Question about T-Mobile Sidekick
Phone stuck on reboot screen
I took my memory card out and when i put it bak in its stuck on da reboot screen
I suggest that the memory is containing dust and must be clean
Posted on Nov 13, 2008
On my Nokia N70, my phone memory card is not accsesible . Even it shows " No Memory Card inserted " on my Mobile after inserting it into phone and when i connect it to computer it does not shows memory...
first connect your memory card to a card reader and check wehther it is recognising...if no,sorry to tell you this, your memory card is currupted. formating is the only one way to get bak your memory card...hope this will helps you...thank you...
Oct 15, 2009 | Nokia N70 Cellular Phone
My LG flame phone is stuck on the "hello" screen. I took the battery out and restarted it multiple times hoping to fix it, but still it gets stuck at "hello"
look sir you cellphone is over loaded by too much data take its memory card out reformat it and then turn it on without memory card..after it gets start then put in the memory card ...........thank you
Jul 04, 2009 | LG Flare Cellular Phone
How do i put music on my sony ericsson phone from a laptop
To put music on your W810i cellphone, connect it to your laptop with the usb cable. If you don't have the cable use a memory stick. The phone or card will show up as a removable drive on your computer in the Windows Explorer. Copy folders of music into the MP3 directory. When your phone is disconnected or the card is inserted, it will take several moments to index the music, and then your music will appear in the music listings.
May 16, 2009 | Sony Ericsson Walkman W810i Cellular Phone
T-Mobile Dash stuck in the start up mode
Unfortunately, the only way to fix this is to do a cold boot on the phone and reset it to the factory default settings. A description on how this works can be found at another answers page. For the sake of saving you some time, I'll repost the answer here.
**beginning of post**
Is it just getting stuck there, or is it doing a reboot loop? If it gets to a certain point and keeps rebooting, and if you have a memory card inserted, try removing the memory card and turning the phone on again. This tends to happen when a program is installed to the memory card instead of the phone, but removing the memory card when turning on the phone will allow it to boot all the way.
If it is getting stuck on that screen, then a hard reboot(cold boot) will need to be done. Hopefully you have synced it with your computer recently, because it will reset everything to factory settings and erase everything else. If you have a memory card, be sure to remove it before doing a hard reboot! I'm not sure if it would erase the memory card or not, but it is best not to take the chance of leaving it in.
***WARNING: This will erase all of your files that are stored to the phone's memory!***
1. Make sure phone is off
2. Hold both softkeys (the 2 buttons below the screen with the dashes) and turn the phone on. Be sure to keep holding the softkeys while the phone is booting.
3 Follow the directions that will appear on the screen to complete a hard reboot. It should ask you to press the Send key to continue or End key to cancel.
**end of post**
Now, keep in mind that when when you are following in the instructions, release the power button immediately after turning the phone on, otherwise you'll have to start the process over again.
May 08, 2009 | T-Mobile Dash Smartphone
Phone frozen
Is there a memory card in the phone? If so, it might be causing a problem. I just had the same thing - phone was stuck on the opening screen. I took it back to the shop. By a long process of elimination involving other handsets and sim cards, we eventually realised it was the memory card, which i have now thrown away.
So if you have a memory card, take it out. If there is still a problem, remove the battery and sim card, put them back in, turn phone back on (without memory card).
Hope this helps,
Aitch
Dec 30, 2008 | Samsung J700 Cellular Phone
Memory card
try to clean the contact of your memory card with a contact cleaner.if still the problem persist, you need to change your memory card.
Jul 10, 2008 | Nokia N70 Cellular Phone
It goes to the verizon screen and stops
its was just a memory problem it had too much memory so i took out my memory card and turned it on and it worked perfectly and when i put my memory card in it still worked fine....so apparantly it just was having a bit trouble with the memory card...
Jul 06, 2008 | LG enV VX9900 Cellular Phone
My Tmobile dash will not turn on. When I put it on the charger, the green light comes on (and it charges), but when I attempt to turn it on it does not come on.
It may be the storage card - if you take the storage card out it will boot up and you can put it back in. - pain in the a## but it may work. Or Try taking the SIM card out, boot it up, turn it off, replace the card, and turn it on again Last resort is a hard reboot to set it back to factory default. reboot system by holding down the two - - keys above the house and arrow while the phone is off. Then you continue to hold while you push the power button on the side for 2 seconds. Should go to white screen then black screen. once at black screen hit the green call button and follow the rest of the prompts.
Feb 29, 2008 | T-Mobile Dash Smartphone
Memory full
Happened to my n73 twice. Format the phone to get rid of junk piled inside the phone memory.
To format:
  1. turn phone off.
  2. hold the following keys WHILE its turning back on: (3 + * + green call key)
  3. do not let go until it asks you about your location
Your phone will gain 44mb back and go back to normal. Phone will respond a lot faster too, as if it were new. Viruses would be deleted as well as other junk stuffed inside.
Important reminder:
If you have anything stored on the phone memory that you woudn't want to delete, such as pictures, videos, or whatever, back it up to your memory card or computer. The format process deletes all stored memory on the phone, but not the memory card.
Dec 23, 2007 | Nokia N73 Cellular Phone
T-Mobile Sidekick Logo
95 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
