Question about Lands Phones
Maestro 3500 telephone feature light is on. need to know how to turn it off
I have a Aastra Telecom 9316CW Corded Phone and I have lost my manual. I need to know how to turn the light back on in the window. Please, please let me know or tell me how I can find out. Thank you. ...
Do you mean the feature light or the backlight for the display? The feature light can be set to on or off.
To set the light, press Save then 1 (for light on) or zero (light off). Press the desired memory key to associate with the feature and then enter the code from your telephone provider for that feature. Press Save and then label the memory key.
To use the feature light, press the memory key (as selected above) and then lift the handset. Press either Handsfree or Mute. The feature and the light will turn on or off. When the phone is not in use, then Feature On will be seen in the display.
The backlight is not adjustable. You can adjust the contrast with the Contrast button. Backlights do fail over time (but it's not a repair I recommend if the phone is out of warranty).
The manual is available here: http://www.aastratelecom.com/cps/rde/xchg/en-ca/hs.xsl/21564.htm . Look at the bottom of the center section for the PDF.
I hope this helps.
Mar 03, 2011 | Nortel Lands Phones
I have installed the Maestro dimmers with the recommended CFL dimmable bulb but when i turn on the power the dimmer cycles up and down and dosent stay on. i have installed one incandescent light in a room...
Maestro dimmers are not recommended with any CFL for pretty much the reasons you are experiencing. The electronics within the CFLs are probably not letting the power circuitry in the Maestro charge-up - and because of that, it comes as no surprise that adding an incandescent lamp solves the problem. The company makes products that are compatible in their Ariadnia/Toggler & Diva product families, but not Maestro - you just need to make sure the dimmer itself identifies itself as compatible with CFLs.
Dec 20, 2010 | Maestro Electrical Supplies
Program "Do not disturb" on business phone
From the manual: You need to program a button with FEATURE 01.
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
¦ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
¦ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
¦ To avoid missing calls when Do Not Disturb is not needed, turn it off
Carl
Mar 16, 2010 | Lands Phones
Need Set-up CD Magellan Maestro 3250
let me say this 1st because this will be the easy way to fix this assuming you tried to either run the update or ran it again after the failure. if thats the case.
im going to assume you tried to update your unit to the 4.46 update that you downloaded off the magellan site,HERE ( if you havent, i suggest you do it before continuing) and in doing so it bricked your unit.
Magellan Will repair or replace any of there gps sytems that were rendered inoperative due to their updates. they will check your account to see if you downloaded the update.
  • register your unit on magellangps.com if you havent already
  • download the update
  • attempt to install update on your computer
  • call magellan tell them your unit is not booting up after the update
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971
hopefully you understand what im saying here.
should you decide to take a different route, let me know and i will help you get it up and running if possible.
bill
Nov 06, 2009 | Magellan Maestro 3250 GPS
How do I unlock Magellan 3250 voice? It says I
if you just bought this, im sure the voice should be unlocked already since its part of the advertised features of the 3250. it should also have the live traffic feature for up to one year.
you can call Magellan here
bill
Sep 06, 2009 | Magellan Maestro 3250 GPS
Lucent Partner 18D telephone turn on caller id
On one of those phones, press "feature 59" That will display the release of the processor. It might be that your processor is not CID capable.
Jun 04, 2009 | Lands Phones
Magellen Maestro 4040 code
it is not a scam .then why did you bought it ,i did on my magellan maestro 4000 the firmware update and map but this unit does not come with turn by turn like the old roadmate700 which gave the option to turn on or off turn by turn voice.but what can you do that is life. regardless you must go to magellan website and do all the Upgrades and Maps Updates
  • Magellan 2008/2009 Map Update - NA
  • Magellan Maestro 4040 Voice Upgrade Magellan Maestro 4040 Voice Upgrade Welcome. You are about to retrieve an Authorization Code for an unlock code so that you can upgrade your Magellan Maestro 4040.
    To purchase an Authorization Code you will need to:
    • Login to your existing user account, or create a new Magellan user account.
    • Register your product if you have not already done so.
    • Have a valid credit card with a billing address in North America or Europe. (Visa, Mastercard, American Express, or Discover in North America, Visa or Mastercard in Europe).
    NOTE: This upgrade includes a new sound engine with a text-to-speech feature and an expanded vocabulary. This upgrade is non-refundable and non-reversible.
Sep 27, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan GPS,Maestro 3100
IF U HAVE THE UNIT FOR LESS THAN A YEAR, U SHOULD BE ABLE TO CALL THEM AND GET FREE REPLACEMENT FROM THE OEM. BUT IF OVER A YEAR THEN I HOPE U BOUGHT AN EXTENDED PROTECTION PLAN AND THAT SHOULD COVERED IF U DID, IF NOT THEN U PROBABLY HAVE TO BUY NEW ONE----
Magellan GPS
960 Overland Court
San Dimas, CA 91773
USA
Customer Service
North America: Telephone 800 669 4477
International: Telephone 1-909 394 5000
Technical Support
North America: Telephone 800 707 9971
International:
Telephone (France and United Kingdom): 0825 864 865 (Cost of a call : from France, 0.125€/minute: From U.K., cost of a long distance call).
May 12, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3100 users guide
CALL THEM AND THEY SHOULD BE ABLE TO PROVIDE U WITH FREE MANUAL AND USER GUIDE WITHOUT QUESTION ASKED.
Magellan GPS
960 Overland Court
San Dimas, CA 91773
USA
Customer Service
Technical Support
International:
Apr 13, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Maestro 3100won't power up
I understand the problem in the unit so to turn on the unit the so please follow the below steps.
-> At the left hand site you can see a small pin hole named as (reset) just inseret a paper clip into the hole and gently push it in side then
-> Press and hold the power button for 20 seconds .
-> The unit will turn on
If still the unit is not turning on means please call to this number :
Technical Support :
North America: Telephone - 800 707 9971
Jan 26, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Lands Phones Logo
123 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
