Question about Mk Diamond MK 101Pro Tile Saw
MK Diamond 101 Wet Saw is Out of Alignment with tile tray groove
I've looked at the saw, and the blade no longer slots into the tile tray groove. All I can think is that somehow the frame was bent. Are there any troubleshooting tips to try and realign the blade with the tray. Or, are there any MK Diamond authorized repair agents. I'm located in the greater Washington DC area. Thank you for any assistance!!!!
  • 1,879 Answers
Aligning the blade is not recommended for personal safety reasons.
It is better to have the frame aligned at a service center.
Closest - No Authorized Service Center in DC
Rental Country Inc.
1044 W. Landis Ave.
Vineland, NJ 08360
Phone: 856-692-7510
Fax: 856-692-0714
Posted on Nov 11, 2008
    Sniper:
  • 69 Answers
Search for nearest service center here
http://www.mkdiamond.com/global/s_serv.php
  • 13,433 Answers
Try to locate a service center with this webpage
Superiorbilt 10" wet tile saw parts
Take a look on amazon for them, here: Amazon com wet tile saw parts. Wish you best of luck.
Thomas
Oct 04, 2012 | Mk Diamond MK - 101 Pro 24, 2hp Tile
Hello ,i was looking for a CAPACITOR for my mk 101,wet saw it is 240V,60hz so any idea please ...thanks
Go to radio shack explain to clerk what you need ,they should stock the 240v, 60 hz capacitor once obtaine you must solder the cap in good luck
Jun 15, 2011 | Diamond Products Mk - 101 10" Tile Saw
I am not sure I can be any clearer than to say the saw dooes not cut the tile square.
the problem is probably the slide cart you set tile on to push it into the blade,on the right side theres a roller you can adjust the the height of the tray,or look at the very bottom of the cutting arm,left hand side,on the outside,where its painted red, theres 2 bolts that hold the cutting arm to the frame of the saw body,try this first, i bet nuts got loose and the cutting arm dropped a tiny bit screwing everything up
Dec 28, 2010 | Mk Diamond Mk Tile Saw Mk-101 Pro24 10in
Saw is not cutting true / will not cut a straight line ?
Check blade is on properly. Remove blade and clean area where mounts to shaft. Make sure proper washers are in place. If blade is bent or wobbles replace. If blade is dull replace. Be sure you're getting enough water to saw. Don't force the tile through, let the saw do the work. Nothing helps any kind of saw more than a nice new blade.
Jul 01, 2010 | Diamond Products Mk - 101 10" Tile Saw
Start capacitor keeps blowing. saw starts up
SOUNDS LIKE THE CENTRIFUGAL SWITCH IS NOT WORKING.
THE MOTOR IS STARTING ON THE START WINDING AND NOT SWITCHING TO THE RUN WINDING. THAT IS THE REASON IT IS RUNNING SLOW.
May 13, 2010 | Diamond Products Mk - 101 10" Tile Saw
Looking for shaft lock to change the blade on MK 170 wet saw
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Apr 27, 2010 | Mk Diamond MK - 170 Wet Cutting Tile Saw
How do you remove the blade on tile cutter model mk470 mk diamond products, inc
Unplug the saw, raise the guard fully, grasp the blade to hold it and loosen the nut then remove the blade.
Sep 12, 2009 | Mk Diamond Products, Inc. 7 In. Wet...
Tile saw not cutting straight
Sometimes a blade that is set deep enough will walk in this manner, especially if it is a thin kerf blade like the MK Hotdog blade.
Also, a blade which has worn unevenly will do this too.
Jul 11, 2009 | Mk Diamond MK - 101 Pro 24, 2hp Tile
Mk Diamond MK 101Pro Tile Saw Logo
111 people viewed this question
Top Mk Diamond Saws Experts
Tom Chichester
ray gallant
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
