Question about Nikon D40x Digital Camera
Overexposure My Nikon D40x is WAY overexposing in AV or S mode. Does it need repairing? (a long trip to get fixed). I tried resetting to default store settings, tried using only manual focus, tries changing the metering options. Noe have worked. AV mode worked beautifully 6 months ago in Africa ......
  • mrdanddjm Nov 11, 2008
    Tried removing memeory card and then replacing, still problem in AV and S mode af major overexposure.
    Yes thankns! I needed to hear it from someone that i wasn't just missing something simple!!
    Genius:
  • 1,124 Answers
That sounds like the aperture blades may be sticking open.
See if the overexposure gets worse and worse as you close the aperture
When you see these kinds of symptoms, and is usually caused by oil that's leaked on the aperture blades causing them to become sticky (a problem usually found only with relatively old lenses). Try remounting the lenses it to make sure it's not a bad connection.
Posted on Nov 11, 2008
    Sergeant:
  • 229 Answers
I do not believe the camera need repair. It may but try these thing first. Av is for Aperture priority setting which can be adjusted manually using your menu features. Refer to your owners manual. Also S is shutter priority which is extremely easy to overexpose photos because if you do not trim the shutter speed using your menu or manual settings it will open the shutter way too long. Bump the adjustments when using these settings and all should be good or go the easy way and use your auto settings in the future. Hope this helps it should thanks for using FixYa!
  • Lance  McKinney
    Lance McKinney Nov 11, 2008
    Looking further if you have manually adjusted metering and shuttering is not working properly then as suggested earlier you probably do have a repair situation at hand. Good Luck
    Scholar:
  • 112 Answers
Based on what you said you tried, It sounds like it needs repairing. If you took it on a trip to Africa, it wold not have been all that difficult to jar it with out you knowing. If you tried fixing shudder speeds and flash settings, something (probably the shudder) is broken.
    Sergeant:
    Novelist:
  • 196 Answers
It needs professional repair person as it is having a internal problem with the circuit of the device. sometimes replacing the battery solves this problem thanks.
    Genius:
  • 1,913 Answers
Put away your memory card battery then try.
My Nikon D40X shows an Error for the shutter release. It says "Error. Press shutter release button again." When I push it again, it keeps giving me the same error. Is there a way to fix it without sending...
Hello. I have the D40X myself and I have had success by going into the menu and locating the reset button. What this does is return the camera to the settings that it had the day it came out of the box. Joe
Feb 14, 2010 | Nikon D40x Digital Camera
Overexposure problem with a Canon Powershot A620
CCD FAILURE !
Just Call CANON for FREE REPAIRS they will do it , bcoz it is a known manufac fault just ask them about BAD CCD
pls rate me WELL !
Jul 07, 2009 | Canon Cameras
Nikon D100 program mode overexposure
Inside the lens mount is the stop down lever. As you look at the camera, it is at 9 O'clock. Move it a couple of times up and down. It is probably stuck.
Jun 10, 2009 | Nikon D100 Digital Camera
Nikon D40x Metering Problem
I assume this is no longer under warranty.
This more likely to be a case of not pointing the camera correctly when pressing the release if for example you press the release firmly and dip the camera down in so doing it will register a shadow the camera moves up on exposure and you get a burned image.
Try various experiments in the mode see what happens.
As regards a repair it is likely the cost would be as much as or more then a new replacement
Contact the Nikon customer support
Jan 31, 2009 | Nikon D40x Digital Camera
the meter should turn on as soon as you half press the shutter. otherwise remove the lens and try cleaning the electrical contacts on the lens and on the camera body.use q-tips dipped in very light spirits of alcohol, make sure you dont leave any debris around the area. caution with the camera's sensor.
Overexposure in AV mode
check your EV settings.. might have set it high on +7
Nov 11, 2008 | Nikon D40x Digital Camera
All white pic is shown on LCD when used in Manual Mode with delayed shutter timer
You are massively overexposing the picture. Manual mode means you have to set the exposure manually. You need to adjust the settings so that the light meter reads somewhere around the zero mark.
M mode is most useful for flash photography where you want a certain level of ambient illumination in the picture as well.
If you want some control over the camera but don't want to worry about exposure too much, use A and S modes. The manual will explain all of these modes.
Aug 31, 2008 | Nikon D40x Digital Camera
"whiteout"
If the photo shoot out show white , the obscure (quality variation),and even horizontal line ( white lines), and so on over-exposure cases,even if the use of anti-tremor, set to default values are invalid,because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Jun 10, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Incorrect metering
it may be a problem with the camera, but you should be using the manual modes....they are much more accurate. if you are worried about it being a defect issue, then send it in.....
I have one also, and have found it to be a bit slow on the metering side on the pre-programed modes.....
May 17, 2008 | Nikon D40x Digital Camera
Overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Apr 29, 2008 | Casio Exilim EX-S600 Digital Camera
Nikon D40x Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
