Question about Homelite 'Yard Broom' Leaf Blower
When I pull the recoil rope it seems to have lost compression and won't start. Pulls easier but with no compression behind each pull. Any ideas?
  • mkh1 Dec 31, 2008
    The key on the Magneto Rotor(flywheel) was sheared. I am still looking for part.
    President:
  • 2,692 Answers
Have you checked the compression? A lot of  two stroke cycle engines are running less lube due to emission which results in far more wear. Sometimes people don't realize that oil has to bve added to the gasoline.thus wearing the engine to the no compression state.
Posted on Dec 25, 2008
Snowmobile ran great all day but seemed to run different on the way home. The next day I went to start it and I couldn't pull the rope. I assumed it was locked up but not sure now.
Problem with starting next day [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-344777.html
Mar 25, 2013 - 13 posts - ‎7 authors
I have a buddy who couldn't start his CF1000 in the mornings and it was like you ... So is the recoil catching and you can't pull the rope? Recoil Rope stretched apart- showing Nylon cords
Mar 2, 2015
Engine seized then not seized??
Feb 23, 2015
2007 Ski-Doo Summit 800 X Motor Quit
Jan 31, 2012
My pull string went bye bye!!
Oct 31, 2008
More results from www.snowest.com
pull start not working - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/...snowmobiles/5470-pull-start-not-workin...
Jan 19, 2005 - When you pull the rope, it should have a little slack followed by a slight... and he couldn't believe that it didnt have a choke. does my sled not ... 1988 yamaha phazer- dies at full throttle
Mar 3, 2010
Need help uprighting snowmobile after tipping over
Dec 28, 2008
More results from www.snowmobileforum.com
Jan 04, 2016 | Garden
My poulan 2075c chain saw won't start. Pull recoil rope will not pull out smoothly.
I would suspect possibly you have the incorrect spark plug installed which is allowing piston to contact it preventing complete rotation of engine.
Or possibly the engine has so much compression that you are not used to it and it is making you believe the engine will not rotate with spark plug inserted?.
Sep 23, 2014 | Poulan Garden
I have a 3hp briggs & stratton//the pull rope pulls freely//it does not engage the engine and turn the engine over
You probably need to replace the starter recoil. This is not a very expensive fix. Just be aware that this problem is usually caused by having to pull the starter rope excessively because of some other starting problem. Once you replace the recoil, keep your engine running properly.
Sep 07, 2014 | Garden
Rope pulls but does not trun motor
Recoil may be broken or seized up inside so it won`t work.
I had a lawn mower like that and tore the recoil off and had to repair the flippers inside. Mine had a broken pin.
Jun 20, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Recoil pulley assembly keeps binding. Rope stays in pulley, but won't retract. Must remove motor housing , loosen 3 pulley hold down guides, & uncock the pulley. spring tension on recoil is fine....
Have you ever replaced the recoil rope, if you had is it a larger rope then the one that came with it? If so, that could be the cause of the binding. I had that difficulty once.
Aug 05, 2011 | Garden
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
Pulley cord wont go down unable to start on gas trimmer
Your cord wont recoil?
You should remove the recoil cover and see if you can rewind the rope manually.
It isnt too hard and will let you know immediately if you need to replace the recoil.
Just the recoil unit by loosening the three or four bolts and lift it off the trimmer. Turn it over and look at the recoil spool. There should be a notch in it. This is were you catch a bit of the starter rope and start turning it in the direction of normal rotation. Normal rotation will put tension on the recoil spring.
When you put 4-6 turns into it just let it recoil and see if it pulls all the rope back in. That's it. If the cord didnt recoil something inside the recoil has broken and you need to get the unit serviced or replaced. Most of the time the cost of repairing something like this is prohibitive. Its a better idea to just replace the whole unit.
Good luck and be careful!
Aug 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I 'm trying to pull the rope and it will barely--honda pressure w
The rope may be bound up in the recoil. Take the recoil cover off(the piece where the pull rope goes into) and try to pull the rope with the housing off. If it pulls freely try turning the engine by hand, you may want to remove the spark plug to release the compression. If the unit will not turn over,then the pressure pump may have failed. Best of luck.
Apr 23, 2010 | Honda Karcher G4000RH Pressure Washer
Craftsman weedwacker 358.791070 suddenly stopped
could have been caused by any number of thing's,
take the recoil assembly off and try pulling the rope out while holding the center of the rope spool just enuff to prevent it from popping out in case there's nothing holding it there.
rewinding the rope is alot easier than rewinding the recoil spring Trust Me.. lol
Jul 31, 2009 | Garden
Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Oct 03, 2008 | Garden
Homelite 'Yard Broom' Leaf Blower Logo
333 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
