wireless G Broadband Router (wr850g) 2wire 2700HG-B Router (2700HGB) 2wire (1000-400108-001) Router 2wire HomePortal 1100 Router (1000400124001) 3Com OfficeConnect ISDN Lan Modem Router 3Com OfficeConnect Wireless 11g Cable/DSL Gateway Router (3crwe754g72-a-uk) Actiontec (5GE583000-01) Router
Can you Help with these Routers problems?
Routers
PS3 ONLINE TROUBLE
i have a ps3 but it wont let me... Answer This...
Routers
Fritz!BOX fon WLAN 7170
Hallo, ich habe diese Box... Answer This...
Computers Do not find DI-704P...
I just had cable internet... Answer This...
wan led
wan led lights is not workin... Answer This...
Vonage does not work with...
Hi, i hope you can help me. i... Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
