Question about Compaq Armada 4220T Notebook
I got a amrada 4220T when i got it it worked fine it had windos 98 on it i tryed to put xp on it and did not have space to finish when i restared my laptop it started asking me for the oriangel systems disk . but my laptop dose not have a cd rom or flopy drive.
  • juggalojay19 Nov 11, 2008
    but my laptop dose not have a cd rom or flopy drive. and it wont boot up to go on line
OK Get a docking port the dock has two ports one for cd-rom the other has muti-capabilitys but anyway this will solve ur problem.
The other way and cheaper way is to get a laptop to desktop ide converter hook up laptop hdd and reformat this will also tell you if u can get XP but i think the compaq comes with a 4GB and xp pro is 2.5GB so just install xp and the compaq armada's drivers. Hope it Helps
Posted on Jun 13, 2009
    Genius:
  • 1,913 Answers
Foramt your hard disk and try to install xp again.
may be your lapto pnot suport xp.
Posted on Nov 11, 2008
Message says that there is insuffient memory when trying to install or run Windoes 98Se on machine with 2MB Ram
FYI,
Minimum hardware requirements for Windows 98:
1. 486DX 66 megahertz (MHz) or faster processor (Pentium central processing unit recommended).
2. 16 megabytes (MB) of memory (24 MB recommended).
3. Hard disk space may range from between 120 MB and 295 MB, depending on your computer configuration and the options that you choose to install.
4. A full install of Windows 98 on a FAT16 drive requires 225 MB of free hard disk space, but may range from between 165 MB and 355 MB, depending on your computer configuration and that options that you choose to install.
5. A full install of Windows 98 on a FAT32 drive requires 175 MB of free hard disk space, but may range from between 140 MB and 255 MB, depending on your computer configuration and the options that you choose to install.
6. One 3.5-inch high-density floppy disk drive.
7. VGA or higher resolution (16-bit or 24-bit color SVGA recommended).
If your PC does not meet the above minimium requirements, you are bound to get errors popup installing or running software.
Hope it helps.
Oct 30, 2010 | Microsoft Windows 98 for PC
Can i install windows xp directly with out
ya u can do that.but demerits are ur old windows still occupy space.if any virus exists it will still exist.so i suggest u to make fresh install by formatting ur c drive
Feb 23, 2010 | Microsoft Windows XP Professional
Joystick will not work on Vista
These are the specifications for your joystick. Apparently it only supports Windows 95/98 and you were probably lucky to have it working on XP.
Software / System Requirements
  • Software Included Drivers & Utilities
  • OS Required Microsoft Windows 95/98
  • Min Processor Type Intel Pentium
  • Min RAM Size 16.0 MB
  • Min Hard Drive Space 15.0 MB
Mar 27, 2009 | Logitech WingMan Extreme Digital 3D...
Invalid systme disk. Replace the disk and press any key
its domnickr,
its so we can not install xp in model 1255 it will spoils your hard disk all you can install win98 ED 2 only..... so its wise not to try it and reinstall using win 98 install disk. if format is not possible do format using Fdisk command.
step 1 :enter dos floppy
restart ur lap enter from insulation option.
chance boot perority to floppy disk ie Shift +.
restart lap
enter fdisk in commant
format using instruction for any help mail at domnickr@yahoo.com
Mar 21, 2009 | Compaq Presario 1255 Notebook
EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Oct 28, 2008 | Epson LQ-2180 Dot Matrix Printer
DISPLAY AND SOUND DRIVER FOR WINDOWS 98
i have 945 mother board but i cant insta VGA , SMBUS Driver
Jun 07, 2008 | Intel D945GCL Motherboard
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Compaq Armada 4220T Notebook Logo
152 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
