Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Viking Range My Viking Range has one burner that keeps trying to light even when it is turned off. It is driving us crazy with its clicking - how do we turn it off?
  • 3 more comments
  • richard64 Dec 01, 2007
    One burner on my Viking 4 burner range continues clicking after the burner is lit. The only way to stop the clicking is to turn the burner off. I replaced the sparking module and now all four burners click. I tried cleaning the spark electrodes but that did not work. Help
    Clicking will not stop on Viking range
  • schpoo Jan 05, 2008
    Our viking oven has the same clicking problem, however not all the time. so it can't be a short. Can it be cleaned? or does it have to be replaced? If it has to be replaced, how do you do that?
  • Dr Race Aug 01, 2008
    I've got the same problem (on a viking stovetop). However, it seems to me that this is related to the 'auto relight' feature: If I turn the gas off, I get continuous sparks on all burners; turn it on, the front two stop sparking when lit.
    My problem is that I cannot tell how the 'auto-relight' circuit detects a lit burner - there are no temperature detectors that I can see. Does anybody know how this works? My only guess (a wild one) it that it is based on a electrical measurement which is changed by combustion products and that the shut-off circuit is not working on my two back-burners.  That said, it's odd that the same problem occurs on both sides, with, apparently, separate spark circuits.
  • bkruger5 Oct 12, 2008
    My new Viking range ignitors keep clicking when burners are turned to low or simmer. Is this typical?
    If this is the case, I am returning this range to dealer.
    President:
  • 878 Answers
Juliac, the burner valve switch for that burner is either shorted or grounding out. Each burner control has a valve switch that controls the power to the igniter. Sometimes they just get full of gunk and short. Part number is PA020015. Catriver...post back.
Posted on Nov 10, 2006
2 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Viking Range
The clicking is the electrode arcing. when the burner lights, a sensor tells the electrode to stop sparking after is heats up a little, that's why is clicks a little after the burner lights, but then stops. If the spark keeps going, the sensor is not registering the flame. The ones that do not click could be the ignite coil, the wire, or the electrode.
Posted on Nov 15, 2007
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
The electronic start will not shut off, it just keeps on clicking even wneh the burners are turned off
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 26, 2011 | Viking Microwave Ovens
When we turn the oven on the ignitor keeps making a Clicking sound like it is trying to keep igniting
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
heatman101
Sep 02, 2010 | Viking Kitchen Ranges
The gas burners are sparking and i am unable to turn off
heatman101
Aug 30, 2010 | Viking VGSC366-6B Gas Kitchen Range
My auto reignition keeps clicking even though the stove is not being used. How do I make it stop. Turning the burners on and off doesn't help.
you have a bad ignition switch some where
un plug it ( the range) and uses matches
its alot cheaper and much less the headache
Oct 02, 2009 | Viking 48" 6 Burner, Grill Professional...
Viking with CRAZY Ignitor
Hi there, I am attaching your manual in case it helps you.
On page 53, in the troubleshooting chart, the ninth item down seems to suggest similar 'problems' - including possible 'cause / remedy' to the right in same chart.
The manual includes the manufacturers contact info on page 1 of this pdf (the back page of the manual itself.).
Or, the manual LINK is here:
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m2730059_F20542.pdf
(and attached as noted above). Good luck to you!
(Hope this helps - please click below if so, thanks!)
Apr 29, 2017 | Viking VGIC305-4B Gas Kitchen Range
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Viking Range
Nov 15, 2007 | Viking VGSC366-6B Gas Kitchen Range
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
944 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
