Question about Homelite Consumer Products Backpack Blower/Vac, Carb
New model ut08580 backpack will not start
When the primer bulb is pressed, no fuel appears in the bulb; the fuel lines are not blocked
  • 1 more comment
  • jmdionne Mar 18, 2009
    What do you mean by small fuel rail holes? Where are they??
  • Anonymous Mar 29, 2014
    replaced primer bulb and the unit will not pump fuel into carb replaced filter (did not have one )and fuel lines
    replaced primer bulb ,fuel lines and filter The unit will not take in fuel even tried switching lines
I have the same problem with my ut08580. When inspecting the carb, I noticed the diapham was torn. I cut a small amount off the corner of the diaphram and set it in the spot of the tear and put it back together. It worked for now, but I would like to order a new diaphram does anyone know how. I've been searching different parts sites for 3 hrs with no luck. I hope I don't have to buy a new carb.
Posted on Jun 04, 2009
  • 163 Answers
Check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 29, 2008
How to hook up fuel lines on a ryobi 08576 backpack leaf blower
hook one up and press the primer bulb if it doesn't squirt fuel out when the bulb is pressed you have the wrong pipe connected
primers work like this they suck fuel from the tank , through the diaphragm pump , into the float diaphragm and out back to the tank
Nov 17, 2017 | Ryobi Garden
Poulan P2500 weedeater want start
change over the fuel lines on the carby
Mar 24, 2016 | Poulan P2500 17" Gas Trimmer
I can't get it to start. Don't think the gas is moving when I pump it to start it. When I push on the bulb, it doesn't appear to pick up fuel.
Is the primer bulb filling with fuel.? If not then you either have a hole in the primer bulb or a hole in the fuel line, you mat also have a blocked primer bulb base.
Aug 03, 2013 | Garden
Primer bulb will not prime
Sounds like it could be a number of faults.
1. Crack in the primer bubble its self, not allowing the creation of pressure or vaccum.
2. The plastic primer base has a valve in it. That could either be blocked or damaged.
3. Blocked up fuel line (not very likely)
4. Hole in the fuel line which is sllowing it to suck air up and not fuel.
I\'d be putting my money on 1 or 2.
Jul 03, 2013 | Husqvarna Garden
Replaced gas tank and primer bulb on my Poulan Leafblower FL1500 and it appears I'm not getting gas into the carb. Any ideas as to what my be the cause?
I assume the new tank came with new fuel lines and filter in it.
First be sure you have all the lines hooked up correctly. There should be a main line from the tank ( has the fuel line on the end of it in the tank) to the fuel pump side of the carb. Then there should be a line leaving the metering side of the carb to the primer bulb then from the primer bulb returning to the tank. When you press the primer bulb you should see it **** the fuel into the carb then from the carb into the primer bulb then back into the tank.
If the fuel lines are all hooked up correctly then you should rebuild the carb.
Jan 02, 2010 | Poulan Featherlite Gas Blower, with Low...
There is a connector or something missing from the fuel overflow line from the carburetor back to the fuel tank
There is no such thing as a fuel overflow line.
If the unit has a primer bulb then there will be 2 lines in the tank ( 1 is a main fuel line distinguishable by the length of line that extends into the tank with a fuel filter on the end of it, the other is a return line from the primer bulb that terminates just inside the tank usually with a male to male conector.) The main fuel line will go to the carb and another line from the carb will go to the primer bulb. If any of these lines are discolered, fragile or broken then they should be replaced. Generally the smaller diameter line is the main fuel delivery line and the larger diameter line is the primer system.
Nov 19, 2009 | Poulan Bp406 45.4cc Backpack Leaf Blower
How do you install primer bulb on husqvarna 125b blower, which line to hook up where
Hello . After you replace the primer bulb , the left tube on the primer bulb goes to the fuel filter inside the tank and the one on the right is just a fuel return that goes inside the tank . Hope this help
May 02, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
688 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
