Question about Canon Office Equipment & Supplies
Paper jam I was given a pc1060. Rec paper jam. Slide platen cover. I have cleared all paper out of fuser and roller areas. same problem still. E111 comes up. under service. any clues to fix.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Make sure that the exit sensor is realese down.generaly u ca check the sensors not to have pull out
Posted on Nov 11, 2008
My oki c3400n continual paper jam's at the fuser. Paper comes out of the printer about 2 inches then jam's. I clear it and it happens again. Don't see any contamination on the fuser roller.
There are paper path cleaner sheets that you can get at supply stores or on line. They are sticky on both sides. They pick up paper dust from the rollers as it passes through the printer.
Feb 17, 2016 | OKI Office Equipment & Supplies
I have a Canon imageclass D880 multifunction, error"Paper Jam, slide platen..." I can see the paper deep within the machine ( fuser?) but cannot get to it to get it out.
Hi marcbachm177,
Please follow the steps below on how to remove paper jams inside printers in hard-to-reach places, a pair of medical forceps is often useful.
1. Take off 3 plastic covers one above exit area-slide top to left to access screw. Remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board.
3. Using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame.
4. Carefully lift fuser up and out toward the exit area.
5. Pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater - be careful NOT to damage plastic heater membrane. remove paper jam and reassemble.
Hope it helps.
Thank you for using FixYa.
Aug 17, 2011 | Office Equipment & Supplies
The copier says rec paper jam slide left platen? what do i do ?
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
Jun 12, 2011 | Canon PC-1060 Black and White Copier
Prompt says, "REC. Paper jam slide platen left". We have done as instructed and looked for paper jams with every opening. We have also rebooted the copier but turning off, then on and also by unplugging...
Hi With this copier I find the paper jam is always in the fuser area. Its very hard to get to. You need a a flash light and tweezers to get it. You need to look where the paper comes out. Thank you, Steven 805-520-3003
Oct 14, 2010 | Canon imageCLASS D661 Digital Printer
Paper jam will not clear
you have a stuck or broken sensor
Jul 02, 2009 | Canon Office Equipment & Supplies
Alarm - paper jam slide platen left - but no jam - won't copy
the paper jam is more than likely in the fuser assembly. unfortunately you will need a service tech to come out and fix that issue.
May 27, 2009 | Canon Office Equipment & Supplies
Display says rec.paper jam,slide platen left
in service mode manually recheck all paper transport sensors...
Mar 17, 2009 | Canon Office Equipment & Supplies
How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Jan 05, 2009 | Canon PC1061 Copier
L-50 machine gets Rec.paper jam slide platen left
Slide the uper unit to the left by pulling handle on the left,open cover on the right,remove drum unit by pulling on the handle,remove paperjam.
Oct 31, 2008 | Canon PC-1060 Black and White Copier
PC1060 canon copier
in your case you have to remove the fuser
I will try to guide you, most of the models are the same.
1-turn off machine and unplug
2-open the side door, you already know where the paper is it's most likely rolled up on a hot long roller, this is the fuser unit
3-with a phillips scredriver(star) remove 2-4 screws that hold the unit, it will have a plug most likely on the right hand side unplug
4-unit should slide out (unless there is a cover holding it
5- you can now see and work on the unit turning the gear by hand to remove the paper.
6-reverse the steps
Aug 12, 2008 | Office Equipment & Supplies
225 people viewed this question
old marine
old marine
Corne Viljoen
