Question about Hampton Bay 04379 Madison Avenue Ceiling Fan
Need a replacement cover or light in madison ave ceiling fan
Light cover broke during installation and a replacement is needed - do you know where we can find one please and thank you.
June 2006
E75795
model : AC-552Avantl
Fan and light: AC 120V, 60Hz, 3.3A (Max)
Mfgr no. 5AO0007
UPC#71821214089
Vendor#16849
dATE: 0606
sn:0000004
SOURCE: my remote control fan does not work
Home Depot has a lifetime warranty on the receiver's
Mine is broken also
Posted on Feb 23, 2008
rickzilla
  • 706 Answers
SOURCE: Instruction Manual
Hampton Bay is carried by Home Depot. You must have a Home Depot near you.. ( everyone else does).They should be able to make a copy of the manual for your specific fan. I'm sure if you contact Hamptom bay directly by going to www.hapmtonbay.com and selecting their contact us menu, you should be able to get the information from them. The question is about why your fan motor isn't operating and it's pretty simple. You either do or don't have power getting to the motor, if you do .. then you may have a bad motor or it is mechanically bound up.. Are you sure it has power? If it does, are you sure that power is getting to the fan wire in its junction box? If it does, is the fan mechanically bound up ( meaning that the blades can't be rotated by hand? ) Those are the fan basics you need to get resolved.. Most fans are wired pretty much the same way ( black is hot, blue is tied to hot if you have a light fixture/fan combination, white is neutral and attaches to all white wires in fan junction box, green is ground and should be connected to the metal housing of the fan. This may differ slightly if you have a remote control set up but in general, that is how it is wired.. Good luck.. and hope this helps you identify the problem.. Fan or Power to the fan,,,
Posted on Sep 03, 2008
landsend
  • 1066 Answers
SOURCE: Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Posted on Mar 31, 2009
  • 5 Answers
SOURCE: where to find ceilng fan replacement parts?
you can either check the company that made the fan or try your local home depot in the light isle towards the back you should see fan parts and light globes.
Posted on Jul 22, 2010
  • 122 Answers
SOURCE: I accidentally broke my Hampton
i know they sell covers at menards and lowes they have a great litting department,good luck
Posted on Aug 09, 2011
I just installed my Hampton Bay fan w/ light kit. The fan works, but the lights don't. What might be wrong.
Did you verify that the light harness was plugged into the harness coming from the motor assembly?
Jun 12, 2011 | Madison Avenue 04317 Hampton Bay Ceiling...
Pull cord is stuck on a hampton bay ceiling fan model ac-552
Most likely broken. Sometimes you can wiggle and work it loose. If not you can replace the pull chain switch. You will have to (remove power first of course) get to the actual switch. most fans this is relatively easy. Often it is just under the glass light cover. There will be a retaining nut and the switch should come loose. Home depot, lowes, and most hardware stores should have a generic replacement that should fit. you may or may not have to cut the wires to remove the old one, but a couple wire nuts to install the new one and you should be good to go. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 02, 2010 | Hampton Bay 04379 Madison Avenue Ceiling...
Cracked the light cover can I replace it
yes, you can probably go down home-depot or lowes and show them cracked light cover.
Apr 10, 2010 | Madison Avenue 04889 Hampton Bay Ceiling...
My hampton bay ceiling fan it a rounded light and I don't know how to get to the light bulb to change it?
ther are three small screws that need to be loosen, once these are loose, the globe will come off and you can now change the light bulbs
Oct 18, 2009 | Madison Avenue 04889 Hampton Bay Ceiling...
Where can I find a new one?
I have one I can sell you but they don't sell them any more. email MKElectricinc@aol.com
Aug 04, 2008 | Madison Avenue Romanesque II 04921 Ceiling...
Light cover/Dish for ceiling fan
My installation instructions say call 1-800-295-4448 and give the following infromation: 1. Part number 2.Part description 3. Style number of your fan. It is part number 31 Glass Shade
Jul 11, 2008 | Dryers
Change light bulb
I have a fan just like that one to change a light bulb all you have to do is unscrew it from the fan itself and if that dosnt work then unscrew the plastic cover or unscrew a screw on the plastic cover
Dec 30, 2007 | Madison Avenue 04889 Hampton Bay Ceiling...
Ceiling fan will not turn off
There is 2way switch attached to this chain you need to replaced it.
Jun 04, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay ceiling fan
You have a dangerous electrical situation call an electritian to test the wiring.
Oct 20, 2006 | Hampton Bay 04379 Madison Avenue Ceiling...
Hampton Bay 04379 Madison Avenue Ceiling Fan Logo
158 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
