Question about GE 29385GE1 Corded Phone
How do I remove phone from wall bracket
Unable to remove wall phone from bracket. Tried to push up on phone but it won't budge.
    Problem Solver:
  • 10 Answers
Some phones have a little clip on the side of the phone you have to pull out before you can slide the phone up. After pulling the brass clip out on the side of the phone. Take you hand and bump the bottom of the phone up.
Posted on Nov 12, 2008
How to remove promed shower seat
the seat sits on a " v" section that is attached to the wall. You may have to lift the bottom out a bit then lift the seat support up off the bracket. If it has be on for some time then it may require a slight tap with a hammer to get it to move as it mat be corroded into place.
Sep 18, 2014 | NRS Promed Wall Mounted Folding Shower...
How do I remove a BT Viscount wall bracket from the wall?
It is on something called Key Hole Slots.
This is one on metal. Your phone bracket is plastic, so the same upside down keyhole shape is moulded in to the plastic.
There's a couple of screw heads sticking out of the wall. The bracket hangs on those screw heads and is slid down by some small distance. That action moves the bracket so that the heads of the screws pass to the long slot and it holds the bracket securely.
Removing the bracket is simply a case of sliding it up some small distance. Be aware though. If the phone has been there some time then previous occupants may have decorated around it. It might be stuck with paint or wall paper. Use a craft knife to break the seal if this is the case.
Sep 02, 2014 | Televison & Video
Unable to disconnect existing wire on control panel
These white wires could be a thermistor which is a type of heat sensor, if you damage it you have no safety cutout or automatic reset.
Mar 29, 2014 | GE JTP30DPCC 30" Built In Single Wall Oven...
Removal of headlight
Im pretty sure you use the button on the dash to raise the lamps with the light off, remove the covers on the side of the headlamp to expose the metal bracket that holds the lamp in place. When removing the bracket, be sure to only remove the screws that hold it in place- NOT the ones that adjust the aim.
Jun 02, 2013 | 1993 Mitsubishi 3000GT
About alternator replacement for 2001 vw beetle gls...I've removed the upper and lower bolts... What am I missing? Alternator still won't budge. Any assistance would be appreciated. Thanks.
all the bolts removed then all thats holding it is the adjustable tube in on the lower fitting ,put a bar in and try moving it then it will move as on the lower fitting with the long bolt is a tube in the alternator housing bracket and this is pulled or pushed out to make contact with the support bracket .Check you havent got three bolts holding it as some vehicles have two bolts on the bottom bracket or one long one
Apr 15, 2012 | 2003 Volkswagen New Beetle Convertible
I have been unable to remove the wter filter. I have tried to turn it 1/4 of an inch clockwise as described in the owners manual but the filter won't budge. any suggestions?
OK maybe try 1/4 inch counterclockwise and pull down. Here is what the service manual quotes.
That is easy for anyone to misread.
Water Filter Removal
The water filter is located in the upper right-hand
corner of the refrigerator. The water filter filters water
for the ice maker and the water dispenser.
1. Turn the water filter 1/2 turn counterclockwise and
pull it down.
2. To install the filter, align the indication mark
(unlock position) and push it up while turning 1/2
turn clockwise until the lock position is aligned.
Do not over tighten.
That would be to the left while facing the filter and opposite for installation. Note where and when to push up. Please let me know if you have any questions and please rate if I am able to help you, Thanks, Sea Breeze
May 08, 2011 | Samsung RS2556 Side by Side Refrigerator
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
Water filter won't come out when I push the button
Push button? It should be a turn to the left to remove if it is a whirpool located at the bottom. These are twist out not push to release. The only push to releases are made by electrolux.
Mar 07, 2010 | Whirlpool ED2FHEXN Side by Side...
How do you remove the battery cover for the compartment under the phone? I've tried sliding, lifting, etc., but it doesn't budge.
On the back of the phone bottom half, push down where it meets the top half and at the same time push (slide) it down away from the top half. It's very tough but it will work.
Oct 08, 2009 | GE 27980 Cordless Phone
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE 29385GE1 Corded Phone Logo
791 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
