Question about Kodak EasyShare DX6440 Digital Camera
Mode Dial Stuck On Camera
Hello, The Mode Dial on my camera is stuck. Somehow it got turned past the Video Icon, and it won't move backwards to the "Off" position. I can still take pics & even download them to my PC, but I can not get the Mode Dial to move. I have to take my batteries out to get it to go off. What would make it stick in that position? I thought the dial moved clockwise & counter clockwise. It will not move at all. Could it possibly need oiled, etc,? Help please!! Thanks muchly
I too owned a DX6440 Easyshare, but it was the mode dial on a later model, Easyshare Z730, that dialed too far past the video mode and got stuck. No support help available from Kodak other to send it in for repair. Easyshare DX6440 and Z730 are great cameras, but after owning 5+ years, I could probably buy a new camera for the cost of repair and shipping. I removed all exterior screws, very carefully pried out the side rubber panel, the bottom connection separated fairly easy. The top connection required more finesse to separate. I loosened the screws to separate the mode dial's two pieces just enough to allow to reset the dial around the housings plastic stops. Be careful with the small metal strip portion of the dial mechanism that makes the "click" when setting your desired photo mode, it slips out easily with the camera housing open and the little board removed from over the dial. I'm charging the battery now before completely reassmbling to see if can test power up first.
Posted on Oct 02, 2011
Hey i had the same problem. Saw your post and none others. Finnaly i gave up looking and just started tearing my camera apart. My camera is a Kodac 7630 so the diss assembly may be a little different but with the removal of a half dozen screws i got to the inside of the dial. It didnt feel sticky but i took it apart any way and cleaned all the touching serfaces of the dial with rubbing alchohol and my problem is solved. took about 30 min and there was really no danger of harming the camera. Its amazing the just a little stickyness caused the problem i was having because i could push with all my might and the dian didnt budge. i thought a part was broken in there. i think this is because you allso have to push down to move the dial so a little tickyness combined with your downward presure makes it impossible to turn.
good luck
Posted on Jun 22, 2008
Kodak Easyshare z730 - possible problem flexible flat cable. I had a recent problem with a stuck power/mode dial turning too far past the video mode. I was successful in carefully opening the camera and...
It's obviously a switch problem, not a ribbon (which controls the lcd screen) problem. Start doing your research to find that "perfect" camera. Read all the reviews to see what actual owners think in addition to the experts. Or......you can "limp along" until you get tired of that.
Oct 05, 2011 | Kodak EasyShare Z730 Digital Camera
My camera when it turns on says ' Mode Dial Is not in the proper posistion ' I haven't dropped or anything! Will my warrinty cover it!?
Hi jayderehbein,
Make sure that the dial for selecting either video capture or image capture is not stuck somewhere in the middle , therefore a good idea would be try moving it to different positions and then back to the usual image mode and this message would go away ...
Hope this helps ..:) Your feed back would be appreciated.
Jun 19, 2011 | Nikon S8100 Digital Camera
Nikon Coolpix L3 Trouble
I had this same issue. Here's what I found on it in the Coolpix L3 manual:
That hand icon is the "camera shake" indicator, and it will pop up when the flash is off. The other day, I turned off my flash, but somehow it got stuck in that mode and wouldn't respond when I clicked the button to turn the flash back on. Without being able to turn on the flash, anytime I tried to take a photo in regular mode, the camera was warning me, with the hand, that there wasn't enough light and any photo I took would be blurry due to the long shutter speed.
Knowing what to look for now, I put the camera into video mode, then rapid-fire mode, and finally back into regular (green) mode. And suddenly, I was able to click the flash button and turn the flash back on. So that's all it was. Just stuck on my end. You may have had a similar situation, or your flash may be off and you can adjust it.
I hope this helps.
Sep 21, 2008 | Nikon COOLPIX L3 Digital Camera
Cybershot dsc-w70 stuck in video mode
Ok! I've searched and searched, so hopefully this will help you all out.
If the videos are very slow moving, you're in multi burst mode. Simple fix, actually...
Press menu button that's below the dial selector. There should be two small options near the bottom of the screen "mode" and the little suitcase.
Go into mode and make sure that Normal is selected. Multi Burst is actually a 16 frame per second function good for sports. It shows as a slow motion video on the camera and a sort of collage on your computer.
Hope this helps. :)
Nov 30, 2007 | Cameras
Fuji finepixA340
I suppose you've already turned the dial? Yea, on my camera there's dial ontop to turn to select the display mode, and then I turn it to the "shoot" mode, its usually a camera icon.
May 23, 2007 | Fuji FinePix A345 Digital Camera
Camera-video mode
Is it a switch or a dial? have you tried new batteries?have you removed them and let the camera sit with the batteries out over night? The button or mode switch could be bad.
Apr 09, 2006 | Fuji FinePix 2650 Digital Camera
Kodak EasyShare DX6440 Digital Camera Logo
369 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
