Question about Lexmark Office Equipment & Supplies
It says my printer spoiler is not working. what is that
    Genius:
  • 1,913 Answers
Go to control panel then printer and faxes
sele ct your printer properties then go to advanced
enable option buton to sppool so progeam finish faster.
aslo enable print directly printer.
Posted on Nov 11, 2008
How to replace 3rd brake lite chrysler pacific
1.Open liftgate before disconnecting battery.
2.Open hood, disconnect and isolate the battery negative cable.
3.Open liftgate.
4.Disconnect the power liftgate prop rod.
5.Remove liftgate trim panel
6.Remove the four retaining nuts to spoiler .
7.Gently lift spoiler off of outer liftgate panel.
8.Disconnect the CHMSL electrical connector.
9.Disconnect the washer hose.
10.Remove spoiler from vehicle.
11.If replacing spoiler, transfer CHMSL lamp to new spoiler.
12.If replacing spoiler, transfer washer nozzle to new spoiler.
Aug 31, 2014 | Chrysler Pacifica Cars & Trucks
964, rear spoiler won't work
Start by checking remote switch. Test to see if there is power at the spoiler motor. If there is power getting to the motor check for bad ground. Finally remove the cable that drives the spoiler up and down and apply 12v dc to the motor. If the motor turns check to see if you can turn the cable without the motor and that the spoiler moves. I all power checks out and the spoiler won't move by turning the cable, the gearing that the cable attaches to is most likely damaged.
Jan 19, 2014 | 1991 Porsche 911
When are the spoilers parts used in airplanes?
Spoilers are used during landing in order to increase the drag of the wing and decrease the amount of lift. They have two functions during flight: make the airplane descend or slow the airplane down before landing. Also, during landing, the spoilers are used in order to keep the plane on the ground and improve the efficiency of the brakes.
Aug 29, 2012 | Champion Sport & Outdoor - Others
I have a 2007 Infiniti G35s sedan. I installed an OEM spoiler & spliced the spoiler wires to the 3rd brake light wires. Non of the brake lights work now including the 3rd & spoiler. What did I do?!...
Sounds like you have lost ground somewhere along the way. might try running a ground from spoiler to frame or simply replacing wires back to original and trying again. Would put my money on a ground wire. good luck
Aug 12, 2012 | Cars & Trucks
My brake lights on the spoiler of my 2004 Lincoln LS do not work.
lift the car and lock inside of the spoiler turn the conector and pull out the light bulb and instal the new bulb light
Jul 22, 2012 | 2004 Lincoln LS
How do you replace the brake light on the rear spoiler on a 2001 Hyundai Accent?
This is the Spoiler Dude. The spoiler light is attached with screws to the spoiler. You must remove the screws and then the spoiler light will come away from the spoiler. Clip the two wires ( Black & Red ). Attached the new spoiler light ( I can get that for you) with a sleeve. Test the new light with the brake pedal depressed. Screw in the new light and that is it. If you have any questions.
Call Spoiler Dude Paul
719-661-8600
www.spoilerdudepaul@gmail.com
Apr 20, 2009 | 2001 Hyundai Accent
Rear spoiler does not work.
The rear spoiler is controlled by a Rear Spoiler Control Module. Fuse 35 (30A) and Fuse 5 (7.5A) located in the fuse panel behind left side of dash provide power to the control module. After ensuring that the fuses are good, I would toggle the Rear Spoiler Switch to see if the servo-motor works properly. It is located under the steering wheel underneath the flat part of the dash.
Apr 04, 2009 | 2000 Volkswagen Beetle
Spoiler service
Sam think this one out and comeback with a full explanation Spoiler Service means nothing to Me
May 21, 2007 | Lexmark X8350 All-In-One InkJet Printer
Spoiler service
Try this website about print spooler. http://support.microsoft.com/kb/314876
489 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
