Question about Sanyo PLC XU35 Multimedia Projector
2 projectors that have blown their lamps
I have two Sanyo Pro Xtra's that are used about 30 hours per week and have both blown their lamps within 7 months. What would cause this? They are mounted upside down and about 25 feet high with no obstructions.
  • 3 Answers
Do you know they probably need a cool down period before you disconnect them from the mains and if they are in a smokey enviroment they should be in filter cases
Posted on Feb 05, 2009
  • 3 Answers
My guess is with them so high in the air, no one seems to clean the air filter often enough. Also, the projector is at 840 hours which is just a few hundred below the normal lamp expectancy. Also, I would wonder how they are shut down. Do they actually go through their normal shutdown process as requested by the manufacturer, or has someone that programmed the shutdown to just kill the power to the circuit. That would definately be worth checking.
Posted on Dec 29, 2008
How to find lamp hours
Hello
Lamp life depends on how much you use it per day. Effeciency of lam detereiate to time. Anyway if you use the projector for 4hours a day, the lamp may last for 1 year. OK.
Feb 05, 2012 | Sanyo PLC-XP51 Multimedia Projector
Hi, i have the projector since january 2009, i use it no more than 2 hours a week, sudenly the lamp stupped to work, and when i try to get it on - the replace lamp is flash, what is the prublem?
Was it new when you bought it. (that is, are the lamp hours approximately 220 hours genuine)
take the lamp out and check that it looks OK.
The unit may have an electronic fault on the lamp power supply board.
Mar 26, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
The projector is approximately 4 years old & on average runs for about 60 hours per week, 40 weeks of the year. After fitting a new lamp last October & resetting the projector, the image is still...
Additional information is required for us to assist. Can you better describe what you mean by "poor image"? Are the colors separated? Is the picture out of focus? Are the colors wrong?
Please describe the picture or post a picture of the screen if you can.
Thanks,
Dan
Feb 03, 2010 | Sanyo PLC-XP57 LCD Projector
Picture dull colours incorrect on sanyo pro xtra x projector
reset to factory default settings (from the menu). after that if it's not where you want them, you can go into the menu and set them to where you like them.
Aug 04, 2009 | Sanyo PLC XU35 Multimedia Projector
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Projection issue
sounds like you might need to change the KEYSTONE settings
Nov 14, 2008 | Sanyo PLC XU35 Multimedia Projector
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on.
Aug 04, 2008 | Office Equipment & Supplies
Sanyo Pro xtra projector - warning light
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Feb 08, 2008 | Sanyo PLC XU33 Multimedia Projector
Sanyo PLC XU35 Multimedia Projector Logo
146 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
