Question about GE WBVH6240F Front Load Washer
Leaking Washing Machine
The excessive leaking is coming from the drawer where you load the detergent, not sure wether replacing the drawer would fix the problem or where to get a new drawer if that would indeed fix the problem?
  • 43 Answers
No you should not need to spend any money on this . it sounds like the hose going from the back of the soap draw to the drum may be blocked just boil your kettle and pour it into the draw if this clears the blockage you wil see steam in the drum then put more hot water about another 2 kettles full down the draw and push the draw in and operate machine on the spin cycle. if the blockage is still there take off the lid you will see the hose from the back of the soap box and sqeeze it this should release the blockage
Posted on Nov 12, 2008
Suds leaking from detergent drawer on brand new Bosch washing machine
Use high efficiency detergent that s more concentrated. It uses MUCH lesser detergent VoLUME than conventional. The detergent has "He" letter on the bottle. And usually with FULl load it uses only about 150+-cc ( my cup is on 3marked level provided by the detergent bottle) Hope this helps! Robert Calgary, AB
Dec 13, 2013 | Bosch Washing Machines
I have a Miele W4840 front load washer and there is water leaking from the door. I've checked the seal and it doesn't seem to be damaged, but there is a definite leak. Please advise.
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
May 09, 2011 | Miele W 4800 Front Load Washer
Water is leaking out of the detergent drawer. It
i would say the outlet from the bleach area is blocked clean out drawer unit
Apr 12, 2010 | LG WM2277H Front Load Washer
Intello washer leaking water from detergent drawer. model no. WM10402F would like to know if a part needs to be replaced or would anew machine be better. the water only leaks when water comes into the...
Are you sure it is coming from the detergent drawer? It could be from your inlet water valves. They are very easy to see. Two screws on the rear of the machine will let you slide the top back and expose the componets.
Dec 29, 2009 | LG WM-2277HW Front Load Washer
Hotpoint WMA40 washing machine is leaking from detergent drawer- any suggestions ? Thanks
Hotpoint WMA40 washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 27, 2009 | Hotpoint WMA40 Front Load Washer
Whirlpool front loader WF665/1 spilling water during cycle. Water is leaking from where the powder is deposited into the machine during the filling stage of the washing cycle. The machine will continue its...
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
Nov 16, 2008 | LG WM2487H Front Load Washer
(front load ATF6000ES) is constantly leaking detergent
the loose vane cant affect leaking first open the drawer look on the back Left side of the drawer push down on the tab and remove the drawer take it apart and clean it well top and bottom clean the inside of the drawer hsg and look for cracks on the top panel remove the two screws at the back and remove the panel reassemble the drawer assembly put detergent in it start the washer take a flashlight and look for leaks
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
GE WBVH6240F Front Load Washer Logo
182 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
