Question about Auralog TeLL me More French Premium Collection Language Software (Beg-Int-Adv) (6002123)
The sound Problem
By clicking on sounds or other parts dont hair any sound.
You must ensure the device is attached correctly and the driver is installed too. There must be no compatability problem...After this you must check the volume level of the system...These are very small things but often small things creates large and huge problems...So after ensuring all the above things if you get this problem then it means that there may be some problem with your sound system i.e. speakers. Check it with a different pair...If it also doesn't fix the problem then send me the details like your computer hardware details,operating system it is using and software you are using....I will be here to help you
Regards
Posted on Nov 18, 2008
Kenmore side by side click and whir noise but not getting cold
There is a coil called the condenser located on the bottom of the refrigerator, that may be plugged with dirt and or animal hair. Check and clean this coil and see if this solves your problem.
Oct 05, 2014 | Kenmore Side by Side Refrigerator
Driver side door lock jammed on 2004 jeep grand cherokee
the key dont work or just the fob?????????????
did you try both fobs?
car came with 2 fobs try both. ?
if both fobs fail, bad solenoid, if metal key works.
if metal dont work, the lock is frozen with ICE, got ICE?(hair dryer fixes it)
no ice ?,then lube the lock with graphite,lube. if key fails.
if key dont fail and you get 12v to solenoid, then the solenoid is bad
I just replaced one that had 1/2 power (the guts inside sol were bad)
$100 part. too.
Feb 06, 2014 | Jeep Cars & Trucks
Sporatic clicking/scraping sound
SOUNDS TO BE A CV JOINT(CONSTANT VELOCITY JOINT) ALSO HAVE BRAKES CHECKED FOR POSSIBLE LOOSE OR WORN PARTS
Jun 24, 2013 | Cars & Trucks
What is a hair iron? The thought of ironing hair sounds very scary.
A hair iron (or hair tong) is a type of hair tool that uses heat to change the structure of the hair ie to straighten it or crimp it. They do get very hot but it's not as scary as it sounds.
Jan 10, 2013 | Health & Beauty
Motor not running but brushes rotate, makes weird sound
thats decouse it is,,,it could well have burnt out if it got "cooked" becouse it was blocked up with dogy hair they get very hot and just melt?
Jun 25, 2010 | Dyson DC25 All Floors Bagless Upright...
The compresoor
Change the relay. If you hear the click it means power is getting there. Must be the innards of the relay are shot. Take the relay off and shake it. If it sounds like a salt shaker it is bad.
May 28, 2010 | Amana ASD 2624 Side by Side Refrigerator
Pleas i av a problem with my toshiba qosmio g10 i have try all my best to download the sound drive i dont know how to do it pleas i need your help asap
These are steps to setup the Audio and to restore the Audio: drivers. Part (1) Click the "Start" button. Go to, and click in the (right, pane) Control Panel. Scroll to find, "Ease of Access (or) Speech Recognition Options. "Click on," Replace sound with visual cue." In the See also (Category) click on, Audio Devices and Sound Themes. Click, Playback, next, click on the Active "Speakers" Click 'Configure' to "Audio channels" The (Speaker Setup) "wizard", appear! Select (Test) click, Next. Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. The (Advanced), not recommended! In, the Controller Information (block), click on, Properties to"update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: “Click, "OK", Save and "Apply" to all changes before exiting. To finish, restart the Computer!" Did this solution help?”
Jan 28, 2010 | Toshiba Qosmio G10-133 Notebook
Loud sounding like loose parts when draining
possibly a coin or hair clip in the pump if not the propeller on the pump may be loose try locating the pump under the machine and try to romove it
Nov 11, 2008 | Kenmore 43052 Front Load Washer
My hair straightener stops working when i increase the level of intensity to dry hair, what can be the problem?
Sounds like a short in the unit. It can be taken apart and make certain all of the wires are tight. Not sure what what you mean by increase intensity but if it means you oull harder it may just be too much for the unit. Try not putting so much pressure on it. Good luck.
Aug 14, 2008 | Conair Professional Ceramic Hair...
Linksys Wireless-N USB Network Adapter WUSB300N Drivers
Hello, Click start, right click my computer, click manage. From there click device manager. This will list all installed devices including sound. Right click sound device and Click Update driver. Follow instructions. Reboot computer. If this doesn't work, get manufacture and part numbers off sound card. Go to manufacture web site and do a search for card number and download driver. Hope this helps
Mar 23, 2008 | Computers & Internet
Auralog TeLL me More French Premium Collection Language Software (Beg-Int-Adv) (6002123) Logo
138 people viewed this question
Top Auralog Computers & Internet Experts
David Payne
David Payne
Are you an Auralog Computer and Internet Expert? Answer questions, earn points and help others
