Question about Philips GoGear HDD6330 MP3 Player
+ Volume button has lost its spring
I have a Philips HDD 120 MP3 player and I have had it for some 4 years. The volume is adjusted at the side of the casing but the plus volume key has lost its rocking feel and does not respond to adjustment.
    New Friend:
  • 161 Answers
Andy, there is no actual spring under the raise / lower bar, it works on a central pivot, one end (--) is underneath the fixed end and is held in by the rear cover.
If you removed the cover you can see how it operates, it is possible some debris is there or some how come off the pivot.???
If you require information on how to strip/remove rear cover, let me have your email address and I will send it to you.
Posted on Nov 16, 2008
How do you charge a 2bg go gear? trued laptip but no luck my in mp3 it won't come on
Your laptop has to have a USB 2.0 port. Many laptops do not even have enough power to properly run an mp3 player. If your laptop is definitely compatible, here is the method to force recognition (note: the Philips HDD series of GoGear needs a proprietary adapter, so if your model # starts with HDD, make sure you have the original adapter):
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
Mar 25, 2009 | Philips SA920017 MP3 Player
I have a Philips Gogear Mp3 player. suddenly I'm not able to switch on the power supply and i tried charging it for 4-5 hrs.no Use. It's just 4 months old. can u help me?
It's dead. The HDD models are basically obsolete - you may have purchased it 4 months ago, but it was manufactured 3 years ago. Here is the basic troubleshooting to be sure, but it won't work:
Triple Reset for Philips’ GoGear:
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Dec 12, 2008 | Philips GoGear HDD1830 MP3 Player
Need assistance regarding my philips gogear 6gb HDD/1630/17 mp3 player
-Tha Mp3 Doctor
Nov 30, 2008 | Philips HDD1630 MP3 Player
Major problems
You have to run the "Repair" function in the Philips Device Manager to remove this error message - see Philips website or call them for details.
Then upgrade the firmware:
Recovery Mode for Philips' GoGear
Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Aug 02, 2008 | Philips GoGear HDD1830 MP3 Player
No power or charge
You might want to call Philips - if the product is in-warranty (purchased in the last year), then you will be good to go. If the product is out-of-warranty, they will give you a reduced (hopefully) cost for A replacement. They are currently out of stock of the HDD models, so they will offer an equivalent SA (which, unfortunately, will not be 30GB).
I would try just one more time - hold the volume + button while the player is disconnected from the computer; continue holding the volume + button as you reconnect the player to the computer, and continue holding volume + after the player has been reconnected for up to one full minute. If the pop-up comes up asking you what you want to do with the player, select "take no action," and check the box that says "perform this action every time". Then disconnect the player, and re-follow the volume + instructions. You can release the volume + key after Windows says "Found Hardware Wizard."
Mar 18, 2008 | Philips GoGear HDD6330 MP3 Player
Phillips HDD120/05
Repair the GoGear - warning: this will delete all files from your player.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
-Tha Mp3 Doctor
Feb 10, 2008 | Philips HDD120 MP3 Player
Sometimes after switching on its has got blank hdd
Get the latest version of the software from the Philips website - it is more recent than the install CD. then,
Make sure you back up all songs on the GoGear before attempting this solution.
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Dec 01, 2007 | Philips GoGear HDD6330 MP3 Player
Nery Guzman
You can register with Philips. Make sure you have Windows XP and WMP 10, or else you will have to do the following:
-Tha Mp3 Doctor
Oct 06, 2007 | Philips GoGear HDD6330 MP3 Player
Power
-Tha Mp3 Doctor
Apr 03, 2007 | Philips HDD1630 MP3 Player
Philips hdd 1620/05
Hold down the power and volume-up buttons for a few seconds.
Philips GoGear HDD6330 MP3 Player Logo
43 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
